ELV Max! Heating control system
michass
- Domoticz version: 4.10064
Re: ELV Max! Heating control system
I have MAX! system and Synology based Domoticz.
Please help me with configure this in Synology enviroment.
Thanks in advance
Michał
Thanks in advance
Michał
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
Heating: eq-3 MAX!
Cam: Foscam C1
sakekl
What am I doing wrong??
my script looks like this:
The first run of the script causes an error:
However, in the domotic in the hardware tab, a new item appears.
The next launch of the script no longer contains errors.
But there are no new devices in the device tab.
Logs in domoticz indicate that the data is reaching correctly.
The whole domoticz system operates in container station on qnap.
Please help.
Post written using the Google translator.
-- Script which creates & synchronizes devices in Domoticz with values from MAX! cube
-- Change variables below to your own values
-- Start by adding new cronjob "*/5 * * * * /usr/bin/lua /home/pi/domoticz/scripts/lua/maxscript.lua" (using crontab -e)
MaxIP='192.168.*.***' -- IP adress of your Cube, best to check via your router
MaxPort = 62910 -- Port used by your Cube, usually 62910
DomoticzPort = **** -- Port used by Domoticz, 8080 is the default
useWMT = false -- Set to true if there is a wall mounted thermostat in every room
interval = 5 -- Polling interval in minutes, fill in same value as in crontab
setpoint_DoorOpen = 1 -- Setpoint when door/window open
json = (loadfile "/home/ubuntu/domoticz/scripts/lua/JSON.lua")() -- uncomment if you're using Linux (comment next line)
--json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")() -- uncomment if you're using Windows (comment previous line)
-- No changes required below this line -
package.loadlib("core.so", "*")
Socket = require "socket"
Basexx = require "basexx"
http = require "socket.http"
Rooms = {}
Devices = {}
Types = {}
Room_nums = {}
function age(timestring)
t = {}
t.year = string.sub(timestring,1,4)
t.month = string.sub(timestring,6,7)
t.day = string.sub(timestring,9,10)
t.hour = string.sub(timestring,12,13)
t.min = string.sub(timestring,15,16)
t.sec = string.sub(timestring,18,19)
return os.difftime(os.time(),os.time(t))
function get_MAX_ID()
result, statuscode, content = http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=hardware')
r,e = json:decode(result)
if r.status == "OK" then
for k,v in pairs(r.result) do
if v.Name == "MAX!" then return v.idx end
function ReadThermostat(DID)
result, statuscode, content = http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=devices')
if v.ID == DID then return v.SetPoint,v.LastUpdate end
return 0, '2016-01-01 00:00:00' -- value to return if device was not found
function UpdateValve(DID, value)
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&hid='..MAX_ID..'&did='..DID..'&dunit=1&dtype=243&dsubtype=6&nvalue=0&svalue='..value)
function UpdateTemperature(DID, value)
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&hid='..MAX_ID..'&did='..DID..'&dunit=1&dtype=80&dsubtype=5&nvalue=0&svalue='..value)
function UpdateSwitch(DID, status)
if status == "On" then
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&hid='..MAX_ID..'&did='..DID..'&dunit=1&dtype=17&dsubtype=0&nvalue=1')
elseif status == "Off" then
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&hid='..MAX_ID..'&did='..DID..'&dunit=1&dtype=17&dsubtype=0&nvalue=0')
function SetpointSync(DID, devicename, setpoint_MAX)
setpoint_Domoticz, LastUpdate = ReadThermostat(DID)
if tonumber(setpoint_Domoticz) ~= setpoint_MAX then
if age(LastUpdate) > interval * 60 then -- Domoticz thermostat value must be updated
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&hid='..MAX_ID..'&did='..DID..'&dunit=1&dtype=242&dsubtype=1&nvalue=0&svalue='..setpoint_MAX)
print(os.date("%x %X ")..'Domoticz setpoint '..devicename..' set to '..setpoint..' degrees')
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=addlogmessage&message='..string.gsub('Domoticz setpoint '..devicename..' set to '..setpoint_MAX..' degrees',' ','%%20'))
elseif setpoint_Domoticz ~= setpoint_DoorOpen then -- MAX! setpoint must be updated
MaxCmdSend(adr, room_num, "MANUAL", setpoint_Domoticz)
print(os.date("%x %X ")..'MAX! setpoint '..devicename..' set to '..setpoint_Domoticz..' degrees')
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=addlogmessage&message='..string.gsub('MAX! setpoint '..devicename..' set to '..setpoint_Domoticz..' degrees',' ','%%20'))
function maxCmd_H(data)
-- print('H='..data)
function maxCmd_M(data)
i = 0
j = 0
while true do -- find next comma
i = string.find(data, ",", i+1)
if not i then break end
j = i
s = data:sub(j+1)
dec = Basexx.from_base64(s)
num_rooms = string.byte(dec,3)
if num_rooms == 0 or num_rooms == nil then
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=addlogmessage&message=MAX!%20configuration%20error!')
pos=4
for i=1, num_rooms do
room_num = string.byte(dec, pos)
name_len = string.byte(dec, pos+1)
pos = pos+2
name = dec:sub(pos, pos+name_len-1)
pos = pos+name_len
adr = Basexx.to_hex(dec:sub(pos, pos+2))
Rooms[room_num] = name
pos = pos+3
num_devs = string.byte(dec, pos)
for i=1, num_devs do
dtype = string.byte(dec, pos+1)
adr = Basexx.to_hex(dec:sub(pos+2, pos+4))
snum = dec:sub(pos+5, pos+14)
name_len = string.byte(dec, pos+15)
pos = pos+16
pos = pos+name_len
Room_nums[adr] = room_num
Devices[adr] = name
Types[adr] = dtype
function maxCmd_C(data)
-- print('C='..data)
function maxCmd_L(data)
pos = 1
dec = Basexx.from_base64(data)
L_hex = Basexx.to_hex(dec)
L_len = string.len(L_hex)
while (pos < L_len) do
s = L_hex:sub(pos,(pos+1))
data_len = tonumber(s,16) + 1
hex = L_hex:sub(pos, pos+(data_len*2))
adr = hex:sub(3,8)
room_num = string.format("%02X", Room_nums[adr])
room = Rooms[Room_nums[adr]]
name = Devices[adr]
dtype = Types[adr]
if not name then name=adr end
valve_info = tonumber(hex:sub(13,14),16)
batt = bit32.extract(valve_info,7,1)
bst = bit32.extract(valve_info,3,1)
mode = bit32.extract(valve_info,0,2)
if (batt==0) then sbat="OK" else sbat="Low" end
if (mode==0) then smode="Auto" elseif (mode==1) then smode="Manual"
elseif (mode==2) then smode="Holiday" elseif (mode==3) then smode="Boost" end
if dtype == 3 then -- WallMountedThermostat
s = hex:sub(17,18)
setpoint = tonumber(s,16) / 2
if setpoint > 50 then setpoint = setpoint - 64 end
s = hex:sub(23,26)
temp = tonumber(s,16) / 10
if temp < 5 then temp = temp + 25.5 end -- temporary solution for 2 digit hex temperature limitation
UpdateTemperature(adr, temp)
SetpointSync('0'..adr, name, setpoint)
elseif dtype == 1 or dtype == 2 then -- Valve
s = hex:sub(15,16)
valve_pos = tonumber(s,16)
s = hex:sub(17,18)
s = hex:sub(19,22)
UpdateValve(adr, valve_pos)
if not useWMT then -- Use valve for temp & setpoint
if temp ~= 0 then UpdateTemperature(adr, temp) end
elseif dtype == 4 then -- Door/window sensor
if mode == 2 then UpdateSwitch(adr, "On") else UpdateSwitch(adr, "Off") end
pos = pos + (data_len*2)
function MaxCmdSend(id, room, mode, setpoint)
bits = setpoint * 2
smode = string.upper(mode)
if smode == 'MANUAL' then
bits = 64 + bits
elseif smode == 'BOOST' then
bits = 192 + bits
elseif smode == 'VACATION' then
bits = 128 + bits
hex = "000440000000"..id..room..string.format("%x",bits)
sendStr = Basexx.to_base64(Basexx.from_hex(hex))
i, status = tcp:send("s:"..sendStr.."\r\n")
if not i then
print("MAX TCP send failed - "..status)
return
-- Main script start --
--Get ID of MAX hardware in Domoticz, create if it doesn't exist
MAX_ID = get_MAX_ID()
if MAX_ID == nil then -- "MAX!" dummy hardware not yet created, create it
http.request('http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=addhardware&htype=15&port=1&name=MAX!&enabled=true')
tcp = Socket.connect(MaxIP, MaxPort)
if not tcp then
print("Socket connect failed for "..MaxIP..':'..MaxPort)
return
tcp:settimeout(2)
while true do
s, status, partial = tcp:receive()
if (status) then
print("TCP receive - "..status)
break
local line = (s or partial)
local cmd = line:sub(1,1)
local data = line:sub(3)
if (cmd == 'H') then
status = maxCmd_H(data)
if status == 'Error' then break end
elseif (cmd == 'M') then
maxCmd_M(data)
elseif (cmd == 'C') then
maxCmd_C(data)
elseif (cmd == 'L') then
maxCmd_L(data)
break
tcp:close()Code: Select all
lua: maxscript.lua:62: attempt to concatenate global 'MAX_ID' (a nil value)
stack traceback:
maxscript.lua:62: in function 'UpdateValve'
maxscript.lua:189: in function 'maxCmd_L'
maxscript.lua:259: in main chunk
[C]: in ?
09/20/18 15:19:19 Domoticz setpoint Agatka-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Podłoga Łazienka-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Podłoga Kuchnia-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Sypialnia-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Podłoga Kuchnia-Stat set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Salon-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Podłoga Łazienka-Stat set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Łazienka-Rad set to 17 degrees
09/20/18 15:19:19 Domoticz setpoint Łazienka-Stat set to 17 degrees
2018-09-20 15:19:18.158 Status: Incoming connection from: 127.0.0.1
2018-09-20 15:19:19.010 Status: Domoticz setpoint Agatka-Rad set to 17 degrees
2018-09-20 15:19:19.067 Status: Domoticz setpoint Podłoga Łazienka-Rad set to 17 degrees
2018-09-20 15:19:19.123 Status: Domoticz setpoint Podłoga Kuchnia-Rad set to 17 degrees
2018-09-20 15:19:19.172 Status: Domoticz setpoint Sypialnia-Rad set to 17 degrees
2018-09-20 15:19:19.218 Status: Domoticz setpoint Podłoga Kuchnia-Stat set to 17 degrees
2018-09-20 15:19:19.268 Status: Domoticz setpoint Salon-Rad set to 17 degrees
2018-09-20 15:19:19.314 Status: Domoticz setpoint Podłoga Łazienka-Stat set to 17 degrees
2018-09-20 15:19:19.363 Status: Domoticz setpoint Łazienka-Rad set to 17 degrees
2018-09-20 15:19:19.409 Status: Domoticz setpoint Łazienka-Stat set to 17 degrees
Please help.
mvzut
That the script gives an error the first time it is launched is normal, it needs to create the new (virtual) hardware on the first run. During the second run, it should automatically create the devices, but I have noticed it doesn't do this anymore. The JSON commands that the script uses for this are no longer functioning as they did before, many (beta) versions back. They still update existing devices, but they don't create new ones anymore if the given device doesn't exist yet. I have posted a question about this on the forum quite some time ago, but received no reaction from the Domoticz authors yet.
I am currently thinking about a solution for this. My ultimate wish is to make a Python plugin, but this requires me to learn Python and dive into the plugin architecture. That takes time that I currently don't have. Alternatively, you can follow the process as described on the Wiki (https://www.domoticz.com/wiki/EQ3_MAX!). This requires you to create the devices yourself, but once you have done that everything should work smoothly.
sakekl
Thank you for your answer. I created new devices manually and used the script_time_max.lua script described on the wiki. Only door sensors do not work for me. Is it possible for the door sensors to show their status?
mvzut
Can you try the script below? I haven't tested it myself, but it should work in theory. It requires you to create virtual on/off switches with the same name as defined for the window/door switches in the e-Q3/ELV MAX configuration software.
--./script_time_max.lua
-- Script parameters
local Socket = require "socket"
local Basexx = require "basexx"
local MaxIP='192.168.178.46'
local MaxPort = 62910
local useWMT = true --Set to true if there is a wall mounted thermostat in every room
local interval = 5 --Polling interval in minutes, possible range 1-59. Cube doesn't seem to like too frequent communication, 5 minutes is a safe value
local DomoticzPort = 8080
local Rooms = {}
local Devices = {}
local Types = {}
local Room_nums = {}
t = {}
i = 0
j = 0
j = i
s = data:sub(j+1)
pos=4
pos = pos+2
pos = pos+name_len
pos = pos+3
pos = pos+16
pos = pos+name_len
Devices[adr] = name
Types[adr] = dtype
pos = 1
hex = L_hex:sub(pos,pos+(data_len*2))
adr = hex:sub(3,8)
name = Devices[adr]
dtype = Types[adr]
if (dtype == 3) then
valve_pos = -1
s = hex:sub(17,18)
s = hex:sub(23,26)
elseif (dtype == 1 or dtype == 2) then
s = hex:sub(15,16)
s = hex:sub(17,18)
if (mode ~= 2) then
s = hex:sub(19,22)
temp = 0
--Following two lines correct temperatures over 25.5 degrees, since e.g. 26 degrees is reported as 0.5 degrees
--This is due to the fact that temperatures seem to be stored as two Hex characters only (= max 255 in decimal)
--Pending better solution
-- Update virtual devices in Domoticz and update MAX! setpoints if necessary
--print(dtype.." "..name.." Setpoint="..setpoint.." Temp="..temp.." Valve pos="..valve_pos)
-- Commands for valve
if (dtype == 1 or dtype == 2) and name:sub(-5,-1) ~= "-Sens" then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[name]..'|0|'..valve_pos})
if not useWMT then --Use valve to update temperature and synchronize setpoints
name = name:sub(1,-5) .. "-Stat" -- set thermostat name to valve name with "-Stat" instead of "-Rad" suffix
setpoint_Domoticz = tonumber(otherdevices_svalues[name])
if setpoint_Domoticz ~= setpoint then
if age(otherdevices_lastupdate[name]) > interval * 60 then --Domoticz thermostat value must be updated
table.insert(commandArray, { ['OpenURL'] = 'http://127.0.0.1:'..DomoticzPort..'/json.htm?type=command¶m=udevice&idx='..otherdevices_idx[name]..'&nvalue=0&svalue='..setpoint})
print('Domoticz setpoint ' .. name .. ' updated')
else --Max! setpoint must be updated
MaxCmdSend(adr, room_num, "manual", setpoint_Domoticz)
print('MAX! setpoint ' .. name .. ' updated')
-- Commands for thermostat
elseif dtype == 3 then
table.insert(commandArray, { ['UpdateDevice'] = otherdevices_idx[room]..'|0|'..temp})
-- Commands for door/window sensor
if mode == 2 then
commandArray[name] = "On"
commandArray[name] = "Off"
bits = setpoint * 2
bits = 64 + bits
bits = 192 + bits
bits = 128 + bits
if not i then
return
local m = os.date('%M')
if (m % interval == 0) and (m ~= 0) then
if not tcp then
return
tcp:settimeout(2)
while true do
if (status) then
break
maxCmd_M(data)
maxCmd_C(data)
maxCmd_L(data)
break
tcp:close()
Last edited by mvzut on Saturday 22 September 2018 13:24, edited 3 times in total.
sakekl
After applying the script, it receives error.
I also came up with such a way to read window sensors, only that it works only with the head turned on, so it would have to work all year long.
2018-09-22 15:20:00.987 Error: EventSystem: in /home/ubuntu/domoticz/scripts/lua/script_time_max.lua: /home/ubuntu/domoticz/scripts/lua/script_time_max.lua:72: attempt to index global 'Types' (a nil value)-
mvzut
Oops, forgot to declare a new array in the beginning of the code. I have updated the code two posts back, can you check again?
sakekl
Now he gets the following error in domoticz log:
If I run this script in the console then:
2018-09-22 17:07:01.258 Error: EventSystem: in /home/ubuntu/domoticz/scripts/lua/script_time_max.lua: /home/ubuntu/domoticz/scripts/lua/script_time_max.lua:173: attempt to index global 'CommandArray' (a nil value)Code: Select all
lua: script_time_max.lua:139: attempt to index global 'otherdevices_idx' (a nil value)
stack traceback:
script_time_max.lua:139: in function 'maxCmd_L'
script_time_max.lua:236: in main chunk
[C]: in ?-
mvzut
Found two typos, that's the disadvantage of writing code without testing (I have no access to my Pi currently). Can you check again? (Post above updated)
sakekl
Everything works now. I am very happy. I will try to add an additional switch - "auto manual eco boost".
Thank you very much for your help, which is invaluable.
I will add that running the script from the console causes an error, but everything works so it probably is not important.
stack traceback:
[C]: in ? -
mvzut
You're welcome!
Please share how you add the auto/manual/eco/boost button, so others can be inspired by it.
By the way, it is perfectly normal that LUA scripts give errors when run from the command line, because they are not able to communicate with Domoticz using commands like 'otherdevices[..]', 'commandArray[..]' etc. in this situation.
sakekl
If only I can implement such a button, I will certainly share my knowledge. However, I do not have much experience with domotic, so I may not succeed.
mvzut
Strange, for me it works fine with the name instead of the ip address!biomm wrote:Dear all,
After a few successful years my system (R Pi + eMAX! + Lua script) stopped to response. Lua script (with crontab) - fine, eMAX! devices are OK as well so... the only reason might be new router (!!)
Some minuter later it was obvious that new device is NOT able to set "static IP" and from time to time IP of eMAX! Cube was changing (why new devices are lacking such an important setting??)
As stated in Lua sript it should be possible to use IP or NAME of Cube device:
-- Enter your cube name or ip address and port here
--MaxIP='192.168.x.x'
MaxIP='LEQ1234567'
MaxPort=62910
/source - wiki - EQ3 MAX/
For some reason in my case IP is working fine while NAME is not working at all.
Script test results: Socket connect failed for 'LEQ1234567"
I would appreciate advice / help - checking each time for IP and paste it to max script is possible BUT very annoying - especially winter time while heating is ON.....
What you could try is the following code instead of MaxIP='LEQ1234567':
MaxIP = Socket.dns.toip('LEQ1234567')P.S. I'm not exactly sure, but I believe you can configure the Cube (using the provided software) to get an automatic IP adress or not. If you enter the fixed address here that you have in your script, it will probably also work.
nono212
- Domoticz version: 3.6179
Hi Guys
I have the same problem as michass I would like to use Max Heating with Domoticz (but it is runing the Jahdal 6.2 on synology )
So no Lua available
Can you help
So no Lua available
Can you help
mvzut
I have no experience with Domoticz on a Synology, is there no Lua package available for this system?nono212 wrote:Hi Guys
So no Lua available
Can you help
I assume it does run time- and event-based Lua scripts inside Domoticz? In that case, you can skip the test script part in the Wiki and set up the time-based Lua script as described there (after manually creating the devices). Use the version shown a few posts back if you also need support for door/window switches (I'll see if I can update the Wiki soon).
nono212
In fact I have a Domoticz on Pi ( an old one )
and I have my current Domoticz on Synology Is there a way to export the eq3 data to put it in the new Domoticz ?
Because I had a running eq-3 solution on the Pi but I migrate almost everything on the synology .
Can you help mvzut ?
and for info I type LUA on syno and nothing hapend:
nono212@syno:~$ lua
-sh: lua: command not found
nono212@syno:~$ lua
sakekl
I have domoticz installed on the qnap server and I also had a problem with the lua on the dedicated application. I solved this by installing the ubuntu xenial system in the docker.
Docker from ubuntu has its own IP address and logs in to it using the console. Then it's just like in a normal Linux.
mvzut
Finally I had some time to dive into the new Python plugin system. It was a steep learning curve, since I had no prior Python experience, but I think I succeeded, mostly... So here is my ELV/eQ-3 MAX! Python plugin for Domoticz!
https://github.com/mvzut/maxcube-Domoticz-plugin
I made use of a very well written Cube API by "hackercowbow", so many of the credits go to him.
Please note that the plugin has only been tested on a Raspberry Pi with the latest Beta (although it will probably work on the latest stable as well). You can install it by typing in a terminal:
Then restart Domoticz, and find the newly added plugin under Setup > Hardware.
Activate the plugin by selecting it from the "Type" drop-down menu, fill in the parameters (on-screen explanation is given) and click "Add".
If all goes as intended, it should automatically create all MAX devices for you (using the names it receives from the Cube), update all devices with the given interval, and change thermostat setpoints on your Cube if you change them in Domoticz. Note that you can safely rename devices to anything you want, unlike previous solutions this plugin doesn't need specific names to function.
Who is willing to test it? I'm sure there are still bugs in it that I didn't encounter yet. For testing purposes, you can safely run it next to your existing MAX integration method. If at least a couple of people get it to work without problems, I'll probably create a dedicated topic on this plugin.
Hoping for your feedback!
cd ~/domoticz/plugins
git clone https://github.com/mvzut/maxcube-Domoticz-plugin MaxCubeActivate the plugin by selecting it from the "Type" drop-down menu, fill in the parameters (on-screen explanation is given) and click "Add".
sakekl
I can not make it today, but I will start testing tomorrow. Nice job and respect for you.
