dear forum users,
i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
for as far as i know this should be possible in dzvents but i do not know how to do that.
i hope someone can help me, thanks in advance!
doorbell script
- Domoticz version: 2020.2
doorbell script
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
- waaren
Re: doorbell script
@snellejellep, Should be possible but some questions:snellejellep wrote: ↑Monday 10 September 2018 21:20 i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
- are these standard on/off, -dimlights or rgbw type of lights
- howto "flash" these lights? Simple on/off or something else ?
Re: doorbell script
I use philips hue lights, some are rgb, some just white, i tought about just flashing the white ones and letting the rgb ones flash red, the color change is what makes it difficult i think.waaren wrote:@snellejellep, Should be possible but some questions:snellejellep wrote: ↑Monday 10 September 2018 21:20 i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
Also i wanted to use the data from my motion sensors to let the lights flash only in the rooms people are
But first wanted to start with just the flashing
- HansieNL
Re: doorbell script
Maybe you can take a look at the HUE API. https://www.developers.meethue.com/docu ... ng-started
With a curl command a lot is possible:
curl -H "Accept: application/json" -X PUT --data '{"alert":"select"}' http://<hue-bridge-ip>/api/<hue-username>/lights/4/state
Blah blah blah
- waaren
Re: doorbell script
Maybe this example script will help in what you want to achieve. Another line of approach could be to trigger an IFTTT applet from this dzVents script.snellejellep wrote: ↑Monday 10 September 2018 21:40I use philips hue lights, some are rgb, some just white, i tought about just flashing the white ones and letting the rgb ones flash red, the color change is what makes it difficult i think.waaren wrote:@snellejellep, Should be possible but some questions:snellejellep wrote: ↑Monday 10 September 2018 21:20 i have a wish and i do not know how to realize it, i have a button connected to domoticz which i want to use as a doorbell, when the doorbell is pressed i want some lights to flash, but is there a possibility to store the state of the light, activate a doorbell scene and after the scene restore the state off the lights.
-- doorbell actions
on = { devices = {"Doorbell" } },
logging = { level = domoticz.LOG_DEBUG, -- switch to LOG_INFO when results are OK
marker = "doorbell actions" },
execute = function(dz, trigger)
if trigger.state == "Off" then -- No action needed when doorbell switch back to Off state
return
local rgbwLights = {"Hue lightstrip","Hue Go","Hue rgbw1","Hue etc"} -- table with rgbwlights that need to flash red
local whiteLights = {"lamp1","lamp2","lamp999"} -- table with white lights that need to flash
local function flashRGBWLights()
local redflashDelay = 20 -- delay in seconds
for i = 1,#rgbwLights do -- walk the table from first (1) to last (#rgbwLights)
local loopDevice = dz.devices(rgbwLights[i])
local colorTable = dz.utils.fromJSON(loopDevice.color)
dz.log(loopDevice.name .. " ;state ===>> " .. loopDevice.state,dz.LOG_DEBUG)
loopDevice.setRGB(255,0,0) -- Turn to RED
loopDevice.switchOn()
loopDevice.setRGB(colorTable.r, colorTable.g, colorTable.b).afterSec(redflashDelay)
if loopDevice.state == "Off" then
dz.log("Schedule switchOff for " .. loopDevice.name,dz.LOG_DEBUG)
loopDevice.switchOff().afterSec(redflashDelay)
local function flashWhiteLights()
local whiteflashDelay = 1 -- delay in seconds
for i = 1,#whiteLights do -- walk the table
local loopDevice = dz.devices(whiteLights[i])
local state = loopDevice.state
loopDevice.switchOff().afterSec(whiteflashDelay)
loopDevice.switchOn().afterSec(whiteflashDelay)
flashRGBWLights()
flashWhiteLights()
Re: doorbell script
thank you, it works great!
Re: doorbell script
waaren wrote: ↑Tuesday 11 September 2018 1:02Maybe this example script will help in what you want to achieve. Another line of approach could be to trigger an IFTTT applet from this dzVents script.snellejellep wrote: ↑Monday 10 September 2018 21:40I use philips hue lights, some are rgb, some just white, i tought about just flashing the white ones and letting the rgb ones flash red, the color change is what makes it difficult i think.waaren wrote:
-- doorbell actions return { on = { devices = {"Doorbell" } }, logging = { level = domoticz.LOG_DEBUG, -- switch to LOG_INFO when results are OK marker = "doorbell actions" }, execute = function(dz, trigger) if trigger.state == "Off" then -- No action needed when doorbell switch back to Off state return end local rgbwLights = {"Hue lightstrip","Hue Go","Hue rgbw1","Hue etc"} -- table with rgbwlights that need to flash red local whiteLights = {"lamp1","lamp2","lamp999"} -- table with white lights that need to flash local function flashRGBWLights() local redflashDelay = 20 -- delay in seconds for i = 1,#rgbwLights do -- walk the table from first (1) to last (#rgbwLights) local loopDevice = dz.devices(rgbwLights[i]) local colorTable = dz.utils.fromJSON(loopDevice.color) dz.log(loopDevice.name .. " ;state ===>> " .. loopDevice.state,dz.LOG_DEBUG) loopDevice.setRGB(255,0,0) -- Turn to RED loopDevice.switchOn() loopDevice.setRGB(colorTable.r, colorTable.g, colorTable.b).afterSec(redflashDelay) if loopDevice.state == "Off" then dz.log("Schedule switchOff for " .. loopDevice.name,dz.LOG_DEBUG) loopDevice.switchOff().afterSec(redflashDelay) end end end local function flashWhiteLights() local whiteflashDelay = 1 -- delay in seconds for i = 1,#whiteLights do -- walk the table local loopDevice = dz.devices(whiteLights[i]) local state = loopDevice.state dz.log(loopDevice.name .. " ;state ===>> " .. loopDevice.state,dz.LOG_DEBUG) if loopDevice.state == "Off" then loopDevice.switchOn() loopDevice.switchOff().afterSec(whiteflashDelay) else loopDevice.switchOff() loopDevice.switchOn().afterSec(whiteflashDelay) end end end flashRGBWLights() flashWhiteLights() end }
the script works great but the brightness stays at 100 percent, can it be returned to the preset brightness of the rgb lights
