hi together,
i`m using Domoticz since one year, and i'm verry happy with the System.
Actuel i have a problem to integrade a FALMEC HOOD into Domoticz.
RFLink suppots Falmec Hoods since Rev. 48, but Domotics reports in the Error Log unhandled switch.
Is there any solution to overcome this Error ?
Thanks for support
RFLink: Unhandled switch type: FALMEC
SweetPants
Re: RFLink: Unhandled switch type: FALMEC
That RFLink suports the device does not mean domoticz is. I have looked at the latest source code and do not see any support yet, hence the 'unhandled'
salamonu
thanks, for the quick answer, that's what i already thought.
Do you see any possibility to force the Implementation,
or it this already on the implantation plan ?
SweetPants
I'm not a developer, I only compile from source to get latest Beta support for testing. Maybe one of the dev's will pick this up, but i know they are very busy at the moment making existing code better and more stable and I don;t know if they own such a device to build support for it.salamonu wrote: Thursday 06 September 2018 19:10 thanks, for the quick answer, that's what i already thought.
Edit: There seems to be Falmec support with the RFXcom already
salamonu
Hi SeetPants,
If there is already a implementation for RFXcom, maybe it´s easy an low effort to port this for RFLink ?
Do you know where i can request this issue ?
