Need help : Lua reading log Topic is solved
zicht
Domoticz version: 2023.1+
Post by zicht »
I am trying to read some status value from the log from json
curl http://192.168.xxx.xxx:8080/json.htm?type=command&param=getlog&lastlogtime=0&loglevel=268435455
Response i get :
{ "status" : "ERR" }
If i copy the same url to my browser i get perfecty i json respond with the log entries.
What am i doing wrong ?
Re: Need help : Lua reading log
zicht wrote: Thursday 30 August 2018 21:42 I am trying to read some status value from the log from json
Response i get :
you could try with
curl -s -X GET http://192.168.xxx.xxx:8080/json.htm?type=command&param=getlog&lastlogtime=0&loglevel=268435455"
zicht
Post by zicht »
Hi Waaren,
Thanx !!
Tried it with same result.
Somehow it works in every browser but with curl it reports an error.
Tried also other json commands, those work well in browser and with curl (setting a switch)
Just not the log.
SOLVED :
	commando='curl "http://192.168.xxx.xxx:8080/json.htm?type=command&param=getlog"'
I added the " and it worked, thanks for ehm inspiring me to test a bit more
zicht wrote: Friday 31 August 2018 22:35 SOLVED :
Yes sorry for omitting the first "
curl does not like the ? and & so they need to be escaped by adding a \ before them or put the whole http string between double quotes.
