Motion Light Off after 2 minutes at Nighttime
I'm looking for a script that will turn the hallway light off after no motion for 2 minutes only when its nighttime out.
Searched the forums but didnt really see what I was looking for..
pvm
- Domoticz version: 4.10538
Sorry wrong answer
Re: Motion Light Off after 2 minutes at Nighttime
Ehhh figured it out using smart lua scripts. I think.
snellejellep
- Domoticz version: 2020.2
can you give some examples for others browsing the forum with a similar question?
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
- waaren
From the dzVents wiki:dbmet wrote: Wednesday 29 August 2018 2:45 I'm looking for a script that will turn the hallway light off after no motion for 2 minutes only when its nighttime out.
"A device trigger can have a time-rule constraint: on = { devices = { ['myDevice'] = 'at nighttime' } }. This only triggers the script when myDevice was changed and the time is after sunset and before sunrise."
so if you use this as the on = section and something like
if trigger.state == "On" then
domoticz.devices("hallway light").switchOn().checkFirst()
domoticz.devices("hallway light").switchOff()
endDebian buster, bullseye on RPI-4, Intel NUC.
- waaren
waaren wrote: Friday 31 August 2018 19:37From the dzVents wiki:dbmet wrote: Wednesday 29 August 2018 2:45 I'm looking for a script that will turn the hallway light off after no motion for 2 minutes only when its nighttime out.
so if you use this as the on = section and something likein the execute = section (assuming the motion detector switches to "Off" after two minutes.) If that is not the case the script becomes a bit more complicated with either a uservar or openURL .Code: Select all
if trigger.state == "On" then domoticz.devices("hallway light").switchOn().checkFirst() else domoticz.devices("hallway light").switchOff() end
Boredcat
- Domoticz version: 3.9639
@Warren : That solution will not work.
He wanted to switch off a light when there is no motoin (so no device trigger).
A solution that I use is to use a timed event (my PIR check runs every minute). So a solution might be.
No sure if the time-rule works with a timer. (might try this)
timer = {'[Every minute ', 'at nighttime' ]}
active = true,
timer = {'Every minute '}
execute = function(domoticz)
if ( ( domoticz.devices('PIR Hallway').lastUpdate.minutesAgo => 2 ) and (domoticz.devices('Hallway').state == 'On' and domoticz.time.isNightTime)) then
domoticz.devices('Hallway').switchOff()
RFXCom(E) - Yeelight Lights - KaKu / Alexa HA Bridge
Windows 2012 / Windows 2012R2 / Xpenology/ Pi 3 / Milight / Home build ESP8266 / Sonoff
- waaren
As always .. It dependsBoredcat wrote: Saturday 15 September 2018 10:08 @waaren : That solution will not work.
My motion detectors also trigger an event after the set time folowing a motiondetection passed.
DomoRies
For me this works perfectly. Maybe u can use it. This way the lights stay on for 1 minute after motion sensor detected motion.
Verstuurd vanaf mijn Moto G (5) Plus met Tapatalk
return { on = { devices = {motion sensor} },
local light = domoticz.devices(light u want to switch)
if ((not light.active and device.active) or (light.active and device.active)) then
light.switchOn()
elseif (not device.active) then light.switchOff().checkFirst().afterMin(1) end
end }
