Battery level indicator
fwehrle
Post by fwehrle »
I notice that domoticz store battery level of devices and that we can set battery level in dummy device.
It's 2 nice features but where can we check/verify or simply view the battery level?
Is that a specific color for devices bricks (like when there goes red when it was not seen for a long time) ?
It would be nice to check battery level, in script and/or in web UI.
Thank you
Flapsie
Domoticz version: V3.5877
Re: Battery level indicator
Post by Flapsie »
I think the device brick turns yellow when the battery level is low (you will also see "low" in the device list), but it won't show a percentage. Would be nice though...
Domoticz V 3.5877 on Raspberry Pi B (wheezy)
RFXtrx433 USB, FW 1015 - type 1
Various Oregon Scientific sensors & 2 Fritz!DECT 200 switches
fwehrle
Post by fwehrle »
Maybe on real device. But on dummy, when I set battery level go 0, it set it go low in devices list, but the brick color don't change. So in standard uses, I never saw battery is low. :(
robertDomoticz
Post by robertDomoticz »
Hello, I modified script www/app/TemperatureController.js for showing battery level.
It's not very clean solution, but I missed this feature too (Domoticz v2.2112) .
You can try it.
script in www/app/
(30.36 KiB) Downloaded 256 times
screenshot
screenshot
pepeEL
Post by pepeEL »
+1
It looks very very good
Send new Pull Request pm GitHub to Domoticz with this added...
gizmocuz
Post by gizmocuz »
You can see the battery level in the devices tab
When the battery is to low, the sensor will turn yellow
most sensors (433Mhz) have only good/low, and low can take 2 months
So when you see a yellow sensor, just goto the devices tab
