- DewGew
- Domoticz version: V4.10618
Re: machinon theme - (work in progress)
Looks great!EdddieN wrote: Monday 27 August 2018 21:08 How is this for updated dark screen? and also updated the about screen to match a bit with the rest:
Prutsium
Might be interesting to look at the Dark theme from TasmoAdmin this has a nice Dark modus.
(More info TasmoAdmin @ https://github.com/reloxx13/TasmoAdmin/wiki )
Hobbybob
Hey Eddie, not a question or anything, but I just want to say that I think this is by far the most beautifull theme out there. I've always said the theme did not matter, as long as the system is functional since I prefer to set it up in a way that you don't need to do too much with it, but I am slowly convincing myself to install this one anyway. It is just too elegant to ignore it any longer
Absolutely stunning work!
Now I just need to find the time to read up on installation-proces and get it done.
- EdddieN
- Domoticz version: 4.9700
Thank you! I'm just a guy with ideas, the real hard work has been done by @DewGew , @landaisbenj and the Domoticz community. Without them, it would be no theme to install.Hobbybob wrote: Tuesday 28 August 2018 22:25 Hey Eddie, not a question or anything, but I just want to say that I think this is by far the most beautifull theme out there. I've always said the theme did not matter, as long as the system is functional since I prefer to set it up in a way that you don't need to do too much with it, but I am slowly convincing myself to install this one anyway. It is just too elegant to ignore it any longer
In terms of installation, pretty easy:
1 .- Click on Clone or Donwload here: https://github.com/EdddieN/machinon-domoticz_theme
2.- Download the Zip file to you computer and copy its contents (unzip) inside the domoticz/www/styles/ folder. Make sure you copy the full machinon folder, not the files directly only.
3.- Go to domotiz/www/templates and copy the files inside the templates folder you downloaded there.
That is it, you should now see it under your Theme settings. Just worth saying I only know how to do this on Raspberry Pi, no idea about other OS.
11101101 - www.machinon.com
Yes I did (now) and settings works now..
only still no larger blocks, so it does not look so good: (already removed cache and tried with another browser)
DewGew wrote: Monday 27 August 2018 15:30Did you copy the Settings.html to www/templates/ ?treshed wrote: Monday 27 August 2018 15:18 I was able to go back to standard theme by renaming the machinon directory in domoticz/www/styles. After a restart of domoticz it comes up with the standard theme.ayasystems wrote: Monday 27 August 2018 14:56
I have the same problem. I can not back to standard theme.
- EdddieN
Definitely a cache issue... have you reset the theme under theme settings?
Also try to clear chrome cache like this chrome://appcache-internals/#
Hobbybob
That worked fantastic. Normall, I use Firefox, and cache is a bit of a pain there, so I tried Chrome and that showed it immediatly, because it coud not have a cache at all.EdddieN wrote: Tuesday 28 August 2018 22:47 Thank you! I'm just a guy with ideas, the real hard work has been done by @DewGew , @landaisbenj and the Domoticz community. Without them, it would be no theme to install.
I do have one thing that I noticed however. I have Weather Underground for temperatures, and it creates a combined device for temperature, barometer, humidity and so on. When I go to "temperature", it is showing the blue figures through the name of the device. Not a big problem, but still...
- EdddieN
yes, we are working on a solution, it has been reported on github: https://github.com/EdddieN/machinon-dom ... /issues/27
More likely an automatic scrolling will be placed there
Hobbybob
Ah, perfect! Like I said: not a really big issue for me. But I wanted to report it anyway. I didn't check the Github issue-list. I'll (try to) follow that!EdddieN wrote: Wednesday 29 August 2018 17:50 yes, we are working on a solution, it has been reported on github: https://github.com/EdddieN/machinon-dom ... /issues/27
- EdddieN
No worries, all feedback is good!
SweetPants
How do I select this dark theme? I like it very much
- EdddieN
Settings -> theme
At the moment is just an inverted colors, work is in progress to convert it into what you see on this thread
- DewGew
Is there a reason why temeperatures, weather and utillity names has bigger font size (20px) than dashboard and devices (16px). I think it looks better if the names has same font size.EdddieN wrote: Wednesday 29 August 2018 17:50 yes, we are working on a solution, it has been reported on github: https://github.com/EdddieN/machinon-dom ... /issues/27
SweetPants
I agree tooDewGew wrote: Thursday 30 August 2018 7:49Is there a reason why temeperatures, weather and utillity names has bigger font size (20px) than dashboard and devices (16px). I think it looks better if the names has same font size.EdddieN wrote: Wednesday 29 August 2018 17:50 yes, we are working on a solution, it has been reported on github: https://github.com/EdddieN/machinon-dom ... /issues/27
- DewGew
Ok, I think we better change that.. I made pull request.
- EdddieN
Please tell me to stop picking things anytime, ok? Otherwise I will just keep trying to make it nicer and nicer
These issues, am I the only one that sees them?
michass
- Domoticz version: 4.10064
Is there posibility to change capital letters to small?
Units in this theme looks unprofessional
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
Heating: eq-3 MAX!
Cam: Foscam C1
snuiter
I just love this theme, but when using it on my mobile or tablet I am not able to select theme in the Settings menu. So I am not able to find any way to alter my settings. Since this theme uses settings per device I am missing my "last update" on dashboard"
Any suggestions how I can solve this or is this a bug?
Thx
Thx
