Can this be simplified?
DanM
Post by DanM »
I have the following script I'm hoping to simplify. I'm defining a table of devices at the start.. then using a standard dzvents device script. Is there any way to not have to repeat the devices in the device section of the script (so to read them from devicesToCheck object).
Thanks.
local devicesToCheck = {
	{ ['name'] = 'Conservatory Motion Sensor', ['true_prob'] = 0.7,['false_prob'] = 0.7 },
	{ ['name'] = 'Kitchen Motion Sensor', ['true_prob'] = 0.7,['false_prob'] = 0.7 },
	{ ['name'] = 'Bedroom Motion Sensor', ['true_prob'] = 0.7,['false_prob'] = 0.7 },
	{ ['name'] = 'Living Room Motion Sensor (Main)', ['true_prob'] = 0.7,['false_prob'] = 0.7 }
local prior = 0.5
		devices = {
		print('stuff here')
emme
Domoticz version: latest
Re: Can this be simplified?
Post by emme »
I do use 2 arrays: the first with the names, the second with the parameters....
this way I can use the first array as trigger
so it would be something like:
local devNames = {
local prior = 0.5
		devices = {
			devNames
		print('stuff here')
just ensure the sequence is the same....
you could also define a function by whitch you gather the devices names into a new table to return to the device trigger... but the solution I posted is more easy :P
"We always done this way"
DanM wrote: Tuesday 28 August 2018 20:51 I have the following script I'm hoping to simplify. I'm defining a table of devices at the start.. then using a standard dzvents device script. Is there any way to not have to repeat the devices in the device section of the script (so to read them from devicesToCheck object).
Thanks.
local prior = 0.5
		devices = {
		print('stuff here')
Would the use of a wildcard string simplify it enough ?
on = { devices = { '*Motion Sensor*' }},
