lost wrote:jannl wrote:You need to start domoticz as root. Try 'sudo ./domoticz.sh'. Or just reboot the pi
In my understanding, he's just willing to run Domoticz as a non root user. As there may only be the http(s) usual ports (80/443, thus < 1024) binding needing root rights under Domoticz, he changed them for some figures over 1024.
But this doesn't work: Still binds https to 443 whatever figures in the command line... and complains for root permissions!
Never tried this as with non standard https there is many networks (open-wifi etc) where they will be filtered out, but for security reasons running Domoticz as a non root user makes sense as the executable does not seems to drop rights after ports bindings.
YES! You said it perfectly.
a) trying to run as a non-root user as recommended (generally and even in the domoticz installation guide)
b)non-root won't easily open lower ports (or at all without installing iptables -> no experience with that either + adding more complexity)
...simplest solution is going high port
b) won't start with that port no matter what I specify in domoticz.sh in etc/init.d/domoticz.sh and just in case I missed something even in home/pi/domoticz/domoticz.sh
c) when I run sudo ./domoticz it starts with 443, but that's what I don't want .. only proves that it's installed correctly and can be run at all
To recap... I proceed as such:
1. Fresh install of Debian on my Acer Netbook, update/upgrade, installing domoticz (with openzwave suport) -no a single error/warning
All files are owned by pi..
2. Before even trying to set it for auto start:
I just run ./domoticz and get the error regarding port numbers. With sudo it works(obviously).
When running as pi and changing the port (in the only version of domoticz.sh existing at this time -> no etc/init.d copy yet)
and even after going the init.d start-up route, no matter what I change the port to in either file and it register and give me the low port error.
It is not commented out or anything, totally stock, checked, reinstalled...
If I type ./domoticz -sslwww 8090 ..IT WORKS!
After following "Starting Domoticz automatically when the system boots Init.d Method"
and changing the port in etc/init.d it starts with any port specified but Top still shows as process run by root (chuid in domoticz.sh is ignored?)
Sorry for such a chunky post...I guess I'm trying to give you as much info I can think of...
So..my question after all this then is...Is there any way to run this as pi(non-root user)? As that seems to be the source of all the problems...
Thank you again for all your wisdom gents!
