Option T0/blinds is missing when adding manual switch in beta [SOLVED!]
melgi
Post by melgi »
Thanx to JonathanLondon we solved this issue! Check out his step by step tutorial in this post: viewtopic.php?f=44&t=24622&p=190270#p190207.
Guys,
I'm trying to manually add a couple of switches for my BOFU motor blinds (see this post http://www.domoticz.com/forum/viewtopic ... 44&t=24622). However in Domoticz, I miss the option T0/blinds when selecting the type. I only have T5 to T13. I already added some other blinds working with Brel motors under the T6 blinds option (they work perfectly).
I'm running the following version numbers:
Domoticz: beta v4.9948
RFXcom firmware: Version: Ext2/1025
In the RFXcom menu I got alle the different protocols ticked.
EDIT: I read in the RFXcom manual that when T0 is selected, all other protocols don't work/should be deselected. Even if I do this, it doesn't change the options in the menu. Still T0 till T4 are missing.
Can someone who's running the stable version check if the T0/blinds option is there? In that case I'd take the effort to go back to the stable version.
Regards,
melgi
i000
Re: Option T0/blinds is missing when adding manual switch in beta
Post by i000 »
I have the same issue with ok motors. I can’t use it.
melgi
Post by melgi »
UPDATE: I installed the Domoticz stable version on my PC and tried to create the switch manually. Still the only types I can select are T5 till T13. So now I can switch my blinds on the first floor (Brel motors -> T6), but I can't switch my blinds on ground floor and 2nd floor (Bofu motors -> T0). I tried T12 and T13 as they have the same "hexadecimal" code, but nothing works. Anybody has any idea how I can get the blinds with the Bofu motors working?
