Logical order to use backup image and sd card size
najtram
Domoticz version: v4.9700
Post by najtram »
I know this is more a Raspberry question, but I want to post it on this forum because you understand my wish to keep the current installation and collected data.
My question: How big is a IMG Win32image backup of a 16GB SDCard containing a restored 8GB image with Win32image, without expansion?
Some explaination:
It looks like my SD card is end-of life. So I want to replace it with a new one. I'm using Domoticz for 2 years now, but now I'm stucked with the situation that the new card I bought is smaller than my img. (8GB is not 8GB).
So I want to buy a extra, new, 16GB image to solve this issue. With win32image I will be able to put back the 8GB img to the 16GB. From this new 16GB SD card I want to make backup's with win32image. How big wil this last backup be? (so without any expansion). If this new IMG is 16GB I can expect the same issue after two years ending up to buy a 32GB, 64GB etc.
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
freijn
Domoticz version: Stable
Re: Logical order to use backup image and sd card size
Post by freijn »
I believe it will be 16 Gb !
However you can zip the image later on and shrink it again.
HansieNL
Post by HansieNL »
You can use the option Read Only Allocated Partitions (Gealloceerde Partities Alleen Lezen).
Option to read only to the end of the defined partition(s). Ex: Write a 2G image to a 32G device, reading it to a new file will only read to the end of the defined partition (2G).
Blah blah blah
freijn
Post by freijn »
Hi Hans
Where can you set this as I do not see it :-(
THanks
Frank
HansieNL
Post by HansieNL »
Are we talking about the same program?
https://sourceforge.net/projects/win32diskimager/
I pack the created image with WinRAR to zip and then I can later write image back with Etcher without unpacking first.
Blah blah blah
Andyf66
Post by Andyf66 »
I use raspibackup running via cron job on my Pi. It will shrink the image down to minimum size and can expand it again on restore to fit whichever size device.
https://www.linux-tips-and-tricks.de/en/backup
Originally I was writing backups to a second usb stick, but now I save them remotely on my NAS via an NFS mount.
najtram
Post by najtram »
HansieNL wrote: Thursday 16 August 2018 22:06 You can use the option Read Only Allocated Partitions (Gealloceerde Partities Alleen Lezen).
This looks exactly as the option I want. I didn't had this option because I used an older version of W32DI. It is new sinds last years version 1.0!
Thanks HansieNL! This also answers question of Freijn...
ZigBee → ConBee II
LAN → Enphase Envoy
heggink
Domoticz version: 12451
Post by heggink »
why not just insert the new SD as well and dd from old to new?
DASHTICZ 🙃
P1 meter & solar panel
najtram
Post by najtram »
heggink wrote: Friday 17 August 2018 10:41 why not just insert the new SD as well and dd from old to new?
- DD on MacBook is annoying slow!
- I've a MacBook with 1 usb-C slot so I'm stucked with my Windows laptop. So no DD.
- My optimal result is a smaller (8GB) image than the (16GB) SD card, so I can buy each (16GB) SD card to avoid the "8GB is not 8GB" issue.
ZigBee → ConBee II
LAN → Enphase Envoy
najtram
Post by najtram »
HansieNL wrote: Friday 17 August 2018 0:47 I pack the created image with WinRAR to zip and then I can later write image back with Etcher without unpacking first.
Is this Etcher program in combination with the smaller ZIP also able to avoid the 8GB is not 8GB issue.
ZigBee → ConBee II
LAN → Enphase Envoy
HansieNL
Post by HansieNL »
najtram wrote: Saturday 18 August 2018 8:28 Is this Etcher program in combination with the smaller ZIP also able to avoid the 8GB is not 8GB issue.
Yes. I backup my Domoticz server (on a 32GB mSATA SSD) which partitions are total 12GB in size to an image. If I write the zipped image back I still have 12GB. The rest on the disk is unused space.
Blah blah blah
