I have fibaro FGBS001 "binary sensor", equipped with 3 temperature sensors that sit in my swimming pool. They used to work fine up to about two weeks ago. All of a sudden, the sensor disappeared completely from the air. So I disassembled the sensor, reset it and it worked fine again - for about half an hour, that is. The sensor than disconnected again.
I decided to exclude it from the network, reset it and re-include it. For some weird reason, the newly included setup shows the binary inputs only, no temperature sensors. What's up with that? Is there any known issue with the temperature sensors on this thing? There is* data communication between CPU and sensors, I guess it is an advertisement issue of some sort.
Please note the configuration for the sensors stems from a previous version of domoticz. The new configuration is made through v4.9700 (running on a raspberry pi), as far as I know that should be the latest and greatest stable version, right?
Fibaro FGBS001 temperature sensors disappeared
- gizmocuz
Re: Fibaro FGBS001 temperature sensors disappeared
is there a way you can verify that the temp sensors actually still work ? Maybe there are burned ?
You could enable the ozw logging and disable/enable the ozw hardware, then look into the log if you see temp values changing
(then disable the log asap as it will consume a lot of data), en disable/enable the hardware again
DomoJev
Disassembled the sensor today (it partly sits in the pool so I needed some time to get it out). It put my digital scope / analyzer on it and there was no communication to/fro the sensors. Disassembled them one by one, removing them from the bus. Nothing. Got out the microscope, the PCB looks horrible. Prolly got wet during the last year or so and some of the components are covered in cauliflower. Not good. Conclusion: hardware failure.
Anyway, I also checked ~/Config/fibaro/fgbs001.xml. There's nothing in there that points to the temperature endpoints. Shouldn't it?
- gizmocuz
No, from what i read in the manual, when you have attached a temp sensor to the switch, you need to exclude it, and include it in again, and the temp sensor should be found
