Issue with Blockly script Topic is solved
Prutsium
Post by Prutsium »
Hi there,
I want to switch the IR filter from my camera with a Blockly based on Sunset and Sunrise.
Made a small script and activating this script manually works good so i assume somehow the Blockly is something wrong.
This should call 1 of the 2 scripts irOn or irOff and as said when i run these scripts manually no problem but Blockly doesn't want to work somehow.
Could anybody guide me what i do wrong?
blauwebuis
Domoticz version: current
Re: Issue with Blockly script
Post by blauwebuis »
Search for problem with Blockly's IF statement on the board. It doesn't work properly.
StanHD
Post by StanHD »
The "after sunset and before sunrise" should be:- "after sunset OR before sunrise".
This is due to the midnight (00:00) threshold that resets the day.
I have many blocklys with multiple "if" and "else if" statements all working correctly once you understand how they work.
Python:- Broadlink RM2, Sonos
Prutsium
Post by Prutsium »
StanHD wrote: Tuesday 14 August 2018 23:15 The "after sunset and before sunrise" should be:- "after sunset OR before sunrise".
Thanks will try that one.
Prutsium
Post by Prutsium »
Confirmed that it works. Thanks!!!
StanHD
Post by StanHD »
Good news, glad it works :)
