Hi there,
I am having a problem forgetting that my coffee maker machine is on and I want to send notifications every 10 minutes while the 'Coffee' switch is on.
My Coffee switch has a timer that goes on at 6:00 am and off at 8:00 am. I want to receive the notifications only if I turn the coffee on at any time other than 6:00 to 8:00.
I have been trying to adapt scripts but I am not successful. Perhaps my request could be useful for anyone else who wants to get notifications on a switch status outside of the standard (or timer) operating time.
Thank you,
Alley Cat
Notification timer every 10min
- waaren
Re: Notification timer every 10min
Something like this dzVents script should workAlleyCat wrote: Wednesday 15 August 2018 18:04 ..
I am having a problem forgetting that my coffee maker machine is on and I want to send notifications every 10 minutes while the 'Coffee' switch is on. My Coffee switch has a timer that goes on at 6:00 am and off at 8:00 am. I want to receive the notifications only if I turn the coffee on at any time other than 6:00 to 8:00.
-- NotifyOutsidePeriod.lua
myCoffeeVar = "coffeeSwitchMinutes" -- This uservar must be created as type integer with initial value 0
myCoffeeSwitch = "coffeeSwitch" -- Name within quotes or index without quotes
on = { variables = {myCoffeeVar}, -- type integer
devices = {myCoffeeSwitch}},
execute = function(dz)
local coffeeVar = dz.variables(myCoffeeVar)
local coffeeSwitch = dz.devices(myCoffeeSwitch)
if coffeeSwitch.state == "Off" then
coffeeVar.set(0).silent()
coffeeVar.set(coffeeVar.value + 10).afterMin(10)
if not( dz.time.matchesRule('at 06:00-08:00') ) and coffeeVar.value > 0 then
local message = "Coffee machine still on after " .. coffeeVar.value .. " minutes."
dz.notify(message)
}Debian buster, bullseye on RPI-4, Intel NUC.
AlleyCat
Fantastic. Thank you for an amazing script.
How can I improve the script to set the exception's base on the Coffee's timer value? Instead of hardcode matchesRule('at 06:00-08:00') to use the switch's Timer "on" values?
Thanks,
AlleyCat
Thanks,
AlleyCat
- waaren
There are at least two methods to achieve that. The easy way is to add the timerstring in the description field of the switch (6:00-8:00) and use the modified script below.AlleyCat wrote: Thursday 16 August 2018 13:03 How can I improve the script to set the exception's base on the Coffee's timer value? Instead of hardcode matchesRule('at 06:00-08:00') to use the switch's Timer "on" values?
-- NotifyOutsidePerdiod.lua
if not( dz.time.matchesRule("at " .. coffeeSwitch.description) ) and coffeeVar.value > 0 then
dz.notify(message)
- waaren
and for the complicated way....AlleyCat wrote: Thursday 16 August 2018 13:03 How can I improve the script to set the exception's base on the Coffee's timer value? Instead of hardcode matchesRule('at 06:00-08:00') to use the switch's Timer "on" values?
-- This script will only works OK if one timer is set for "On" and 1 timer is set for "Off". Both of type "On time"
myCallback = "coffeeTimerResponse"
on = { variables = { myCoffeeVar }, -- type integer
devices = { myCoffeeSwitch },
httpResponses = { myCallback }}, -- Trigger the handle Json part
logging = { level = domoticz.LOG_DEBUG,
marker = "NotifyOutsidePeriod" },
data = { startTime = { initial = "6:00" },
endTime = { initial = "8:00" },
state = { initial = "Off" }},
execute = function(dz,triggerObject)
local function getTimers(device)
local urlString = dz.settings['Domoticz url'] .. "/json.htm?idx=" .. device.idx .. "&type=timers"
dz.openURL({ url = urlString,
method = "GET",
callback = myCallback
local function handleState()
dz.data.state = "Off"
if not( dz.time.matchesRule("at " .. dz.data.startTime .. "-" .. dz.data.endTime) ) and coffeeVar.value > 0 then
dz.notify(message)
dz.log(message,dz.LOG_DEBUG)
local function handleResponse()
rt = triggerObject.json -- dump json to lua table
for i = 1, #rt.result do -- loop over result
if rt.result[i].Type == 2 and rt.result[i].Cmd == 0 then -- Type 2 is "On Time", Cmd 0 is "On"
dz.data.startTime = rt.result[i].Time
elseif rt.result[i].Type == 2 and rt.result[i].Cmd == 1 then -- Type 2 is "On Time", Cmd 1 is "Off"
dz.data.endTime = rt.result[i].Time
if triggerObject.isHTTPResponse then
if triggerObject.ok then -- Response from domoticz OK
handleResponse()
handleState()
dz.log("Problem with response from domoticz",dz.LOG_ERROR)
elseif coffeeSwitch.state == "On" and dz.data.state == "Off" then
dz.data.state = "On"
getTimers(coffeeSwitch)
handleState()
AlleyCat
Thanks for the scripts. I will test the revised script later tonight.
In the case of my Coffee switch, there is only one (1) timer between 06:00 "On" and 09:30 "Off".
Would the "complex" script know how to handle multiple Timers?
I want to adapt this script to my Parental Control switches, which have multiple Timers. Here is the scenario:
My kid's internet access and privileges are controlled by a Dummy switch that sends ssh commands to the Router's iptables firewall to ACCEPT or REJECT access based on MAC address. The details of the scripts and switches are beyond the scope of this thread. (Nevertheless, I plan to share soon because I know I have a solution for a very painful problem with controlling internet access for kids).
I am managing the Internet privileges with multiple Timers to when the internet goes on or off. For example, the kid is allowed to play the XBOX between 10:00-11:00 and 16:00-17:00.
Now I have multiple Timers going on/off at two different times. On Saturdays my kid has Karate leasons, so the XBOX switch is on only in the afternoon. So, on Saturday the Timer is different than from the rest of the week. I think I made the point and explained the scenarion to why I want to handle multiple Timers.
Now, when my kid cut the lawn and earns more internet time. The problem is I tend to forget that the XBOX in on, and he plays for hours. LOL
If the script would handle multiple Times I will be able to receive notifications that the XBOX is on outside of the Timers operating cycles, and this will make me a better father. LOL
Thanks,
Alley Cat
Thanks,
Alley Cat
- waaren
the "complex" script cannot handle multiple timers in its current form. The call to domoticz do get all timers so it is possible to make the script work for multiple timers but that is beyond the scope of my examples. One of the challenges there is that there is no such thing as a defined set of On/Off timers. It will be quite cumbersome to code On/Off sets more so if they are distinguishing special days of the week.AlleyCat wrote: Thursday 16 August 2018 18:30 ...
...when my kid cut the lawn and earns more internet time. The problem is I tend to forget that the XBOX in on, and he plays for hours. LOL
What might be a far easier way of addressing your requirement is to let dzVents switch off your virtual devices one hour (or another defined timespan) after they are switched on or alerting you to do that manually.
