[Solved] Stepp down light, before turning off ?
Droll
Domoticz version: 2024.7
Post by Droll »
By searching this forum, using som bits and pices, a bit cut/paste :) I usually ends up with what I want, or close ( AND learning as a bonus )...
This time it's close, just want's a little bit more... found the bases for this script here on the forum, just made some small adjustments ...
BUT ...
Any easy way to replace the "OFF" command by something like :
commandArray['Bad']='Set Level 5%' for 30 sek
THEN
commandArray['Bad']='OFF '
Just to get a warning ;-) before it gets dark ( Light triggered by movement )
Arne Kjetil
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
-- Set length of time light should be on for in seconds
timeon = 140
-- Calculate time since time PIR was last activated
difference = timedifference(otherdevices_lastupdate['Bevegelse_Bad'])
-- If the time since last activation was within 1 minute of time for light to stay on
if (difference > timeon and difference < (timeon + 61)) then
   tempdiff = tostring(difference)
   tempmessage = "Switch1 Light Off - after at least " .. (timeon+1) .. "secs up - actually - " .. tempdiff .. "seconds"
   print(tempmessage)
   -- Switch off Switch1
   commandArray['Bad'] = 'Off'
print('testing domoticz log')
Droll
Re: Stepp down light, before turning off ?
Post by Droll »
Solution ....
Found what I was looking for, found in a post from alanlsmith :)
t1 = os.time()
return difference
commandArray = {} --Round to a set number of decimal places
function round(what, precision)
if (what) then
return math.floor(what*math.pow(10,precision)+0.5) / math.pow(10,precision)
return math.floor(val+0.5)
local light = 'Bad' --For fading
local lightstepsfull = 10 --100% in 5% steps --These need to be adjusted top suit the--
local lightstep = 5 --number of steps to suit your light/dimmer--
local timestep = 10 -- Time in seconds between each light level step--
local delay = 0 --Delay, (if any) before start of dimming/fading up--
lysbaddag = tonumber(uservariables['lysbaddag'])
lysbadnatt = tonumber(uservariables['lysbadnatt'])
if (timeofday['Daytime']) then lightlevel = lysbaddag
elseif (timeofday['Nighttime']) then lightlevel = lysbadnatt
local lightstepsnow = round( lightlevel / lightstep , 0 )
local lightsteps = lightstepsfull - lightstepsnow
timeon = 61 -- Set length of time light should be on for in seconds
diff1 = timedifference(otherdevices_lastupdate['Bevegelse_Bad'])
diff2 = timedifference(otherdevices_lastupdate['DorBad'])
if (diff1 < diff2) then --Using 2 devices to trigger the light, door switch and movmen sensor
difference = diff1 else difference = diff2 --Just need to know witch one triggered last...
tempmessage = "Bad av, etter minst " .. (timeon+1) .. "secs up - actually - " .. tempdiff .. "seconds"
print(tempmessage)
for i = 1,lightstepsnow do -- Dimming down the light in steps, need a warning before the lights goes dark ...
lightlevel = lightlevel - lightstep
delay = delay + timestep
commandArray[#commandArray+1] = {[light] = 'Set Level ' ..lightlevel.. ' AFTER ' ..delay}
Print('Slar av lys bad')
