P1 Meter is not collecting data anymore
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I'd the P1 meter (electricity and gas) working, but suddenly it has stopped today at approx 13:05.
There is no new data coming in.
I've also a Toon in th elivingroom, but the same problem here.
What can here be the problem ?
SweetPants
Re: P1 Meter is not collecting data anymore
Post by SweetPants »
Does the log tell you anything? Maybe something with your smart meter?
freijn
Domoticz version: Stable
Post by freijn »
Try to reset the connection?
if via USB, take the usb off and insert it again ?
is your P1 still moving ? Do you see the readings change?
madpatrick
It has to do something with my Toon.
I've a smartmeter and this is connected to my Toon.
My Toon is also repsonding very slow on commands.
I've reset my Toon, wifi, remade the connections, reset my smartmeter.
gordonb3
Domoticz version: Custom
Post by gordonb3 »
<sigh>
It would help a lot if people would start naming the actual hardware interface they are using.
madpatrick
------ UPDATE ------
Everything is working again.
I did not change anything, but somehow every is back online.
I think my Toon was the problem.
