Hi,pwhooftman wrote: ↑Thursday 15 June 2017 17:34 Nice
I grab part of that website to show on my frontpage:
Can you tell me how to build this page?
How do you setup this notification?dutchdevil83 wrote: ↑Wednesday 05 July 2017 20:45 For sending a notification one day before the actual pickup day (for example paper day is wednesday but waste day is friday here) i use this code for the notication:
--Notification if tonumber(os.date("%d")) + 1 == tonumber(string.match(tmp, "0*(%d+)")) then commandArray['SendNotification']='Afvalwijzer#'..tmp end
In Domoticz Setup --> Settings --> Notification.DickN wrote: ↑Sunday 15 July 2018 16:34How do you setup this notification?dutchdevil83 wrote: ↑Wednesday 05 July 2017 20:45 For sending a notification one day before the actual pickup day (for example paper day is wednesday but waste day is friday here) i use this code for the notication:
-- afvalWijzer module
-- curl in os required!!
-- create dummy text device from dummy hardware with the name defined for: myAfvalDevice
-- Check the timing when to get a notification for each Afvaltype in the afvaltype_cfg table
-- based on script by zicht @ http://www.domoticz.com/forum/viewtopic.php?t=17963
-- based on script by nf999 @ http://www.domoticz.com/forum/viewtopic.php?f=61&t=17963&p=174908#p169637
local myAfvalDevice='Container'
local area='Weidevenne'
local NotificationEmailAdress = "[email protected]"
-- Define the Notification Title and body text. there are 3 variables you can include:
-- @DAG@ = Will be replaced by (vandaag/morgen/over x dagen)
-- @AFVALTYPE@ = Will be replaced by the AfvalType found on the internet
-- @AFVALTEXT@ = Will be replaced by the content of the text field for the specific AfvalType
-- @AFVALDATE@ = Will be replaced by the pickup date found on the internet
local notificationtitle = '@DAG@ de @AFVALTEXT@ aan de weg zetten!'
local notificationtext = '@DAG@ wordt de "@AFVALTEXT@" opgehaald!'
-- Switch on Debugging in case of issues => set to true/false=======
local debug = false -- get debug info in domoticz console/log
-- define a line for each afvaltype_cfg retuned by the webrequest:
-- hour & min ==> the time the check needs to be performed and notification send when daysbefore is true
-- daysbefore ==> 0 means that the notification is send the day of the planned garbage collection
-- daysbefore ==> X means that the notification is send X day(s) before the day of the planned garbage collection
-- text ==> define the text for the notification.
local afvaltype_cfg = {
["Rest"] ={hour=19,min=22,daysbefore=1,text="Grijze Container met Restafval"},
["GFT"] ={hour=19,min=22,daysbefore=1,text="Groene Container met Tuinfval"},
["Papier"] ={hour=12,min=00,daysbefore=0,text="Blauwe Container met Oud papier"}}
--==== end of config ======================================================================================================
-- General conversion tables
local MON_e_n={January="januari", February="februari", March="maart", April="april", May="mei", June="juni", July="juli", August="augustus", September="september", October="oktober", November="november", December="december"}
local WDAY_e_n={Sunday="zondag", Monday="maandag", Tuesday="dinsdag", Wednesday="woensdag", Thursday="donderdag", Friday="vrijdag", Saturday="zaterdag"}
local MON={januari=1,februari=2,maart=3,april=4,mei=5,juni=6,juli=7,augustus=8,september=9,oktober=10,november=11,december=12}
-- round
function Round(num, idp)
return tonumber(string.format("%." ..(idp or 0).. "f", num))
-- debug print
function dprint(text)
if debug then print("@AFW:"..text) end
-- run curl and capture output
function os.capture(cmd, rep) -- execute command to get site
-- rep is nr of repeats if result is empty
local r = rep or 1
local s = ""
while ( s == "" and r > 0) do
r = r-1
local f = assert(io.popen(cmd, 'r'))
s = assert(f:read('*a'))
f:close()
if ( rep - r > 1 ) then
print("os.capture needed more than 1 call: " .. rep-r)
return s
-- get days between today and provided date
function getdaysdiff(i_afvaltype_date)
local curTime = os.time{day=timenow.day,month=timenow.month,year=timenow.year}
-- Calculate the daysdifference between found date and Now and send notification is required
local afvalyear =timenow.year
local afvalday =timenow.day
local afvalmonth=timenow.month
local s_afvalmonth="vandaag"
-- check if date in variable i_afvaltype_date contains "vandaag" in stead of a valid date -> use today's date
if i_afvaltype_date == "vandaag" then
-- use the set todays info
afvalday,s_afvalmonth=i_afvaltype_date:match("%a+ (%d+) (%a+)")
if (afvalday == nil or s_afvalmonth == nil) then
print ('! afvalWijzer: No valid date found in i_afvaltype_date: ' .. i_afvaltype_date)
return
afvalmonth = MON[s_afvalmonth]
dprint("...gerd-> afvalyear:"..tostring(afvalyear).." s_afvalmonth:"..tostring(s_afvalmonth).." afvalmonth:"..tostring(afvalmonth).." afvalday:"..tostring(afvalday))
local afvalTime = os.time{day=afvalday,month=afvalmonth,year=afvalyear}
-- return number of days diff
return Round(os.difftime(afvalTime, curTime)/86400,0) -- 1 day = 86400 seconds
function notification(s_afvaltype,s_afvaltype_date,i_daysdifference)
dprint("...Noti-> i_daysdifference:"..tostring(i_daysdifference).." afvaltype_cfg[s_afvaltype].daysbefore:"..tostring(afvaltype_cfg[s_afvaltype].daysbefore).." hour:"..tostring(afvaltype_cfg[s_afvaltype].hour).." min:"..tostring(afvaltype_cfg[s_afvaltype].min))
if afvaltype_cfg[s_afvaltype] ~= nil
and timenow.hour==afvaltype_cfg[s_afvaltype].hour
and timenow.min==afvaltype_cfg[s_afvaltype].min
and i_daysdifference == afvaltype_cfg[s_afvaltype].daysbefore then
print ('afvalWijzer Notification send for ' .. s_afvaltype)
dag = ""
if afvaltype_cfg[s_afvaltype].daysbefore == 0 then
dag = "vandaag"
elseif afvaltype_cfg[s_afvaltype].daysbefore == 1 then
dag = "morgen"
dag = "over " .. tostring(afvaltype_cfg[s_afvaltype].daysbefore) .. " dagen"
notificationtitle = notificationtitle:gsub('@DAG@',dag)
notificationtitle = notificationtitle:gsub('@AFVALTYPE@',s_afvaltype)
notificationtitle = notificationtitle:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtitle = notificationtitle:gsub('@AFVALDATE@',s_afvaltype_date)
notificationtext = notificationtext:gsub('@DAG@',dag)
notificationtext = notificationtext:gsub('@AFVALTYPE@',s_afvaltype)
notificationtext = notificationtext:gsub('@AFVALTEXT@',tostring(afvaltype_cfg[s_afvaltype].text))
notificationtext = notificationtext:gsub('@AFVALDATE@',s_afvaltype_date)
commandArray['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress
-- Do the actual update retrieving data from the website and processing it
function Perform_Update()
print('afvalWijzer module start check')
dprint('=== web update ================================')
-- get data from afvalWijzer
local commando = "curl --max-time 5 -s 'https://datalab.purmerend.nl/afvalkalender/?area=Weidevenne'"
local tmp = os.capture(commando, 5)
if ( tmp == "" ) then
print("afvalWijzer: Empty result from curl command")
return
-- strip html stuff and format for domoticz
tmp=tmp:gsub('%c','')
--~ <p class="firstDate">donderdag 22 maart</p>
--~ <p class="firstDate">vandaag</p>
--~ <p class="firstWasteType">Groente, Fruit en Tuinafval</p>
-- get the data for these fields
web_afvaldate,web_afvaltype=tmp:match('.-<p class="firstDate">(.-)</p>.-<p class="firstWasteType">(.-)</p>')
dprint("web_afvaltype:"..tostring(web_afvaltype).." web_afvaldate:"..tostring (web_afvaldate))
if (web_afvaldate == nil or web_afvaltype == nil) then
print ('! afvalWijzer: No valid data found in returned webdata. skipping the rest of the logic.')
return
-- set the date back to a real date to allow for future processing
if web_afvaldate == "vandaag" then
if WDAY_e_n[os.date("%A")] == nil then
dprint(" Error: Not in table WDAY_e_n[]:"..os.date("%A"))
if MON_e_n[os.date("%B")] == nil then
dprint(" Error: Not in table MON_e_n[]:"..os.date("%A"))
web_afvaldate = WDAY_e_n[os.date("%A")].." "..os.date("%d").." "..MON_e_n[os.date("%B")]
dprint('Change web_afvaldate "vandaag" to :' .. web_afvaldate)
-- process new information from the web
daysdifference = getdaysdiff(web_afvaldate)
if (afvaltype_cfg[web_afvaltype] == nil) then
print ('! afvalWijzer: Afvalsoort not defined in the "afvaltype_cfg" table for found Afvalsoort : ' .. web_afvaltype)
notification(web_afvaltype,web_afvaldate,daysdifference) -- check notification for new found info
dprint('=== device: ' .. myAfvalDevice .. ' check and update ========')
-- update device when text changed
local txt = ""
curdevtext = otherdevices[myAfvalDevice]
-- process each record in the device text first to check if still in future and notification needed
for dev_date, dev_afvaltype in string.gmatch(curdevtext..'\r\n', '(.-)=(.-)\r\n+') do
dprint("=> process:"..dev_date.."="..dev_afvaltype)
if web_afvaltype == dev_afvaltype then
dprint(".> skip same as Web -> dev_afvaltype:"..dev_date.."="..dev_afvaltype)
-- Get DaysDiff
daysdiffdev = getdaysdiff(dev_date)
if daysdiffdev < 0 then
dprint(".> skip old -> dev_afvaltype:"..dev_date.."="..dev_afvaltype.." daysdiffdev:"..daysdiffdev)
dprint(".> Add back to TxtDev -> afvaltype:"..dev_date.."="..dev_afvaltype.." daysdiffdev:"..daysdiffdev)
notification(dev_afvaltype,dev_date,daysdiffdev) -- check notification for new found info
txt = txt..dev_date .. "=" .. dev_afvaltype .. "\r\n"
dprint('=== Update TxtDevice in Domoticz =============')
dprint("=> Add Webinfo to TxtDev -> afvaltype:"..web_afvaltype.." - "..web_afvaldate)
txt = txt..web_afvaldate .. "=" .. web_afvaltype
-- always update the domoticz device so one can see it is updating and when it was ran last.
if (curdevtext ~= txt) then
commandArray['UpdateDevice'] = otherdevices_idx[myAfvalDevice] .. '|0|' .. txt
print ('afvalWijzer: Update device from: \n'.. otherdevices[myAfvalDevice] .. '\n replace with:\n' .. txt)
print ('afvalWijzer: No updated text for TxtDevice.')
-- End Functions =========================================================================
-- Start of logic ========================================================================
timenow = os.date("*t")
-- check for notification times and run update only when we are at one of these defined times
local needupdate = false
for avtype,get in pairs(afvaltype_cfg) do
dprint("afvaltype_cfg :"..tostring(avtype)..";"..tostring(afvaltype_cfg[avtype].hour)..";"..tostring(afvaltype_cfg[avtype].min))
if timenow.hour==afvaltype_cfg[avtype].hour
and timenow.min==afvaltype_cfg[avtype].min then
needupdate = true
-- get information from website, update device and send notification when required
if needupdate then
debug = true -- activate debug here to only log the update process in detail
Perform_Update()
dprint("Scheduled time(s) not reached yet, so nothing to do!")
lua script_time_afvalwijzer.lua
Hello Jos,jvdz wrote: ↑Monday 13 August 2018 12:14 The command to run the lua script is:Try that and see what it says.Code: Select all
Jos
I was wrong there's no fault but also no reply. When i'm using https://datalab.purmerend.nl/afvalkalen ... ind=&date= in curl I do get a reply.rron wrote: ↑Monday 13 August 2018 21:57Hello Jos,jvdz wrote: ↑Monday 13 August 2018 12:14 The command to run the lua script is:Try that and see what it says.Code: Select all
Jos
My mistake.
Looks ok now but only the wrong garbage bin. I have to look into that.
Thanks for that I appreciate that
Dear...pwhooftman wrote: ↑Thursday 15 June 2017 17:34 Nice
There is now also a version for Zuid Limburg available in github on request of @brutus.rron wrote: ↑Saturday 18 August 2018 12:29 Everything is working now with the help of JvdZ, thanks for that.
The script can be found on : https://github.com/jvanderzande/mijnafvalwijzer
Ronald
Jos is a master!jvdz wrote: ↑Saturday 29 September 2018 16:54There is now also a version for Zuid Limburg available in github on request of @brutus.rron wrote: ↑Saturday 18 August 2018 12:29 Everything is working now with the help of JvdZ, thanks for that.
Ronald
Enjoy,
Jos
