What are all these devices?
Theedoek
Post by Theedoek »
First of all, I'm fairly new to Domoticz and all that comes with it (Z-Wave, Hue, etc.). I haven't done much with it yet as I am still learning.
I borrowed a Philips Hue set and Aeon Z-Wave set from a friend and used my Raspberry Pi 3 to install Domoticz on a freshly installed Raspbian Stretch Lite. Followed all the articles to get my system up to date and running (including monit and HomeKit).
Hardware added: Hue bridge and Aeon USB Controller
Devices: Hue: three light bulbs / Z-Wave: Aeon Smart Switch 6 and Aeon Multi Sensor 6
Both z-wave devices from Aeon provide much more functionality than just the switch and sensor. In case of the smart sensor 6, it creates the following devices:
z-wave additional devices.png (12.95 KiB) Viewed 583 times
The first and last line are obvious, but what do the others do? I tried various things but can't find out what they do and how they can be used.
Eventually, if I like how Domoticz works and can find some good not too expensive hardware, I will equip my new house with it and also wish to configure an alarm system using Domoticz.
blauwebuis
Domoticz version: current
Re: What are all these devices?
Post by blauwebuis »
you'll have to ask Aeon?
Theedoek
Post by Theedoek »
We'll i crawled though the documentation already, but no luck.
And I can't imagine that no one else has come this before...
Derik
Post by Derik »
All this devices are Zwave device [ from the sensor you learn ] you can use for alarm settings or alarm
All these sensor are working in Domoticz.
So when a X value is reached domoticz can do something with that.
Example..
There are max value into Zwave device when you use a powerdevice.
when the max value is there.. a warningsensor is going to on
When the max of the sensor is not there, the warningsensor is going to off.
