[Solved] Zipato rgbw bulb 2 only dimmable
peet3kabo
Post by peet3kabo »
Hello all,
Just today received a zipato bulb rgbw light.
Now installed en added node to domoticz with zwave usb stick.
Now I can only control the lamp as a normal lamp, on/off and dimmable.
No options on changing colors in rgb mode.
Tried to exclude and include several times but no change.
Anybody having any ideas?
Verstuurd vanaf mijn SM-G935F met Tapatalk
peet3kabo
Re: Zipato rgbw bulb 2 only dimmable
Post by peet3kabo »
Also tried to reset the bulb and include again but that also doesn't change anything.
Can't vind anything about the bulb and rgb mode
peet3kabo
Post by peet3kabo »
Nobody having a clue if it is possible with these bulbs 8n domoticz to control rgbw?
TJLuijt
Domoticz version: 2022.1
Post by TJLuijt »
I somehow have the same issues since owning this bulb - factory reset quite a few times and pairing again but no luck.
It should be possible seeing all the other threads on changing the colours :)
please help :)
Raspberry pi
Zigbee2MQTT
Z-Wave usb
peet3kabo
Post by peet3kabo »
Found on the web somewhere that it is not completly supported by domoticz.
Likely its only dimmable on warm white.
That is the problem that we have, but also read somewhere that they did have the rgb function in Domoticz.
It installed as a RGBW light.........nothing I can't seem to get going.
Maybe some of the developers know how and what is going on with these bulbs.
Someone know how to contact them?
peet3kabo
Post by peet3kabo »
Opened a post in bugs and problems, here:
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Maybe that will get something going.
peet3kabo
Post by peet3kabo »
Problem solved.
Got an answer from somebody to adjust the RGBBulb2.XML file.
You can find the answer here:
https://gathering.tweakers.net/forum/li ... es/1869961
Adjust config file for Zipato Bulb2 (~/domoticz/Config/ZipatoRGBBulb2.xml). The <CommandClass id="51"> needs to be replaced with the following:
<CommandClass id="51" name="COMMAND_CLASS_COLOR" version="1" request_flags="2" innif="true" colorchannels="31">
 <Instance index="1" />
 <Value type="string" genre="user" instance="1" index="0" label="Color" units="#RRGGBBWWCW" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="#8888000000" /> <Value type="list" genre="user" instance="1" index="1" label="Color Index" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="17" size="0">
      <Item label="Off" value="0" />
      <Item label="Cool White" value="1" />
      <Item label="Warm White" value="2" />
      <Item label="Red" value="3" />
      <Item label="Lime" value="4" />
      <Item label="Blue" value="5" />
      <Item label="Yellow" value="6" />
      <Item label="Cyan" value="7" />
      <Item label="Magenta" value="8" />
      <Item label="Silver" value="9" />
      <Item label="Gray" value="10" />
      <Item label="Maroon" value="11" />
      <Item label="Olive" value="12" />
      <Item label="Green" value="13" />
      <Item label="Purple" value="14" />
      <Item label="Teal" value="15" />
      <Item label="Navy" value="16" />
      <Item label="Custom" value="17" />
  </Value>
  <Value type="int" genre="system" instance="1" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="31" />
</CommandClass>
Edit:
Don't know how to get the code visible yet, working on it.
TJLuijt
Re: [Solved] Zipato rgbw bulb 2 only dimmable
Post by TJLuijt »
yep, works for me as well.
thanks for the help guys!
Raspberry pi
Zigbee2MQTT
Z-Wave usb
Sandy
Domoticz version: V4.10717
Post by Sandy »
peet3kabo wrote: Tuesday 14 August 2018 16:33 Problem solved.
  </Value>
</CommandClass>
Edit:
Worked for me, thanks a lot. I missed setting this up.
It got even better than before, before i couldnt mix colours.. just bright RED not light red.
Thanks a million.
Bospieper
Post by Bospieper »
Hi, I recently purchased a Zipato Bulb2. After some install issues and reading the forum I copied the XML file as earlier mentioned in to the \Domoticz\Config. Then I include the Zipato. At the Devices page I am getting three devices, two color switches and one color level device.
When this is correct can you describe me how to manage colors in Domoticz.
My Domoticz version is 4.11227 and I am using the Aurora theme
bert
Post by bert »
Got a brand new Zipato rgbw bulb 2 in the mail today.
I Included it without issues in Domoticz 4.10717. It is added as a regular dimmer and as an RGBWWZ controlled light that lets me choose any colour I like from the Domoticz userinterface. No need to modify any file or jump through hoops in any way; works out of the box.
Writing this because, before ordering, I also landed on this thread and prepared myself for the worst.
For you all hesitating as a result - no need - issues seem to have been solved in the meantime :)
miniomar
Post by miniomar »
Hi everybody,
Have you any idea if it is possible to read the consumption of this bulb lamp ?
Thanks and regards
