JuanUil
Domoticz version: 4.11083
Post by JuanUil »
Hi Folks,
I have tried everything over and over again.
Installed stable version - no favourites
Installed beta - no favourites
when I insert
columns[1] = {}
columns[1]['blocks'] = ['341']
columns[1]['width'] = 5;
then I get a switch on the screen.
here is my config
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://192.168.2.18:8080';
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['loginEnabled'] = 0;
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'son-en-breugel/bushalte-penseelkever', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,3,4,31,46,92], maxitems: 5 }
var _STREAMPLAYER_TRACKS  	= [
	{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3"},
	{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
	{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
	{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl',  width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos',  width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
/*columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather']
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise','streamplayer',buttons.nunl,buttons.nos]
columns[3]['width'] = 2;
columns[1] = {}
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
also set autopositioning from 1 to 0 and also use favourites from 1 to 0 also no luck :cry:
Any help is highly appreciated!!
Jan
HansieNL
Post by HansieNL »
JuanUil wrote: Saturday 14 July 2018 15:51 Hi Folks,
when I insert
columns[1] = {}
here is my config
var config = {}
var tvguide = {}
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
/*columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[1] = {}
var screens = {}
screens[1] = {}
Jan
You have to add your switches as blocks ( blocks[IDX] = {} ) if set favorites to 0.
How to do that is described in the wiki https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
var blocks = {}
blocks[123] = {} //Sensor 1
blocks[234] = {} //Example 2
Then you can add your switch/sensor where you want it.
columns[1] = {}
columns[1]['blocks'] = [123,234]
Blah blah blah
JuanUil
Post by JuanUil »
Oh oké,
thanx for your reply, I thought that the favourites were added automatically.
I will start working it out with an example!
Thanx again.
Jan
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
Can someone help me. Volt is ok. Volt as text and value below. But Gas vandaag, Totaal Gas, And the rest are not switched also not the title is showing
// P1 INFO
blocks[23] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Watt'    };
blocks[24] =    {width: 4, icon: 'fa-bolt', show_lastupdate: false,  hide_data: true, switch: true,   title: 'Volt'    };
blocks[25] =    {width: 4, icon: 'fa-fire',  show_lastupdate: false,  hide_data: true, switch: true,   title: 'Gas'    };
poudenes
Post by poudenes »
nobody?
EdwinK
Post by EdwinK »
No, sorry. I had the same problem, and somehow it's now gone. Strange.
mvveelen
Post by mvveelen »
I managed to get one of my webcams integrated in Dashticz:
buttons.camera1 = {width:12, isimage:true, refreshimage:2000, image: 'http://192.168.0.17:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=passwd'}
But the other one has a URL like:
http://192.168.0.101/webcapture.jpg?command=snap&channel=0
and I can't seem to get this one integrated in my Dashticz. Maybe someone can help me out? It's an Escam QD500
Another question:
I have some door/window sensors in my house, but on the Dashticz screen all sensors are displayed as DOOR-sensors. I would like to be able to change some of them into WINDOWS-sensors. Is this possible? If so, how?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Ectholian
Post by Ectholian »
Beware of an upcoming change in the new domoticz versions. The LevelNames returned by domoticz will be base64-encoded instead of plain text. That means it will stop working in dashticz. I quickfixed it (try base64-decode and after that use the current split('|') ) but a nicer way would be to check the domoticz version and do/don't base64decode on that.
More info: https://github.com/domoticz/domoticz/issues/2454
Ectholian
Post by Ectholian »
mvveelen wrote: Sunday 22 July 2018 18:44 Hi,
https://www.ispyconnect.com/man.aspx?n=eScam
That cam does not have a jpeg stream, only rtsp and that won't work if i am not mistaken.
EdwinK
Post by EdwinK »
RTSP won't work on Domoticz/Dashticz, unfortunately.
mvveelen
Post by mvveelen »
Ah, too bad.... thanks though.
RiLaSol
Post by RiLaSol »
Is there a manual for Dashticz?
For example were can I find were the TV channels that are coded in the CONFIG.js file are?
HansieNL
Post by HansieNL »
There's is a Wiki. You can find the channellist here https://www.domoticz.com/wiki/Dashticz_ ... 28Dutch.29
Blah blah blah
TapNL
Post by TapNL »
My Pi crashed the other day. I had all settings backed up. That worked out quite well.
I was not yet running on the latests version of Dashticz, not sure on which one.
I use an Android tablet to display the dashboard. Works like a charm.
In the past I was able to refresh the page by pulling the screen down. That does not work anymore. I checked other websites and it works there, so I am guessing that something changed in an update of Dashticz. Anyone any clue how I can fix this?
Herman-H
Post by Herman-H »
First of all i will thanks Rob Geerts for this nice piece of software and the community for the samples and tips etc.
I'm a noob with this kind of programs so it was a lot of reading and testing.
But now i have two questions:
1: When i change somthing in the settings menu and will save it it doesn't work.
2: I have 'currentweather_big','weather' in my CONFIG.js but i don't see it again.
I have a key of Weather Underground.
What do i wrong? Any help will appreciate.
CONFIG.js
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'My-IP';
config['wu_api'] = 'My_Key';
config['wu_city'] = 'Hengelo';
config['wu_name'] = 0;
config['wu_country'] = 'NL';
config['standby_after'] = 10;
/* REMOVE THIS LINE, INCLUDING THIS TEXT IF YOU WANT TO USE THE CODE BELOW, ALS REMOVE THE LAST LINE OF THIS FILE ( the asterisk * with the slash)
publictransport.ovinfobus = { show_via: false, station: 'hengelo/bushalte-bruninkshoek', show_lastupdate:true, provider: '9292-bus', icon: 'bus', width:6, results: 6 }
publictransport.ovinfotrain= { station: 'station-hengelo', show_lastupdate:true, provider: '9292-train', icon: 'train', width:6, results: 6 };
var buttons = {}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos',url: 'http://nos.nl'}
buttons.tweakers = {key: 'tweakers', width:12, icon: 'fa-newspaper-o', title: 'Tweakers', newwindow:true, url: 'http://tweakers.net'}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', newwindow:true, url: 'https://gadgets.buienradar.nl/gadget/zo ... &overname=$
//************************************************** 'blocktitle_1' **********************************************************************
//Lampen kamer
blocks[66] = {} //Woonkamer Duo lampen
blocks[66]['width'] = 6;
blocks[67] = {} //Woonkamer L & R naast TV
blocks[67]['width'] = 6;
blocks[345] = {} //Woonkamer staande schemerlamp
blocks[345]['width'] = 6;
blocks[346] = {} //Woonkamer staande schemerlamp lezen
blocks[346]['width'] = 6;
blocks[779] = {} //WC-Raam
blocks[779]['width'] = 6;
//************************************************** 'blocktitle_2' ************************************************************************
blocks[2170] = {} //Temperatuur slaapkamer
blocks[2170]['width'] = 6;
blocks[3268] = {} //Temperatuur zolder
blocks[3268]['width'] = 6;
var blocks = {}
//Block Titles
blocks['blocktitle_1']['title'] = 'Schakelaars';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['key'] = 'blocktitle_2';
blocks['blocktitle_2']['title'] = 'Temperatuur';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['key'] = 'blocktitle_3';
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Bus en Trein';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['key'] = 'blocktitle_4';
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Info en Weer';
columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',66,67,345,346,779,'blocktitle_2',2170,3268]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_3','currentweather_big','weather',publictransport.ovinfobus,publictransport.ovinfotrain]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_4','clock','sunrise',buttons.nunl,buttons.nos,buttons.tweakers,buttons.buienradar]
columns[3]['width'] = 4;
//************************************************** 'Standby' ************************************************************************
var screens = {}
screens[1] = {}
custom.css
CUSTOM CSS FILE
HansieNL
Post by HansieNL »
1. Settings are only saved when running php.
2. Have you tried config['auto_positioning'] = 0; ? https://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
Blah blah blah
Herman-H
Post by Herman-H »
HansieNL wrote: Friday 10 August 2018 19:43 1. Settings are only saved when running php.
i don't use php so point 1 is clear.
for point 2 i tried auto positioning. same 'currentweather_big','weather not visible.
When i use the data from the original CONFIG_DEFAULT.js of github and my wu key i have the same result.
And that do i don't understand.
HansieNL
Post by HansieNL »
@Herman-H: can you try to enlarge the width for the column containing weather block to 5?
Blah blah blah
Herman-H
Post by Herman-H »
@ HansieNL, the same, no weather or currentweather_big. Is there a relation between the key of WU and showing this items?
HansieNL
Post by HansieNL »
@Herman-H: If the key is not right the item only shows 4 small blocks without info.
Blah blah blah
Locked
