[Solved] How to treat nil value returned by otherdevices_svalues Topic is solved
YellowSky
Domoticz version: Last
Post by YellowSky »
Hi everyone,
in my lua script i use this command to recover the temperature and the humidity of a DHT sensor.
line 99 T, RH = otherdevices_svalues['Kitchen']:match("([^;]+);([^;]+)")
However i would like to treat this error i receive when the sensor is disconnect:
Error: EventSystem: in domoticz/scripts/lua/script_time_thermostathyst.lua:99: attempt to index field 'Kitchen' (a nil value)
Is there any command to do this?
For example if a nil value is returned, change by default value and continue to execute the code.
Thank you.
freijn
Domoticz version: Stable
Re: How to trat nil value returned by otherdevices_svalues
Post by freijn »
instead of a calculation, first test if there is a value > 0 ?
jvdz
Domoticz version: 4.107
Post by jvdz »
something like this:
if otherdevices_svalues['Kitchen'] ~= nil then
	-- put here your the actions in case it is nil
Jos
YellowSky
Post by YellowSky »
Thank you for your suggestion.
Users browsing this forum: RNEE and 1 guest
