I just started using a 2nd Fibaro FGS-223 and found out both my old and new unit show the same "double switch reporting" issue.
I never noticed it on my 1st unit, but I am using my second one with DzVents scripts, and notice the double logging, as the script is triggered twice. Now I checked the 1st unit and find the same issue.
It seems to me that:
- When I operate the button physically linked to the relay, it reports 1 switch in the log
- When I operate the relay by software, it reports often 2 similar switches in the log
Is there a known solution? Solving the cause (Domoticz sending the switch command twice) rather than the effect (finding an workaround in the script)?
Fibaro Switch FGS-213 and FGS-223 causing double events
Nelissuh
- Domoticz version: 4.10717
Re: Fibaro Switch FGS-213 and FGS-223 causing double events
- Fibaro FGS-223 sending on-off commands double.PNG (29.44 KiB) Viewed 1011 times
Grover01
Hi Nelissuh,
I'm seeking around already for a long time to find a solution for this........without any luck until now.
commentator
Hi, noticed this also (besides this problem: http://domoticz.com/forum/viewtopic.php?f=6&t=24381 )
jluc2808
sorry to post late, but i get the same problem with FGS222, is there possible that the zwave mesh network is involved in the duplicate command, send by the controller and repeat by a device which is connected to the group ?
Amsterdam020
- Domoticz version: 3.5629
I have returned them to the shop because I was not satisfied. Get rid of them
Rp3, youlesss, rfxcom, philips hue, dsb1820
Nelissuh
I updated to the latest config files, but I still see the same issue.
