Hi All,
I've bought cheap chinese doorcontact (3 pcs in 1 buy) and they work perfectly in domoticz, until I activated Byron SX (Byron is needed for my doorbell).
When I have activated Byron SX in domoticz, only 1 doorcontact is working. The other 2 don't work anymore. I also tested in RFXmanager and when pressing the working doorcontact it receives signal, when pressing the other two there is no signal received.
When I deactivate Byron SX, all 3 of the doorsensors work properly.
I'm running Domoticz on RaspberryPi with RFXcom. I have 3 doorcontacts:
https://nl.aliexpress.com/store/product ... 4102BUp8Em
Thanks in advance!
No signal from doorcontact when enable Byron SX
- Target OS: -
Re: No signal from doorcontact when enable Byron SX
See chapter 2.4 in the RFXtrx User Guide which protocols can be used together.
Within a few weeks a new firmware will become available which supports more enabled protocols.
RFX-433, RFX-433EMC, RFX-868
Thanks for your reply! It explains a lot to me.
But it stays strange to me that one of the sensors is working perfectly with both protocols enabled and the other 2 don't (exact the same sensors and bought in one buy). Al sensors are working on lightning5 protocol.
Thanks again for your time and reply. I will wait for the new firmware.
Kind regards Robin
Kind regards Robin
Re: Problem Solved. Now it's working!
To discover the doorbell you need to enable the Byron SX modus. Once the doorbel is programmed I closed the Byron SX mode en the doorbell is still working. Doorbell is now listed under switches as: Lightning 4, PT2262, Doorbell.
Now all sensors and the doorbell are working fine!
Problem Solved!
Kind regards
Problem Solved!
Kind regards
