Ciao,
I'm playing with MQTT and I see dZ publish only devices and sensors to MQTT, no variables, no other status message
I have few NodeRed flows that could be interested in receiving messages from MQTT to... do stuff...
a kind of these messages should came from Domoticz as a reasult of a scritp...
Instead of adding a os.execute with the mosquitto_pub (which doesn't work for me since the repository seems to be broken), it would be nice if dzVents could send MQTT telegram as function
something like
sendMqtt(topic, payload)
could it be an idea?
ciao
M
dzVents new feature: add MQTT feature
- emme
- Domoticz version: latest
"We always done this way"
Charley
- Domoticz version: V3.9030
Re: dzVents new feature: add MQTT feature
With nodered you can use the published events from MQTT by setting the topic to domoticz/out.
Then you need a function node to filter what event you like to control. I use extensive Nodered flows to control several devices.
Here is a flow to start how you could collect data from MQTT with domoticz/out
Here is a flow to send data to MQTT
If you want to collect your uservariables this flow could be a start. I use it to set timers for lights, wakeup alarm and rollershutters.
My Domoticz, MQTT and Nodered are all on the same Raspberry PI 3+ (Nodered and MQTT are password protected)
[{"id":"cd222b8e.945fb8","type":"mqtt in","z":"150731a6.9b7e5e","name":"MQTT","topic":"domoticz/out","qos":"1","broker":"fc68fc78.a14ae","x":150,"y":260,"wires":[["cbef9f4a.ea47d"]]},{"id":"cbef9f4a.ea47d","type":"json","z":"150731a6.9b7e5e","name":"","property":"payload","action":"","pretty":false,"x":290,"y":260,"wires":[["70c33c55.72fb64","b259e07.59b2a2","b6de791b.57af08","eebb88a4.b5a368"]]},{"id":"b259e07.59b2a2","type":"switch","z":"150731a6.9b7e5e","name":"stype","property":"payload.stype","propertyType":"msg","rules":[{"t":"eq","v":"kWh","vt":"str"},{"t":"eq","v":"LaCrosse TX3","vt":"str"},{"t":"eq","v":"Sound Level","vt":"str"},{"t":"eq","v":"Weather Station","vt":"str"},{"t":"eq","v":"Electric","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":450,"y":260,"wires":[["a7edc925.0e8878"],["69f16424.05c39c"],["862d4453.3427f8"],["e8720982.29a618","69f16424.05c39c"],["a7edc925.0e8878"]]},{"id":"fc68fc78.a14ae","type":"mqtt-broker","z":"","name":"","broker":"192.168.178.188","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
[{"id":"de09d7bd.29a8e8","type":"inject","z":"75ec7863.1959e8","name":"","topic":"light","payload":"Off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":280,"wires":[["2f822c74.4153d4"]]},{"id":"21317f95.a289c","type":"inject","z":"75ec7863.1959e8","name":"","topic":"light","payload":"On","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":240,"wires":[["2f822c74.4153d4"]]},{"id":"fa3a4b82.b07b88","type":"function","z":"75ec7863.1959e8","name":"","func":"var mqtt = { command: \"setcolbrightnessvalue\", idx: 59, hex: msg.payload, brightness: 90, iswhite: false };\n\nvar newMsg = {};\nnewMsg.payload = {};\nnewMsg.payload = mqtt;\nreturn newMsg\n","outputs":1,"noerr":0,"x":410,"y":120,"wires":[["3c7b98c0.c99a28","b170a429.7792e8"]]},{"id":"3c7b98c0.c99a28","type":"mqtt out","z":"75ec7863.1959e8","name":"","topic":"domoticz/in","qos":"1","retain":"true","broker":"fc68fc78.a14ae","x":710,"y":120,"wires":[]},{"id":"b170a429.7792e8","type":"debug","z":"75ec7863.1959e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":690,"y":260,"wires":[]},{"id":"2f822c74.4153d4","type":"function","z":"75ec7863.1959e8","name":"","func":"// 59 is a RGB strip, 28 is a normal ligth\nif (msg.topic==\"rgb\"){\n var mqtt = { command: \"switchlight\", idx: 59, switchcmd: msg.payload };\n} else if (msg.topic==\"light\"){\n var mqtt={ command: \"switchlight\", idx: 28, switchcmd: msg.payload }\n}\n\nvar newMsg = {};\nnewMsg.payload = {};\nnewMsg.payload = mqtt;\nreturn newMsg\n","outputs":1,"noerr":0,"x":410,"y":260,"wires":[["3c7b98c0.c99a28","b170a429.7792e8"]]},{"id":"38d76626.40560a","type":"inject","z":"75ec7863.1959e8","name":"set color","topic":"","payload":"FF0B85","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":60,"wires":[["fa3a4b82.b07b88"]]},{"id":"5e1d95e8.8198ac","type":"inject","z":"75ec7863.1959e8","name":"","topic":"rgb","payload":"Off","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":140,"wires":[["2f822c74.4153d4"]]},{"id":"dbea6765.a9ad18","type":"inject","z":"75ec7863.1959e8","name":"","topic":"rgb","payload":"On","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":100,"wires":[["2f822c74.4153d4"]]},{"id":"fc68fc78.a14ae","type":"mqtt-broker","z":"","name":"","broker":"192.168.178.188","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
[{"id":"43534cff.c597d4","type":"inject","z":"65fdffa8.dd87d","name":"","topic":"button","payload":"17","payloadType":"num","repeat":"60","crontab":"","once":true,"onceDelay":"1","x":110,"y":240,"wires":[["595da7f.2494358"]]},{"id":"595da7f.2494358","type":"http request","z":"65fdffa8.dd87d","name":"","method":"GET","ret":"obj","url":"http://192.168.178.188:8088/json.htm?param=getuservariables&type=command","tls":"","x":270,"y":240,"wires":[["c8ac953a.354328"]]},{"id":"c8ac953a.354328","type":"function","z":"65fdffa8.dd87d","name":"Select the vars","func":"//loop the payload we don't need all\nfor (var i=0;i<msg.payload.result.length;i++){\n //set the received minutes to 24h time format\n var newMins = parseInt(msg.payload.result[i].Value);\n var cMins=newMins;\n var newHrs=Math.floor(newMins/60);\n // the number of hours is too big set it to 7 hours\n if (newHrs>23){newHrs=7}\n newMins = newMins - (60 * newHrs)\n // 12:34 \n newTime=(newHrs<10?\"0\":'') + newHrs + \":\" +(newMins<10?\"0\":'') + newMins\n //extract the name\n var tmpName = msg.payload.result[i].Name\n if (tmpName==\"LichtWoonkamer\" ||\n tmpName==\"LichtSlaapkamer\" ||\n tmpName==\"Wekker\" ||\n tmpName==\"RolluikOpenSlaapkamer\" ||\n tmpName==\"LichtKeuken\" ||\n tmpName==\"LichtBuiten\" ||\n tmpName==\"RolluikOpenLogeer\" ||\n tmpName==\"RolluikKantoor\") {\n \n // now send them one by one \n newMsg={payload: newTime, topic:tmpName, cMin:cMins}\n node.send(newMsg)\n \n \n }\n}","outputs":1,"noerr":0,"x":440,"y":240,"wires":[["49a6afb7.ff702"]]},{"id":"49a6afb7.ff702","type":"switch","z":"65fdffa8.dd87d","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"LichtWoonkamer","vt":"str"},{"t":"eq","v":"LichtSlaapkamer","vt":"str"},{"t":"eq","v":"Wekker","vt":"str"},{"t":"eq","v":"RolluikOpenSlaapkamer","vt":"str"},{"t":"eq","v":"LichtKeuken","vt":"str"},{"t":"eq","v":"LichtBuiten","vt":"str"},{"t":"eq","v":"RolluikOpenLogeer","vt":"str"},{"t":"eq","v":"RolluikKantoor","vt":"str"}],"checkall":"true","repair":false,"outputs":8,"x":590,"y":240,"wires":[["5f26157.dd391ec","2efab279.5e1a9e"],["50904e59.f0861"],["6b809640.6800a8"],["d377196b.ce7c48"],["9d3a9264.a1b11"],["c10b99b3.986f18"],["2dbe37eb.a28cb8"],["c117573d.c1b348"]]}]
- emme
that doesn't work for variables...
