Simple IF - THEN not working
mvveelen
Post by mvveelen »
I have this in Lua:
if aircoValueVaneZKval == "10" then
commandArray['UpdateDevice'] = "739|0|50"
local aircoValueVaneZKval2 = aircoValueVaneZKval  * 10
commandArray['UpdateDevice'] = "739|0|" .. tostring(aircoValueVaneZKval2) .. "|"
The values can be:
aircoValueVaneZKval: 1 -> this has to be converted into 10, hence the * 10
aircoValueVaneZKval: 2 -> this has to be converted into 20, hence the * 10
aircoValueVaneZKval: 3 -> this has to be converted into 30, hence the * 10
aircoValueVaneZKval: 4 -> this has to be converted into 40, hence the * 10
aircoValueVaneZKval: 10 -> this has to be converted into 50......
So, where is the fault in my script?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
jvdz
Domoticz version: 4.107
Re: Simple IF - THEN not working
Post by jvdz »
try:
local aircoValueVaneZKval2 = tonumber(aircoValueVaneZKval)
if aircoValueVaneZKval2 == 10 then
	aircoValueVaneZKval2 = aircoValueVaneZKval2  * 10
Jos
mvveelen
Post by mvveelen »
Edit:
I forgot 2 lines of code. Your solution seems to work. Tomorrow I'll try to use it for the other values. Thanks!
mvveelen
Post by mvveelen »
It's working with your code. I used it for all other values too and it works.
One thing: I had to split everything into separate Lua scripts (time). If I put all into one Lua script (time), only one value is updated. No problem though.
Now, every minute the status is updated. That's a lot, but I don't think it can do any harm to the Domoticz setup, right :D ?
jvdz
Post by jvdz »
That is easy to resolve too. :D
Just use this format for the commandarray entries:
	commandArray[#commandArray + 1] = {['UpdateDevice'] = "739|0|50"}
	commandArray[#commandArray + 1] = {['UpdateDevice'] = "739|0|" .. tostring(aircoValueVaneZKval2)}
Let me know when you need help converting the separate script by showing them and I'll help merging them.
Jos
mvveelen
Post by mvveelen »
Ehm.....it's a lot.....but I copied them here: https://pastebin.com/76aSiXaU
Don't waste too much time, it works for now. And I don't want you to waste too much of your time. On the other hand: if it's easy to do: thanks in advance :-) !
