Get online airquality data [SOLVED]
- EdwinK
- Domoticz version: BETA
Re: Get online airquality data
At least PM10 (and PM25) and amonia. We have some heave industry over here, so I want to know as much as possible about airquality.
elmortero
- Domoticz version: 3.9639
WIth the last code I posted, you can replicate all parts for PM25 (I don't know if that is needed, as PM25 is smaller than PM 10)
As for amonia, waqi does not offer that value
- capman
My script so far. It's not updating now because the values are stable. But there are no errors in the log.
Just wonder how to get the right allert values ? For Europe.
So should it not begin with a value of <50 , >50 and <=90 , and so on ? This is only for pm10 value.
timer = { 'every 10 minutes' },
httpResponses = { 'waqi' } -- matches callback string below
execute = function(domoticz, triggerItem)
local lat = 'xxxxxxxx'
local long = 'yyyyyyyy'
local apikey = 'my api key'
local PM10sensor = domoticz.devices('Fijn stof') -- virtual sensor of the type "Custom sensor"
local prevPM10 = PM10sensor.rawData[1] -- get the current value of the Alert
local pmalert = domoticz.devices('Fijn stof alarm') -- virtual sensor of the type "Alert"
local AirC = domoticz.devices('Luchtkwaliteit') -- virtual sensor of the type "Air Quality"
if (triggerItem.isTimer) then
domoticz.openURL({
url = 'http://api.waqi.info/feed/geo:'..lat..';'..long..'/?token='..apikey,
method = 'GET',
callback = 'waqi'
elseif (triggerItem.isHTTPResponse) then
local response = triggerItem
if (response.ok and response.isJSON) then
local pm10 = tonumber(response.json.data.iaqi.pm10.v)
local aqius = tonumber(response.json.data.aqi) -- combined air quality
if pm10 ~= nil and pm10 ~= prevPM10 then
PM10sensor.updateCustomSensor(pm10)
if aqius ~= nil then --and aqius ~= prevAirC
AirC.updateAirQuality(aqius)
if pm10 ~= prevpm10 then -- before updating the sensor check if the value has changed (in order to avoid unneeded updating,
if pm10 <= 100 then level = domoticz.ALERTLEVEL_GREEN; nfo = "Good"
elseif pm10 > 100 and pm10 <= 200 then level = domoticz.ALERTLEVEL_YELLOW; nfo = "Polluted"
elseif pm10 > 200 and pm10 <= 300 then level = domoticz.ALERTLEVEL_ORANGE; nfo = "Very Polluted"
elseif pm10 > 300 then level = domoticz.ALERTLEVEL_RED; nfo = "Alarming"
pmalert.updateAlertSensor(level, pm10) -- if you want just on sensor with alert level and value (as text) replace nfo with pm10
print('**PM10failed to fetch info')
}So should it not begin with a value of <50 , >50 and <=90 , and so on ? This is only for pm10 value.
- EdwinK
Maybe it has another name, or code. Not sure Need to check that from another, now no longer, working script.elmortero wrote: Saturday 28 July 2018 13:31 WIth the last code I posted, you can replicate all parts for PM25 (I don't know if that is needed, as PM25 is smaller than PM 10)
- capman
My final working script. Hope it's okee now.
Thanks to all for helping my out , especially Elmortero for the original script.
timer = { 'every 6 minutes' },
local lat = 'xxxxxxx'
local long = 'yyyyyy'
local apikey = 'zzzzzzzzzzz'
local PM10sensor = domoticz.devices('Fijn stof PM10') -- virtual sensor of the type "Custom sensor"
local PM25sensor = domoticz.devices('Fijn stof PM2.5') -- virtual sensor of the type "Custom sensor"
local prevPM25 = PM25sensor.rawData[1] -- get the current value of the Alert
local AirC = domoticz.devices('Luchtkwaliteit buiten') -- virtual sensor of the type "Air Quality"
domoticz.openURL({
method = 'GET',
callback = 'waqi'
local pm10 = tonumber(response.json.data.iaqi.pm10.v) -- respirable particulate matter
local pm25 = tonumber(response.json.data.iaqi.pm25.v) -- partical matter of particles < 2.5µm
if pm25 ~= nil and pm25 ~= prevPM25 then
PM25sensor.updateCustomSensor(pm25)
if pm25 ~= prevpm25 then -- before updating the sensor check if the value has changed (in order to avoid unneeded updating,
if pm25 <= 100 then level = domoticz.ALERTLEVEL_GREEN; nfo = "Zuiver"
elseif pm25 > 100 and pm25 <= 200 then level = domoticz.ALERTLEVEL_YELLOW; nfo = "Vervuild"
elseif pm25 > 200 and pm25 <= 300 then level = domoticz.ALERTLEVEL_ORANGE; nfo = "Zeer vervuild"
elseif pm25 > 300 then level = domoticz.ALERTLEVEL_RED; nfo = "Alarmerend"
pmalert.updateAlertSensor(level, pm25) -- if you want just on sensor with alert level and value (as text) replace nfo with pm10
print('**PM25failed to fetch info')
- EdwinK
Just noticed, I don't get any data at all
elmortero
Just no data? Or errors in log?
Maybe write the acquired data to the log so you can see if it gets a nil value
- EdwinK
This is what I have as devices
And an error.
dzVents: Error (2.4.7): An error occured when calling event handler AirQuality
2018-08-03 10:24:04.331 Status: dzVents: Error (2.4.7): ...omoticz/scripts/dzVents/generated_scripts/AirQuality.lua:32: attempt to index field 'pm25' (a nil value)
2018-08-03 10:24:04.331 Status: dzVents: Info: ------ Finished AirQuality
I'm using the latest (adapted) script from Capman.
And an error.
- waaren
I saw this behaviour also too many times. It looks like some of the locations do not return any data on the first call. Not sure why but most of the times a second call with the exact same content is successful.EdwinK wrote: Friday 03 August 2018 10:30
That is why I modified the script to handle these exceptions. If you are interested...
data from http://waqi.info/
An API key is required and can be aquired here ==> http://aqicn.org/data-platform/token/
Based on the original idea and script from @elmortero
http://api.waqi.info/feed/geo:51.852062;4.507676/?token=Your_apikey = Zwartewaalstraat, Rotterdam Zuid
http://api.waqi.info/feed/geo:51.986119;4.934413/?token=Your_apikey = Lopik (co)
http://api.waqi.info/feed/geo:51.867238,4.354981/?token=Your_apikey = Leemkuil (so2)
timer = { "every 15 minutes" },
httpResponses = { "waqi*" } -- matches callback wildcard
data = {
safedMessage = { history = true, maxItems = 100 , maxHours = 168 }
logging = { level = domoticz.LOG_DEBUG,
marker = "Waqi" },
execute = function(dz, triggerItem)
local apiKey = "Your_apikey"
local defaultLocation = "51.852062;4.507676"
local sensorType
if dz.data.safedMessage.get(1) == nil then
dz.data.safedMessage.add("Init")
local geo = { nearby = defaultLocation, -- to get station closest to your home
SO2 = "51.867238;4.354981", -- if value for this item cannot be obtained from "nearby"
CO = "51.986119;4.934413", -- else keep this as an empty string
PM25 = "",
PM10 = "",
O3 = "",
NO2 = "",
AQI = "",
local sensors = { SO2 = { sensor = 1003, alert = 1002 }, -- enter device index Numbers or 0 for sensor and alert "
CO = { sensor = 1004, alert = 0 },
PM25 = { sensor = 1008, alert = 1009 },
PM10 = { sensor = 1011, alert = 1010 },
O3 = { sensor = 1005, alert = 0 },
NO2 = { sensor = 0, alert = 0 },
AQI = { sensor = 1007, alert = 1006 , aqiSensor = 1000}, -- additional Air Quality sensor
local sensorTypes = { alert = "Alert", aqi = "Air Quality", custom = "Custom Sensor" }
local function responseType(str) -- strip waqi_ from string
return str:gsub("waqi_","")
local function errorMessage(message,notify) -- Add entry to log and notify to all subsystems
dz.log(message,dz.LOG_ERROR)
if notify then
dz.notify(message)
local function callPollutionURL(location,callback,delay)
local delay = delay or 1
local url = "http://api.waqi.info/feed/geo:".. location .. "/?token=" .. apiKey
dz.openURL({ url = url,
method = "GET",
callback = callback
}).afterSec(delay)
local function getAirQualityData()
local delay = 1
for callType, location in pairs(geo) do
if location ~= "" then
callPollutionURL(location,"waqi_" .. callType,delay)
delay = delay + 30
local function alertLevelAQI(value)
if value < 50 then return dz.ALERTLEVEL_GREEN,"Excellent" end
if value < 100 then return dz.ALERTLEVEL_YELLOW,"Poor" end
if value < 150 then return dz.ALERTLEVEL_ORANGE,"Polluted" end
return dz.ALERTLEVEL_RED,"Dangerous"
function deviceType(device)
if device ~= nil then
if dz.devices(device).deviceType:upper() == "GENERAL" then
return dz.devices(device).deviceSubType
return dz.devices(device).deviceType
return nil
local function setSensor(sensor,value)
if sensor ~= 0 and value ~= nil then
if deviceType(sensor) == sensorTypes.custom then
dz.devices(sensor).updateCustomSensor(value)
elseif deviceType(sensor) == sensorTypes.aqi then
dz.devices(sensor).updateAirQuality(value)
local alertLevel, alertText = alertLevelAQI(value)
local alertString = alertText .. "(" .. tostring(value) .. ")"
if dz.devices(sensor).text ~= alertString then
dz.devices(sensor).updateAlertSensor(alertLevel, alertString)
local function handleResponse(type)
local rt = triggerItem.json -- rt is just a reference to the data no actual copy is done
if triggerItem.json ~= nil and rt.data ~= nil and tonumber(rt.data.aqi) then
if type == "nearby" then
rt.data.iaqi["aqi"] = {}; rt.data.iaqi["aqi"].v = rt.data.aqi -- handle exception in iaqi as aqi is stored elsewhere
for nearbyType, location in pairs(geo) do
if nearbyType ~= "nearby" and location == "" then -- No other location for this type
handleResponse(nearbyType)
for setDevice, idx in pairs(sensors[type]) do
setSensor(idx,rt.data.iaqi[type:lower()].v)
errorMessage("This should not happen") -- aqi should always be there and set
if dz.data.safedMessage.get(1).time.secondsAgo > 30 then
errorMessage("I will call url again") -- aqi should always be there and set
callPollutionURL(geo[responseType(triggerItem.trigger)],triggerItem.trigger,1)
dz.data.safedMessage.add("Extra call to openURL for " .. triggerItem.trigger)
if triggerItem.isHTTPResponse then
if triggerItem.ok and triggerItem.isJSON then
handleResponse(responseType(triggerItem.trigger))
errorMessage("Problem with response from waqi",true)
getAirQualityData()
}Debian buster, bullseye on RPI-4, Intel NUC.
- EdwinK
Going to try this
Now i see data getting into the sensors. Thanks everyone.
krommetje3108
- Domoticz version: 3.5877
I am using this code...
but stil get this error:
2019-06-08 09:48:12.521 Error: EventSystem: in Waqi: [string "--[[ ..."]:22: attempt to index global 'domoticz' (a nil value)
Any thoughts on how to make it work?
http://api.waqi.info/feed/geo:51.468096;5.631230/?token=TOKEN REMOVED = Helmond
http://api.waqi.info/feed/geo:51.544365;5.867349/?token=TOKEN REMOVED = Vedepeel (co)
http://api.waqi.info/feed/geo:51.544365;5.867349/?token=TOKEN REMOVED = Vedepeel (so2)
data = {
marker = "Waqi" },
local apiKey = "TOKEN REMOVED"
local defaultLocation = "51.468096;5.631230"
local sensorType
SO2 = "", -- if value for this item cannot be obtained from "nearby"
CO = "", -- else keep this as an empty string
PM25 = "",
PM10 = "",
O3 = "",
NO2 = "",
AQI = "",
local sensors = { SO2 = { sensor = 203, alert = 0}, -- enter device index Numbers or 0 for sensor and alert "
CO = { sensor = 204, alert = 0},
PM25 = { sensor = 205, alert = 0},
PM10 = { sensor = 206, alert = 0},
O3 = { sensor = 207, alert = 0},
NO2 = { sensor = 208, alert = 0},
if notify then
dz.notify(message)
method = "GET",
callback = callback
}).afterSec(delay)
local delay = 1
delay = delay + 30
return nil
getAirQualityData()
- waaren
Yes. You most likely saved it as a Lua script. It should be saved as a dzVents script.krommetje3108 wrote: Saturday 08 June 2019 10:01 I am using this code...
When not yet familiar with dzVents please start with reading Get started Before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
krommetje3108
Oops, do I feel a little bit .... (well you know)
For Nitrous Oxide, values are there
but....,
Update 10:48: I've put the station's Lat/Long in the script, now I've got Ozone PM2.5 and PM10 as well....Carbon Monide and SO2 still nothing
Perhaps this staion does not send them...
Here part of my Log:
2019-06-08 10:30:03.295 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.468096;5.631230/?token=TOKEN REMOVED
2019-06-08 10:30:03.295 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-08 10:30:03.295 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-08 10:30:03.295 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-08 10:30:03.296 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_nearby
2019-06-08 10:30:03.297 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-08 10:30:03.298 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-08 10:30:05.039 Status: dzVents: Info: Handling httpResponse-events for: "waqi_nearby
2019-06-08 10:30:05.039 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_nearby"
2019-06-08 10:30:05.117 Status: dzVents: Debug: Waqi: Processing device-adapter for Lachgasgehalte: Custom sensor device adapter
2019-06-08 10:30:05.117 Status: dzVents: Error (2.4.22): Waqi: An error occured when calling event handler Waqi_1
2019-06-08 10:30:05.118 Status: dzVents: Error (2.4.22): Waqi: ...pi/domoticz/scripts/dzVents/generated_scripts/Waqi_1.lua:135: attempt to index field '?' (a nil value)
2019-06-08 10:30:05.118 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-08 10:30:05.118 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
- waaren
Can you replace in your script the function handleResponse withkrommetje3108 wrote: Saturday 08 June 2019 10:36 > Yes. You most likely saved it as a Lua script. It should be saved as a dzVents script.
For Nitrous Oxide, values are therebut....,
Perhaps this station does not send them...
dz.log(triggerItem.data,dz.LOG_DEBUG)
dz.log("setDevice" .. setDevice, dz.log_DEBUG)
dz.log("idx" .. idx, dz.log_DEBUG)
dz.log("sensors[Type]" .. tostring(sensors[Type]), dz.log_DEBUG)
dz.log("rt" .. tostring(rt), dz.log_DEBUG)
dz.log("rt.data" .. tostring(rt.data), dz.log_DEBUG)
dz.log("rt.data.iaqi" .. tostring(rt.data.iaqi), dz.log_DEBUG)
dz.log("rt.data.iaqi[type]" .. tostring(rt.data.iaqi[type]), dz.log_DEBUG)
endDebian buster, bullseye on RPI-4, Intel NUC.
- FireWizard
Do you know that a Domoticz plugin for air quality exists?
See: https://openaq.org
Plugin: https://github.com/Xorfor/Domoticz-OpenAQ-Plugin
It's easier than inventing the wheel twice.
If you are in The Netherlands you can also use the script in this thread:
https://www.domoticz.com/forum/viewtopic.php?t=17334
Regards.
Regards.
krommetje3108
I am going to look into this..., thnksFireWizard wrote: Saturday 08 June 2019 22:23 Hi,
Regards.
krommetje3108
This will only add some extra debug logging
2019-06-09 07:46:02.042 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 07:46:31.996 Status: dzVents: Info: Handling httpResponse-events for: "waqi_nearby
2019-06-09 07:46:31.996 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_nearby"
2019-06-09 07:46:32.016 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 07:47:02.016 Status: dzVents: Info: Handling httpResponse-events for: "waqi_PM10
2019-06-09 07:47:02.016 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_PM10"
2019-06-09 07:47:02.094 Status: dzVents: Debug: Waqi: Processing device-adapter for Adembare grootfijnstof: Custom sensor device adapter
2019-06-09 07:47:02.096 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 07:47:02.096 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 07:45:32.056 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 07:45:32.057 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 07:46:01.962 Status: dzVents: Info: Handling httpResponse-events for: "waqi_CO
2019-06-09 07:46:01.962 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_CO"
2019-06-09 07:46:02.040 Status: dzVents: Debug: Waqi: Processing device-adapter for Koolmonoxide Buiten: Custom sensor device adapter
2019-06-09 07:46:02.042 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 07:47:32.004 Status: dzVents: Info: Handling httpResponse-events for: "waqi_O3
2019-06-09 07:47:32.005 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_O3"
2019-06-09 07:47:32.082 Status: dzVents: Debug: Waqi: Processing device-adapter for Ozongehalte: Custom sensor device adapter
2019-06-09 07:47:32.084 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 07:47:32.084 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 07:48:01.991 Status: dzVents: Info: Handling httpResponse-events for: "waqi_SO2
2019-06-09 07:48:01.991 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_SO2"
2019-06-09 07:48:02.010 Status: dzVents: Error (2.4.22): Waqi: An error occured when calling event handler Waqi_1
2019-06-09 07:48:02.010 Status: dzVents: Error (2.4.22): Waqi: ...pi/domoticz/scripts/dzVents/generated_scripts/Waqi_1.lua:134: attempt to index field '?' (a nil value)
2019-06-09 07:48:02.010 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:00:01.990 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1:, trigger: every 15 minutes
2019-06-09 08:00:01.992 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.544365;5.867349/?token=token_removed
2019-06-09 08:00:01.993 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-09 08:00:01.993 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-09 08:00:01.993 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.993 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_SO2
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.544365;5.867349/?token=token_removed
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_PM25
2019-06-09 08:00:01.994 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.841338;5.857758/?token=token_removed
2019-06-09 08:00:01.995 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-09 08:00:01.995 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-09 08:00:01.995 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.995 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_CO
2019-06-09 08:00:01.995 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.544365;5.867349/?token=token_removed
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_O3
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.468096;5.631230/?token=token_removed
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.996 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_nearby
2019-06-09 08:00:01.997 Status: dzVents: Debug: Waqi: OpenURL: url = http://api.waqi.info/feed/geo:51.544365;5.867349/?token=token_removed
2019-06-09 08:00:01.997 Status: dzVents: Debug: Waqi: OpenURL: method = GET
2019-06-09 08:00:01.997 Status: dzVents: Debug: Waqi: OpenURL: post data = nil
2019-06-09 08:00:01.997 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.997 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_NO2
2019-06-09 08:00:01.998 Status: dzVents: Debug: Waqi: OpenURL: headers = nil
2019-06-09 08:00:01.998 Status: dzVents: Debug: Waqi: OpenURL: callback = waqi_PM10
2019-06-09 08:00:01.999 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:00:02.002 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 08:00:03.739 Status: dzVents: Info: Handling httpResponse-events for: "waqi_SO2
2019-06-09 08:00:03.739 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_SO2"
2019-06-09 08:00:03.758 Status: dzVents: Error (2.4.22): Waqi: An error occured when calling event handler Waqi_1
2019-06-09 08:00:03.758 Status: dzVents: Error (2.4.22): Waqi: ...pi/domoticz/scripts/dzVents/generated_scripts/Waqi_1.lua:134: attempt to index field '?' (a nil value)
2019-06-09 08:00:03.759 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:00:33.797 Status: dzVents: Info: Handling httpResponse-events for: "waqi_PM25
2019-06-09 08:00:33.797 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_PM25"
2019-06-09 08:00:33.876 Status: dzVents: Debug: Waqi: Processing device-adapter for Fijnstof: Custom sensor device adapter
2019-06-09 08:00:33.878 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:00:33.879 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 08:01:03.779 Status: dzVents: Info: Handling httpResponse-events for: "waqi_CO
2019-06-09 08:01:03.779 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_CO"
2019-06-09 08:01:03.862 Status: dzVents: Debug: Waqi: Processing device-adapter for Koolmonoxide Buiten: Custom sensor device adapter
2019-06-09 08:01:03.865 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:01:03.865 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 08:01:33.880 Status: dzVents: Info: Handling httpResponse-events for: "waqi_O3
2019-06-09 08:01:33.881 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_O3"
2019-06-09 08:01:33.907 Status: dzVents: Debug: Waqi: Processing device-adapter for Ozongehalte: Custom sensor device adapter
2019-06-09 08:01:33.909 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:01:33.910 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 08:02:03.764 Status: dzVents: Info: Handling httpResponse-events for: "waqi_nearby
2019-06-09 08:02:03.765 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_nearby"
2019-06-09 08:02:03.786 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:02:33.770 Status: dzVents: Info: Handling httpResponse-events for: "waqi_NO2
2019-06-09 08:02:33.770 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_NO2"
2019-06-09 08:02:33.852 Status: dzVents: Debug: Waqi: Processing device-adapter for Lachgasgehalte: Custom sensor device adapter
2019-06-09 08:02:33.854 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
2019-06-09 08:02:33.854 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-09 08:03:03.756 Status: dzVents: Info: Handling httpResponse-events for: "waqi_PM10
2019-06-09 08:03:03.757 Status: dzVents: Info: Waqi: ------ Start internal script: Waqi_1: HTTPResponse: "waqi_PM10"
2019-06-09 08:03:03.840 Status: dzVents: Debug: Waqi: Processing device-adapter for Adembare grootfijnstof: Custom sensor device adapter
2019-06-09 08:03:03.842 Status: dzVents: Info: Waqi: ------ Finished Waqi_1
- waaren
The station eibergen-lintveldseweg (52.1;6.65) seems to be the station nearest to you that does report so2 datakrommetje3108 wrote: Sunday 09 June 2019 8:15 as far As I can tell the script works fine so I think the sensordata for Idx203 mis not sent by waqi.info...
krommetje3108
Everthing works now!!! Thanx All
mojso
i use this script
i get all the values but i get this error
2019-11-11 15:30:00.835 Error: dzVents: Error: (2.5.0) Waqi: An error occurred when calling event handler AirQ4
2019-11-11 15:30:00.835 Error: dzVents: Error: (2.5.0) Waqi: .../pi/domoticz/scripts/dzVents/generated_scripts/AirQ4.lua:136: bad argument #1 to 'for iterator' (table expected, got nil)
timer = { "every 5 minutes" },
data = {
marker = "Waqi" },
local apiKey = "REMOVED"
local defaultLocation = "42.00997;20.97114"
local sensorType
so2 = "", -- if value for this item cannot be obtained from "nearby"
co = "", -- else keep this as an empty string
pm25 = "",
pm10 = "",
o3 = "",
no2 = "",
aqi = "",
local sensors = { so2 = { sensor = 62, alert = 63 }, -- enter device index Numbers or 0 for sensor and alert "
co = { sensor = 64, alert = 65 },
pm25 = { sensor = 66, alert = 67 },
pm10 = { sensor = 68, alert = 69 },
o3 = { sensor = 70, alert = 71 },
no2 = { sensor = 72, alert = 73 },
aqi = { sensor = 76, alert = 75 , aqiSensor = 74}, -- additional Air Quality sensor
if notify then
dz.notify(message)
method = "GET",
callback = callback
}).afterSec(delay)
local delay = 1
delay = delay + 30
return nil
getAirQualityData()
