I've got a few Neo CoolCam PIR Motion Sensors v2's with temperature but i cannot set the the following settings (copied from Fibaro Smoke Sensor):
20. Temperature report interval:
Time interval between consecutive temperature reports. Report is sent when new temperature value is different from the one previously reported - according to the set hysteresis (parameter 21). Available settings: 0,1-8640 (multiply by 10 seconds) [10s-24h]. Default setting: 1 (10s)
21. Temperature report hysteresis:
The temperature report will only be sent if there is a difference in temperature value from the previous value reported, defined in this parameter (hysteresis). Available settings: 1 to 100 (in 0,1C steps). Default setting: 10 (1C)
These settings are not available in the Z-wave nodes list.
Neo CoolCam PIR Temperature settings
terrorsource
Re: Neo CoolCam PIR Temperature settings
I think that that device does not support those settings.
There is a: 7. Light Sensor Polling Interval
Lux and Temp come at the same interval.
