Update switch status using LUA
mvveelen
Post by mvveelen »
I have a bash script which can be used to control the airco units. This script van also be used to get the status of the units.
./airco.sh 192.168.0.60 set power on
./airco.sh 192.168.0.60 set speed 2
./airco.sh 192.168.0.60 set mode cool
etc.
The status van be read:
pi@pidomoticz:~ $ /home/pi/airco.sh 192.168.0.60 get speed
4
pi@pidomoticz:~ $ ./airco.sh 192.168.0.60 get power
1
pi@pidomoticz:~ $ ./airco.sh 192.168.0.60 get speed
4
pi@pidomoticz:~ $ ./airco.sh 192.168.0.60 get mode
4
pi@pidomoticz:~ $ ./airco.sh 192.168.0.60 get vane
10
pi@pidomoticz:~ $ ./airco.sh 192.168.0.60 get setpoint
220
etc.
And the results are always a number (220 = 22 degrees Celsius)
The Lua script I use:
print('=========== airco script start ============')
aircoValuePowerSK = os.execute('/home/pi/airco.sh 192.168.0.60 get speed')
commandArray['OpenURL'] = 'http://192.168.0.126:8080/json.htm?type=command&param=udevice&idx=735&nvalue=1&svalue=' .. aircoValuePowerSK;
print('=========== airco script eind ============')
But, I get an error message:
Error: EventSystem: in Airco_status: [string "commandArray = {}..."]:6: attempt to concatenate global 'aircoValuePowerSK' (a boolean value)
How can this be fixed?
In short: I want the status in Domoticz to reflect the status also when I use the IR controller or the iPhone app. So, the corresponding value must be read (get) and then sent to the virtual switch in Domoticz.
I hope someone can help me out.
jvdz
Domoticz version: 4.107
Re: Update switch status using LUA
Post by jvdz »
What About something like this?:
local f = assert(io.popen('/home/pi/airco.sh 192.168.0.60 get speed', 'r'))
local aircoValuePowerSK = assert(f:read('*a'))
f:close()
Jos
mvveelen
Post by mvveelen »
Hi Jos,
thanks. I just saw your solution and I'm going to try it.
This is what I had:
local aircoValuePowerZK = io.popen('/home/pi/airco.sh 192.168.0.61 get power') -- runs command
local aircoValuePowerZKval = aircoValuePowerZK:read("*a") -- read output of command
commandArray['UpdateDevice'] = "715|" .. tostring(aircoValuePowerZKval) .. "|" .. tostring(aircoValuePowerZKval) .. "|"
And that kinda works. But I'm having some troubles getting everything tied together, see: viewtopic.php?f=61&t=24287
