Blocky: Run LUA script with a delay of x seconds
Ritmeester
Post by Ritmeester »
In Blocky I run a LUA script. I want to run this script with a delay of x seconds.
Is this possible?
leonmoonen
Domoticz version: current
Post by leonmoonen »
You could change the lua script so it starts with a delay/sleep. Here are some suggestions on building a sleep function in lua: http://lua-users.org/wiki/SleepFunction
Re: Blocky: Run LUA script with a delay of x seconds
leonmoonen wrote: Sunday 22 July 2018 11:21
Ritmeester wrote: Sunday 22 July 2018 8:34 In Blocky I run a LUA script. I want to run this script with a delay of x seconds.
Is this possible?
Probably not an ideal solution as the event system in domoticz is single threaded. So it will have to wait until the lua script with the delay is finished.
Better to use a workaround by creating a virtual device or variable that you switch / set with the afterSeconds option and let that device / var trigger the next script.
leonmoonen
Wow, I had fully expected that such ‘secondary’ scripts (i.e., started in a event handling script like blockly) would be executed on the background...
Is there a reason not to do so (except if you’d want to get a value back)?
leonmoonen wrote: Sunday 22 July 2018 11:52 Wow, I had fully expected that such ‘secondary’ scripts (i.e., started in a event handling script like blockly) would be executed on the background...
If it is external script (so started from os level) you can use the OS mechanism for running it in the background. So in linux you could start it with a trailing &.
Ritmeester
Thank you all for the answers. I didn’t know of this “Single Threaded” so I made a virtual switch and let this switch do the job.
All is working perfect now.
EDIT: Extra info.
The sleep command in LUA wil generate this error message:
Error: EventSystem: Warning!, lua script Post Box Switch has been running for more than 10 seconds
