บาคาร่าออนไลน์
D-Link, Zipato and Philio multi-sound sirens
harry56
Re: D-Link, Zipato and Philio multi-sound sirens
Has anyone got the PH-PSE02 working with Domoticz? I've seen an update in openzwave v1.5 https://github.com/OpenZWave/open-zwave ... /ChangeLog I've seen some blockly setups via google images on zipato forums, but no sign of a working configuration with Domoticz. I'm wondering because I might want to buy a PH-PSE02 for use with Domoticz.
Domoticz 2025.2 on Ubuntu 24.04 LTS VM (ESXi 7u3s)
SolarEdge/webAPI, SE2MQTT/modbus IP, Zigbee2MQTT/Sonoff ZB3.0+, ZWave-JS-UI/ZMEEUZB1, MQTT AD Client Gw, P1 mtr, RFXCOM433E, Philips Hue v2, Kodi, Panasonic TV, BuienRadar & Watermtr/HTTP/HTTPS poll
Darthkatzs
I'm a bit disappointed that this has still not been implemented yet even though 5 large brands are selling this type of siren. This is forcing us to move to their proprietary software.
I know this is open source and free but I'm perfectly willing to donate when this feature gets implemented. I've already paid the 5 euros through the IOS app as a token of support.
I'm not having to look for a speaker for my Raspberry to send notification sounds as I can only trigger the actual alarm from the siren.
fergalom
Just got a Zipato siren and only coming to realisation that the other sounds are not accessible.
Anyone found a solution?
I did find this on https://api.telldus.com/ in my searches for a solution.
https://github.com/telldus/tellstick-lu ... /Siren.lua
Could this work in domoticz through lua? (will try myself but any lua experts know)The Siren from Philio (PSE02) is sold as a multi sound device, but to make it play other sounds it has to receive a NOTIFICATION_REPORT. This report is normally sent out from a sensor such as a PIR or door/window-sensor. That means it's possible to e.g. play a Door Chime sound when a door/window-sensor is opened.
When sending a SWITCH_BINARY_SET (which is the default command that will be sent to this device from TellStick ZNet) will only make it play the default emergency sound.
In order to play other sounds, a NOTIFICATION_REPORT has to be sent out from TellStick - that can be done from a Lua-script.
We've put together a script that can send out the NOTIFICATION_REPORT when a device (or dummy-device) is turned on, it's available here: https://github.com/telldus/tellstick-lu ... /Siren.lua
fergalom
ANybody get this to work in Domoticz with the other sounds?
