Zigbee2MQTT
1981nick1981
Zigbee2MQTT
Post by 1981nick1981 »
During my experiments with home assistant I came across the project zigbee2mqtt. This project uses parts that are available on Ali Express to make a zigbee hub. Which makes the hub of xiaomi, hue, ikea, etcetera unnecessary. I think this will probably also work with domoticz.
https://github.com/Koenkk/zigbee2mqtt
Wiki:
https://github.com/Koenkk/zigbee2mqtt/wiki
blauwebuis
Domoticz version: current
Re: Zigbee2MQTT
Post by blauwebuis »
Did you get this to work? Looks awesome.
1981nick1981
Re: Zigbee2MQTT
This works well in Home Assistant. Even the Aqara cube that does not work via the gateway works with this. Normally this should also be able to work with domoticz, but then a driver needs to be made.
blauwebuis
Re: Zigbee2MQTT
A driver?
Isn't this already a driver that translates signals to MQTT? So doesn't Domoticz just need to pull in the MQTT messages?
EddyG
Re: Zigbee2MQTT
Post by EddyG »
I got it running on my test system.
The reason I am doing this that my Xiaomi gateway only connects to a Chinees server.
So all? traffic is going to China, and I do not want that.
Now I am looking for a way to translate to messages to the 'domoticz/in' and 'domoticz/out'
The topics I get are:
domoticz/bridge/log
domoticz/0x00158d00022cbcad
where 0x00158d00022cbcad is the Zigbee device (address).
Could anyone point me the way how to resolve this?
jvdz
Domoticz version: 4.107
Re: Zigbee2MQTT
Post by jvdz »
EddyG wrote: Thursday 19 July 2018 21:46 Now I am looking for a way to translate to messages to the 'domoticz/in' and 'domoticz/out'
domoticz/bridge/log
Interesting topic.
Node-red should be able to receive, translate and send those message to Domoticz.
Jos
EddyG
Re: Zigbee2MQTT
Post by EddyG »
I got it almost working in node-red.
I already converted this output from the zigbee device
{ temperature: 26.29, humidity: 57.7, pressure: 1004, battery: "88.33", voltage: 2965 }
to
{ idx: 21, nvalue: 0, svalue: 26.29 }
My domoticz log shows:
2018-07-21 12:34:15.639 MQTT: Topic: domoticz/in, Message: {"idx":21,"nvalue":0,"svalue":25.9}
2018-07-21 12:34:15.438 Error: MQTT: Invalid data received!
The problem lies proberly in the "svalue":25,9
How can I convert the property "svalue":25,9 to "svalue": "25,9" (2 double quotes extra for string.)
Because when I do this command it works.
 mosquitto_pub -h localhost -m '{ "idx" : 21, "nvalue" : 0, "svalue" : "25.0" }' -t 'domoticz/in'
I am new in node-red, so it might be very simpel
EddyG
Re: Zigbee2MQTT
Post by EddyG »
In the meantime I found the answer.
I put a function inbetween the JSON output and the assembly of the new JSON object.
The .toString() did the job, like I wrote, its easy.
But there might be better ways to do it, please tell....
At the end I now have Zigbee2MQTT hardware and software working with domoticz without the Chinese in the middle.
And btw it is cheap too. Total cost for controller and flashing tool from AliExpress € 22,32
I go on trying to connect other Zigbee devices too.
I also got the joined Temperature/Humidity device working, but only with a fixed Humidity status of 'Comfortable'
Barometer device (same unit) is working too.
Does anyone have a javascript to calculate Temperature and Humidity to a Humidity Status?
Does anyone have an idea how to calculate the Prediction?
EddyG
Re: Zigbee2MQTT
Post by EddyG »
:D Got humidity status and prediction working too.
Node-red is more valuable then I tought. :D
ben53252642
Re: Zigbee2MQTT
Post by ben53252642 »
This needs to be integrated into Domoticz asap!
Finally a solution to replace the 3 proprietary zigbee hubs in my setup. Will lower the cost of using Zigbee since I won't need to maintain 3 separate hubs and reduce power usage. :)
I've just ordered a few dongles (I always keep a couple of spare controllers), I don't have the skills to integrate this directly into Domoticz but I can create scripts to do it manually.
tezzlicious
Re: Zigbee2MQTT
Post by tezzlicious »
Just got it up and running. Has some great potential. The range is also quite nice, picking up the Aqara Door Sensor from approx. 25-30 meters in the garden with 2 walls in between. Wish I had the time to explore it further. Looking forward to progress being made on this.
ben53252642
Re: Zigbee2MQTT
Hardware requirements
I was able to get:
1x CC Debugger
https://www.aliexpress.com/item/Wholesa ... 74637.html
1x Download cable
https://www.aliexpress.com/item/Downloa ... 78130.html
3x CC2531 USB Adapters
https://www.aliexpress.com/item/Wireles ... 63830.html
With epacket delivery 13 - 20 days to Australia for a total of $72.23 AUD.
Pretty reasonable considering I got THREE usb adapters when I'd usually be paying around $85 AUD for a single Z-Wave stick...
EddyG
Re: Zigbee2MQTT
Post by EddyG »
tezzlicious wrote: Saturday 21 July 2018 17:07 Just got it up and running. Has some great potential. The range is also quite nice, picking up the Aqara Door Sensor from approx. 25-30 meters in the garden with 2 walls in between. Wish I had the time to explore it further. Looking forward to progress being made on this.
Did also get the data in Domoticz via Node-red, or an other way?
jvdz
Re: Zigbee2MQTT
Post by jvdz »
EddyG wrote: Saturday 21 July 2018 16:28 :D Got humidity status and prediction working too.
Could you share the node-red code please as I like to do something similar?
Cheers,
Jos
EddyG
Re: Zigbee2MQTT
Post by EddyG »
Sure, no problem. I was already intended to do that.
I got these running.
https://xiaomi-mi.com/sockets-and-senso ... ty-sensor/
https://xiaomi-mi.com/sockets-and-senso ... cy-sensor/
B.t.w. these Xiaomi sensor do not publish battery every time.
So sometimes I got a reading and sometimes not, and then 'null' will be published and then ofcourse no battery data in Domoticz.
I have to figure out how to solve that, but it could be better solved in Domoticz by not replacing the data with nothing.
This is my Node-red first ever, so coding might not be the best way, so please correct if there is a more efficient way.
This was more like a quick and dirty to see if it works.
My test domoticz is currently running the Zigbee controler and Node-red and is publishing to my mosquitto on the production system.
Of couse you have to change the servers and zigbee device addresses in the code.
[{"id":"74016149.f403","type":"mqtt in","z":"8188c534.77e7e8","name":"THB","topic":"zigbee2mqtt/0x00158d00022cbcad","qos":"2","broker":"54b04e64.e1422","x":210,"y":240,"wires":[["3bd30ad7.b12a16"]]},{"id":"73b1b108.435a8","type":"debug","z":"8188c534.77e7e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":990,"y":180,"wires":[]},{"id":"705118a8.0cf9d8","type":"comment","z":"8188c534.77e7e8","name":"Xiaomi Mi Smart Home Temperature / Humidity Sensor","info":"https://xiaomi-mi.com/sockets-and-sensors/aqara-temperature-and-humidity-sensor/\n\nWSDCGQ11LM","x":360,"y":160,"wires":[]},{"id":"3bd30ad7.b12a16","type":"json","z":"8188c534.77e7e8","name":"","property":"payload","action":"","pretty":false,"x":370,"y":240,"wires":[["a4376d59.45fef"]]},{"id":"989fbc27.9c0e1","type":"change","z":"8188c534.77e7e8","name":"Temperature Humidity","rules":[{"t":"delete","p":"payload.pressure","pt":"msg"},{"t":"delete","p":"payload.humidity","pt":"msg"},{"t":"delete","p":"payload.voltage","pt":"msg"},{"t":"set","p":"payload.idx","pt":"msg","to":"552","tot":"num"},{"t":"set","p":"payload.nvalue","pt":"msg","to":"0","tot":"num"},{"t":"move","p":"payload.temphumi","pt":"msg","to":"payload.svalue","tot":"msg"},{"t":"delete","p":"payload.temperature","pt":"msg"},{"t":"move","p":"payload.battery","pt":"msg","to":"payload.Battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":240,"wires":[["b50d2c76.b8846","73b1b108.435a8"]]},{"id":"b50d2c76.b8846","type":"mqtt out","z":"8188c534.77e7e8","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"a61018b4.359498","x":990,"y":240,"wires":[]},{"id":"a4376d59.45fef","type":"function","z":"8188c534.77e7e8","name":"Convert THB","func":"var temp = msg.payload.temperature;\nvar humi = msg.payload.humidity;\nvar pres = msg.payload.pressure;\nvar batt = msg.payload.battery;\nvar forecast = \"5\"\nvar humistat = \"5\"\n\nif (pres < 966) {\n    forecast = \"4\"\n} else if (pres < 993) {\n    forecast = \"3\"\n} else if (pres < 1007) {\n    forecast = \"2\"\n} else if (pres < 1013) {\n    forecast = \"1\"\n} else {\n    forecast = \"0\"\n}\n\nif (humi < 31) {\n    humistat = \"2\"\n} else if (humi > 69) {\n    humistat = \"3\"\n} else if (humi > 34 && humi < 66 && temp > 21 && temp < 27) {\n    humistat = \"1\"\n} else {\n    humistat = \"0\"\n}\n\n\nmsg.payload.temperature = temp.toString();\nmsg.payload.humidity = humi.toString();\nmsg.payload.pressure = pres.toString()+\";\"+forecast;\nmsg.payload.battery = Math.round(batt);\nmsg.payload.temphumi = temp.toString()+\";\"+humi.toString()+\";\"+humistat;\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":240,"wires":[["989fbc27.9c0e1","d882ea2c.a7b6f8"]]},{"id":"d882ea2c.a7b6f8","type":"change","z":"8188c534.77e7e8","name":"Barometer","rules":[{"t":"delete","p":"payload.voltage","pt":"msg"},{"t":"delete","p":"payload.temperature","pt":"msg"},{"t":"delete","p":"payload.humidity","pt":"msg"},{"t":"delete","p":"payload.temphumi","pt":"msg"},{"t":"set","p":"payload.idx","pt":"msg","to":"553","tot":"num"},{"t":"set","p":"payload.nvalue","pt":"msg","to":"0","tot":"num"},{"t":"move","p":"payload.pressure","pt":"msg","to":"payload.svalue","tot":"msg"},{"t":"move","p":"payload.battery","pt":"msg","to":"payload.Battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":320,"wires":[["af0169ca.91a728","182fe774.2ff9c9"]]},{"id":"af0169ca.91a728","type":"debug","z":"8188c534.77e7e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":990,"y":380,"wires":[]},{"id":"182fe774.2ff9c9","type":"mqtt out","z":"8188c534.77e7e8","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"a61018b4.359498","x":990,"y":320,"wires":[]},{"id":"40149863.198668","type":"comment","z":"8188c534.77e7e8","name":"Xiaomi Mi Smart Home Occupancy Sensor","info":"https://xiaomi-mi.com/sockets-and-sensors/xiaomi-mi-occupancy-sensor/\n\nRTCGQ01LM","x":320,"y":440,"wires":[]},{"id":"614e4d93.e19474","type":"mqtt in","z":"8188c534.77e7e8","name":"PIR Zolder","topic":"zigbee2mqtt/0x00158d0001b192fd","qos":"2","broker":"54b04e64.e1422","x":220,"y":520,"wires":[["f673a083.e94cc"]]},{"id":"da1292d5.8d0d4","type":"debug","z":"8188c534.77e7e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":990,"y":580,"wires":[]},{"id":"f673a083.e94cc","type":"json","z":"8188c534.77e7e8","name":"","property":"payload","action":"","pretty":false,"x":370,"y":520,"wires":[["bb6c57b.96869a8"]]},{"id":"bb6c57b.96869a8","type":"function","z":"8188c534.77e7e8","name":"Convert PIR","func":"var occu = msg.payload.occupancy;\nvar batt = msg.payload.battery;\n\nif (occu === true) {\n    msg.payload.occupancy = \"On\";\n} else {\n    msg.payload.occupancy = \"Off\";\n}\nmsg.payload.battery = Math.round(batt);\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":520,"wires":[["4d650218.b6d83c"]]},{"id":"4d650218.b6d83c","type":"change","z":"8188c534.77e7e8","name":"Motion","rules":[{"t":"delete","p":"payload.voltage","pt":"msg"},{"t":"set","p":"payload.command","pt":"msg","to":"switchlight","tot":"str"},{"t":"set","p":"payload.idx","pt":"msg","to":"554","tot":"num"},{"t":"move","p":"payload.occupancy","pt":"msg","to":"payload.switchcmd","tot":"msg"},{"t":"move","p":"payload.battery","pt":"msg","to":"payload.Battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":520,"wires":[["da1292d5.8d0d4","bc3f7964.9da148"]]},{"id":"bc3f7964.9da148","type":"mqtt out","z":"8188c534.77e7e8","name":"","topic":"domoticz/in","qos":"","retain":"","broker":"a61018b4.359498","x":990,"y":520,"wires":[]},{"id":"54b04e64.e1422","type":"mqtt-broker","z":"","name":"Zigbee","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"domoticz/bridge/state","birthQos":"0","birthPayload":"online","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"a61018b4.359498","type":"mqtt-broker","z":"","name":"Domoticz","broker":"domoticz.local","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
jvdz
Re: Zigbee2MQTT
Post by jvdz »
Thanks for sharing the code... Looks fine to me but Iám not a Node-red buff either yet. :D
I think you took the logic for the forcast from buien radar?
Either way I believe you missed one piece of the logic and think it should be:
	if (pres < 966) {
		forecast = "4"
		forecast = "3"
		forecast = "2"
		forecast = "3"
	} else if (pres < 1033) {
		forecast = "0"
	} else {
		forecast = "1"
Jos
EddyG
Re: Zigbee2MQTT
Post by EddyG »
Tnx. Yes I found the code logic in buienrader and was to hasty. :mrgreen:
And the initialisation of the vars I now set to:
var forecast = "1"
var humistat = "0"
ben53252642
Re: Zigbee2MQTT
EddyG I've successfully imported your code into Node-Red (very nice)!
One thing I noticed, you have seperate temp+hum and baro sensor (idx 552 and 553), you know you can have a combined Temp+Hum+Baro sensor in Domoticz?
Look in the create virtual sensor.
EddyG
Re: Zigbee2MQTT
Post by EddyG »
Yes, I know.
But I 'hate' the fact that those devices have the same name in both Domoticz Menus.
That is why I seperated those devices. But you can ofcourse have output to 1 Domoticz device.
ben53252642
Re: Zigbee2MQTT
EddyG wrote: Sunday 22 July 2018 9:58 sometimes I got a reading and sometimes not, and then 'null' will be published and then ofcourse no battery data in Domoticz.
Try this example (editing as needed) for the battery, if the result is not more than 1 it should fail so a null doesn't get sent.
-- inputvoltage
var inputvoltage = msg.payload[1].value;
    inputvoltagestr = inputvoltage.toString();
    inputvoltageint = inputvoltagestr.substring(0, inputvoltagestr.length-1);
if (inputvoltageint > 1) {
    msg.payload.inputvoltage = inputvoltageint
Put this in a debug connected to it: msg.payload.inputvoltage
