LUA: To many Telegram messages
Twoink
Post by Twoink »
Hi All,
I have the following script to switch on a Fan (433 KAKU switch) if the temperature reaches a certain level.
The script will also send a Telegram message, but.... it looks like "commandArray['Solar: Fan'] = "On" is executed 5 times, so i will receive the message also 5 times.
Does someone have a solution for this issue?
Regards Twoink :D
function Telegram(message)
    local bot = 'XXXX'; -- Telegram Bot ID
    local token = 'XXXXX'; -- Telegram Bot Token
    local chatId = 'XXXXX'; -- Telegram Chat ID
	os.execute('curl --data chat_id='..chatId..' --data-urlencode "text='..message..'"  "https://api.telegram.org/bot'..bot..':'..token..'/sendMessage" ')
	return
-------------DEVICES----------------
local fan                   	= otherdevices['Solar: Fan']
local temp       		= otherdevices_temperature['Solar: Temperature']
-------------SETTINGS----------------
local Set_switch_off_temp   = 35
local Set_switch_on_temp    = 43
-- START SCRIPT
if (temp >= Set_switch_on_temp and fan == "Off") then
    Telegram("Fan is switched ON")
elseif (omvormer_temp <= Set_switch_off_temp and fan == "On") then
    commandArray['Solar: Fan'] = "Off"
    Telegram("Fan is switched OFF")
emme
Domoticz version: latest
Re: LUA: To many Telegram messages
Post by emme »
5 times means the script is fired 5 times
if you use pure LUA script (instead of dzVents) you should also ensure your FAN device is within the changed devices
When a script device is fired domoticz will pass the devicechanged table to the script, you should use it to ensure the device is included
your script runs on temp change... good!
	return
local tempName = 'Solar: Temperature'
local temp       		= otherdevices_temperature[tempName]
-- START SCRIPT
if (devicechanged[tempName] ~= nil) then
"We always done this way"
Twoink
Post by Twoink »
emme wrote: Monday 16 July 2018 12:45 5 times means the script is fired 5 times
Thanks for your reply! It helped, but i don't understand your explanation. How do i ensure that the device is included in the table?
freijn
Domoticz version: Stable
Post by freijn »
Interested in answer as well. :-)
jvdz
Domoticz version: 4.107
Post by jvdz »
I am not sure why this script can work at all as the variable "omvormer_temp" is nowhere defined!
I also assume this script is a device script and not a time script, which I think you normally would use for this purpose.
Normally you want to run this script either one time per minute(script_time_????.lua) or only when one particular device changes. The latter is done by checking for the device with the statement: if devicechanged[tempName] then
This will ensure the rest of the logic is only performed when that temp actually changed.
Jos
emme
Post by emme »
Ciao,
sorry for the delay in reply, just back from my vacation today :P :P
can you please try to convert your script in dzVents as follow?
	return
		devices = { tempName }
        local temp = domoticz.devices(tempName).temperature
        local fan  = domoticz.devices('Solar: Fan').state
        if temp >= Set_switch_on_temp  then
            domoticz.devices('Solar: Fan').switchOn().checkFirst()
        elseif temp < Set_switch_off_temp  then
            domoticz.devices('Solar: Fan').switchOff().checkFirst()
