Smart Meter Integration
Hi. I’ve been trying to get a smart meter fitted for some time now with the intention of collecting the data with Domoticz. However, it was installed yesterday and I was disappointed to find the one I have, a Secure Liberty 100, doesn’t have a cable port so I cant connect a P1. From the documentation it looks like it is compatible with Zigbee so I’m wondering if this is the road to go down but that may be beyond my limited technical capabilities. Does anyone have any experience of collection data from this meter or able to point me in the right direction please?
- philchillbill
Re: Smart Meter Integration
The spec sheet for your smart meter says that GPRS and zigbee are options, not necessarily standard. It lists an 'Optical IEC62056-21 (IEC1107) hardware-compatible port' as standard. Google what options exist to read that out.
- emme
- Domoticz version: latest
probably the optical port would pulse on consumption...
try to see it through a video camera and see if you see any light
"We always done this way"
Thanks for your reply. Yes, I used to use the optical on my old electric meter with mysensors to grab energy use. Never been able to do that with my old gas meter though. I'll need to check to see if the new one has optical IEC1107 and, if so, possibly go along the mysensors route with this. It's a Secure Liberty eg4v11 which has only just been released. I can only find info on the eg4v10 which does have one. Hopefully this will be the same.Thank you.
- emme
the onboard optical link is IEC1107 compatible as per tech sheet and as per @philchillbill already wrote on the second post
http://www.securemeters.com/index.php/p ... berty-100/
Yes, I can see there is an optical link on the Liberty 100 electric meter. Unfortunately, I can’t see that there is one on the Secure Liberty eg4v11 gas meteremme wrote: ↑Friday 13 July 2018 11:23 the onboard optical link is IEC1107 compatible as per tech sheet and as per @philchillbill already wrote on the second post
Who is your supplier?
I’m with Tonik energy.
Sorry for not getting back but this is what you want https://shop.glowmarkt.com/products/glo ... art-meters I believe.
Thank you. I'll look into this
