I have run a Blockly Event with a Fibaro Plug that switches a 433mhz Plug on when there is kwh > 2
So if my Coffeemachine is going on the light above turns on.
The Function is Correct, but every Second the Log gets: EventSystem: Event triggered: Light Coffee
(RFX433) Lighting 1 (Diner LED Coffee)
Is that normal?
Event Triggered every Second
- jvdz
- Domoticz version: 4.107
Re: Event Triggered every Second
No, so you likely have a logic error testing for status and switching the same switch.
It would help when you show your blockly logic.
Jos
Jos
i dont know how to put the Blockly Event here so i take a Photo
- jvdz
yea... stamp sizedozen wrote: Thursday 12 July 2018 16:31 i dont know how to put the Blockly Event here so i take a Photo![]()
Anyways, Just add an AND to both to test the status of "Diner LED Coffee" so it looks like:
If "Fibaro gen5 kwh".actual >= 5 and "Diner LED Coffee" = "Off" then
Set "Diner LED Coffee" = "On"
ElseIf "Fibaro gen5 kwh".actual <= 5 and "Diner LED Coffee" = "On" then
Set "Diner LED Coffee" = "Off"Re: Event Triggered every Second
I Think its a Problem with the Fibaro, he sends a lot of Status Messages
2018-07-12 20:27:14.478 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:15.142 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:15.442 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:17.210 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:17.524 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:19.159 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:19.464 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:20.425 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:20.729 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:42.160 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:42.466 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:43.161 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:43.456 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:44.231 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:44.510 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:45.173 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:45.470 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:27:51.181 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:27:51.794 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:12.140 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:12.440 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:14.510 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:14.812 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:15.213 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:15.519 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:16.160 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:16.459 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
2018-07-12 20:28:18.158 (Aeotec Z-Stick) Usage (Fibaro Gen5)
2018-07-12 20:28:18.443 (Aeotec Z-Stick) General/kWh (Fibaro Gen5 kw/h)
So now i have changed the Problem from event triggering to this
gerardsoraya
- Domoticz version: 2024.7
The way jos says it have to work because jou dont have a check right now. Every second the system sees the usage is above so i do an action.dozen wrote:I Think its a Problem with the Fibaro, he sends a lot of Status Messages
Verstuurd vanaf mijn SM-G965F met Tapatalk
Rpi 4
rflink 433 mhz
Philips hue
p1 smart meter cable
P1 smart meter solar
Lyric t6
rflink 433 mhz
Philips hue
Lyric t6
I must remove the „if its on then turn it off“ command because sometimes i need the Light Permanentlyjvdz wrote:yea... stamp sizedozen wrote: Thursday 12 July 2018 16:31 i dont know how to put the Blockly Event here so i take a Photo![]()
Anyways, Just add an AND to both to test the status of "Diner LED Coffee" so it looks like:JosCode: Select all
If "Fibaro gen5 kwh".actual >= 5 and "Diner LED Coffee" = "Off" then Set "Diner LED Coffee" = "On" ElseIf "Fibaro gen5 kwh".actual <= 5 and "Diner LED Coffee" = "On" then Set "Diner LED Coffee" = "Off"
Gesendet von iPhone mit Tapatalk
terrorsource
You need to have some kind of check in your script. this way it always triggers each second because nothing changed. this is as designed.
The IF ELSE from @jdvz is what you need to use.
mrf68
But remove one of the = , because using “if >= 5” and “else if <= 5” would be nasty when usage = 5.
