domoticz to MQTT topic
emme
Domoticz version: latest
Post by emme »
Ciao,
Since the MQTT messages are almost a replication of the Log, it is quite a mess to work with them, the only way to work with it is to grab the IDX value.
I have few flows in node-red that handle lights/group, multimedia devices and security.
those 3 blocks are handled by a switch block that gets the IDX and do what it is supposed to do...
actually the message sent is the followig:
 "idx" : 5,
 "name" : "Internal Temperature",
 "id" : "00080A",
 "unit" : 1
 "dtype" : "Temp",
 "stype" : "TFA 30.3133",
 "nvalue" : 0,
 "svalue1" : "41.2",
 "Battery" : 100,
 "RSSI" : 12,
I was wondering if there is the possibility to assign a MQTT topic to each device and add it payload sent...
 "idx" : 5,
 "id" : "00080A",
 "unit" : 1
 "dtype" : "Temp",
 "nvalue" : 0,
 "svalue1" : "41.2",
 "Battery" : 100,
 "RSSI" : 12,
 "topic": "TempSensors"
this way it would be much more easy to understand what device has done what... :P
thanks
ciao
M
"We always done this way"
Charley
Domoticz version: V3.9030
Re: domoticz to MQTT topic
Post by Charley »
Hello Emme,
If the topic is added to the object that Domoticz sends out you can't filter just the topic out.
In that case you need to make a switch to determine your topic.
if domoticz/out/tempsensors you only receive the topic your are subscribed to from your broker.
better would be:
domoticz/out/sensors/temperature
domoticz/out/sensors/humidity
or
domoticz/out/sensors (as general)
