EdddieN
Domoticz version: 4.9700
Re: machinon theme - (work in progress)
Post by EdddieN »
landaisbenj wrote: Tuesday 10 July 2018 8:52 Hello ;D
All files in github on machinon/ must be up on parent folder to create a .git.
I test the theme, it's really beautifull, and i have some problem.
But it's the worst, is icon. Where is your superb icon !!! lol
Screen Shot 2018-07-10 at 10.36.03.png (194.76 KiB) Viewed 4491 times
11101101 - www.machinon.com
landaisbenj
Domoticz version: stable
Post by landaisbenj »
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
DewGew
Domoticz version: V4.10618
Post by DewGew »
If you want custom icon for this just add them with same filetype (png), size and name on the icon you want to change in machinon/images folder domoticz will replace them automatic.
landaisbenj
Btw the design board is really really cool.
I don't know how to do with css but I'm really good to learn. I will do test on mine et share result!!
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
Ok, moved the files on git, hopefully is the right way now
landaisbenj
Yes it's work fine.
Now you can do that:
git clone https://github.com/EdddieN/machinon-domoticz_theme.git machinon
And upgrade:
git pull
I see for install and icon.
Platforme: Rpbi3b
poudenes
Domoticz version: 3.8993
Post by poudenes »
In multi selection switch you can change it to Button set or Select menu. Select "Select Menu"
landaisbenj
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
Is that suppose to be a selector like the one on the left?
Are they identical buttons? If so have you tried cleaning Chrome’s cache (If using it) -> url bar: chrome://appcache-internals/#
landaisbenj
EdddieN wrote: Tuesday 10 July 2018 19:33 Is that suppose to be a selector like the one on the left?
Yes, it's two way on selector parameter. I try to clean but no change.
Platforme: Rpbi3b
landaisbenj
How do you create the theme, with a software like sketch ? I can try to learn how to help you.
I already make some change on another theme with google chrome inspector...
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
the design was done in sketch / zeplin
landaisbenj
DewGew wrote: Tuesday 10 July 2018 11:51 If you want custom icon for this just add them with same filetype (png), size and name on the icon you want to change in machinon/images folder domoticz will replace them automatic.
I can't do it. I create some icone, and place it with same name of icone in domoticz, but it's don't work.
Platforme: Rpbi3b
landaisbenj
EdddieN wrote: Tuesday 10 July 2018 20:29 the design was done in sketch / zeplin
Thanks i will look at this.
Platforme: Rpbi3b
landaisbenj
Ok i do create some icon.
I try to create more and i post give it to you. I go to bed.
Platforme: Rpbi3b
EdddieN
Post by EdddieN »
Great work! I have added you as a collaborator to the theme, since you already have done more than I can do.
I can help with the graphic design, so if you need any new graphics or updates I can get them
landaisbenj
Nice! I do my best xD i will look at for css
Platforme: Rpbi3b
DewGew
Post by DewGew »
landaisbenj wrote: Tuesday 10 July 2018 21:22
It works great on all my templates..
Did you put them in the right folder? Do not put them in a subfolder in "machinon/images"
landaisbenj
Thanks. No it's browser... I have to delete all image files... :?
Platforme: Rpbi3b
landaisbenj
I've post a pull request and i've make a zip with icon. You can extract .png in images folder
images.zip
(19.68 KiB) Downloaded 210 times
The change in pull request are only visual in best effort to wait.
Change must be done in js.
If i've time ( :( ) i try to clean the code to find the best way to progress whitout sketch (for the moment).
And sorry for my english :roll:
Platforme: Rpbi3b
