Is there any solution already compatible with Domoticz to monitor individual circuit on the electrical panel?
I have Domoticz on my Synology NAS.
The only solution I found are 2 Amp clamp kit.
I want to monitor the Water tank, dryer, pool thermopump and house thermopump. And some other stuff
Envoyé de mon Pixel 2 en utilisant Tapatalk
Cheap solution to monitor individual circuit on the electrical panel?
Banshee1971
- Target OS: -
- philchillbill
Re: Cheap solution to monitor individual circuit on the electrical panel?
Check out the i2c interface products from NCD.io (current monitors). I have a 4 channel one in my fuse box connected to a dedicated pi and it works with Domoticz. They provide a python script.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
freijn
- Domoticz version: Stable
Phil, its a solution but not cheap
Go for the below sensor(s) connect it to an node mcu and stuff ESPeasy on it.
Voila
Frank
https://www.aliexpress.com/item/Non-inv ... autifyAB=0
Voila
Frank
- philchillbill
'Cheap' is of course a relative thing. The 4-channel ncd.io with i2c costs $75. Four of those chinese babies will be $16. You can't exactly buy a new car from that difference...
Banshee1971
- Target OS: -
The minimum solution, 6 donuts. The ideal ; 21.
Do you have any website or description on how to build a 21 donuts solution?
And instructions? Parts list,..
Banshee1971
- Target OS: -
I found this :
https://www.hackster.io/whatnick/esp826 ... tor-b199ed
Now how we connect it to domoticz?
Envoyé de mon SM-T560NU en utilisant Tapatalk
- philchillbill
Using the http client library in arduino for the ESP8266, post to a json url endpoint corresponding to a meter or switch. Google is your friend.
freijn
Why messing around with libraries ?
https://www.letscontrolit.com/wiki/index.php/ESPEasy
1 stop software/image to connect to Domoticz and reliable results.
Banshee1971
- Target OS: -
I found the iotaWatt project on Github. It's a 14 Chanel monitoring using mqtt.
Anyone tested that?
Sound promising.
Anyone tested that?
Sound promising.
