Question about energy usage
rednas
Post by rednas »
Not directly related to Domoticz, but has to do with the results I get from Domoticz.
Can someone explain why there is almost no usage during the day? (Is the usage subtracted from the return? Then why are there still bumps?)
And as soon as there is no return anymore, the usage increases.
I hope someone can help me explain what is going on.
gordonb3
Domoticz version: Custom
Re: Question about energy usage
Post by gordonb3 »
The return is what you are not using. That part never passes your meter. The "bumps" will likely be because you either used more at that particular time or you did not generate (enough) power part of the 5 minute time frame that every point represents.
Of topic: I'm somewhat amazed by graphs posted here by some users. Running two freezers and a separate fridge in the house I'm probably not the best energy saver, but with a maximum below 300 Watts I can't see you do any cooking, laundry or running a dishwasher. How do you do that?
freijn
Domoticz version: Stable
Post by freijn »
I was curious as well and made a simple script.
'Generated by solar' - 'overload back to grid' = 'power consumed by house'.
rednas
Post by rednas »
gordonb3 wrote: Thursday 05 July 2018 9:34 The return is what you are not using. That part never passes your meter.
Is it? So it is not possible to see what my solar panels are delivering?
gordonb3 wrote: Thursday 05 July 2018 9:34 Of topic: I'm somewhat amazed by graphs posted here by some users. Running two freezers and a separate fridge in the house I'm probably not the best energy saver, but with a maximum below 300 Watts I can't see you do any cooking, laundry or running a dishwasher. How do you do that?
Haha, I am currently not at home. And it is a new house.
gajotnt
Domoticz version: V4.9700
Post by gajotnt »
What kind of meter are you using to get that return value?
I have adquired 3 solar panels, and during the day i get negative values (giving energy to the power company) and that kind of meter would be awesome
gordonb3
Post by gordonb3 »
rednas wrote: Thursday 05 July 2018 16:55
Not from reading the P1 datagrams. As explained by @freijn you'll have to combine the data from the inverter to deduce the in house usage.
Right, that makes sense.
rednas
Post by rednas »
So if I'm correct, the P1 only shows "usage minus returns" as usage and "returns minus usage" as returns?
freijn
Post by freijn »
Not sure if I do understand your statement, but the P1 shows the current to/from the Grid.
if +100 you are using 100 watts from the grid
if -100 you are returning 100 watts to the grid.
You solar panels are connected to inside power of your house.
All switched on equipment start consuming the power from your solar first.
If the solar is generating more power that the house requires your P1 will show minus.
For example Solar generates 1000 watts, washing machine eats 600, lamp eats 5 then you still have 395 watts left and the P1 will show -395
if your solar generates 200 and the washingmachine eats 600, the P1 will show 400.
Is the above you are looking for?
Frank
rednas
Post by rednas »
Alright, so during the times where I use more power than is generated, the P1 doesn't record returns? If I would like to know my returns I have to connect my converter to Domoticz?
gajotnt
Post by gajotnt »
You have to use a sonoff pow or a pzem to record what the solar panels are generating
freijn
Post by freijn »
rednas wrote: Thursday 05 July 2018 23:16 Alright, so during the times where I use more power than is generated, the P1 doesn't record returns? If I would like to know my returns I have to connect my converter to Domoticz?
That is correct. The P1 is only between the grid and not inside your house.
Doesn't your solar have any type of communication/reporting ?
I have grabbed some libraries and every time I get an update from the P1 ( 3 sec) I grab the solar numbers as well and do the calculations.
rednas
Post by rednas »
I am currently looking into it to report to Domoticz from my solar panels!
Will get back asap.
rednas
Post by rednas »
freijn wrote: Friday 06 July 2018 8:52 I have grabbed some libraries and every time I get an update from the P1 ( 3 sec) I grab the solar numbers as well and do the calculations.
Is it possible to show the code you use to grab the solar numbers and the calculations?
freijn
Post by freijn »
Not sure which code you are looking for.
This is the code to calc house consumption.
-- Script parameters
Debug = "NO"                    -- Turn debugging on ("YES") or off ("NO")
-- Grid Power calculation    GridPower - Solar Power  and store in Uservariable
local solarflag
local var5
local var6
local powercount
local consume
powersensor = "Power"
if (devicechanged[powersensor]) then
    if Debug=="YES" then
        print( " ####Power debug device changed: "..devicechanged[powersensor])
    commandArray['Variable:TEST']=tostring(devicechanged[powersensor])
    var1,var2,var3,var4,var5,var6 = string.match(otherdevices_svalues['Power'], "(%d+%.*%d*);(%d+%.*%d*);(%d+%.*%d*);(%d+%.*%d*);(%d+%.*%d*);(%d+%.*%d*)")
        print( " ####Power debug var5: "..var5)
        print( " ####Power debug var6: "..var6)
    solarflag="0"
    if (var5 == "0") then
    -- solar is feeding the grid
        powercount = tonumber(var6)
        solarflag="1"
        powercount = tonumber(var5)
        print( " ####Powercount after solarflag: "..powercount)
        print( " ####solarflag: "..solarflag)
    commandArray['Variable:GridPowerVar']= tostring (powercount)
    commandArray['Variable:SolarPowerFlag']= solarflag
    -- store value in variable for later use in other scpt
    --commandArray['Variable:GridPowerVar']= tostring(powercount)
-- testing stuff
--commandArray['Variable:SolarPowerVar']= tostring (1100)
--solarflag =1
   -- get solar power from var and make number
  --commandArray['Variable:SolarPowerVar']= "12"
  -- print ( "solarwaarde "..commandArray['Variable:SolarPowerVar'])
   -- for i, v in pairs(otherdevices) do print(i, v) end
   solarsensor = "SolarEdge kWh"
   Solarvar1, var2 = string.match(otherdevices_svalues[solarsensor], "(%d+%.*%d*);(%d+%.*%d*)")
   Sol = tostring (Solarvar1)
  -- solarcount = commandArray['Variable:SolarPowerVar']
    print("####solarcount read from Var : "..Sol)
  if ( solarflag == "1") then
    consume = Solarvar1 - powercount
    consume = Solarvar1 + powercount
    print( " ####solarcount : "..Solarvar1)
    print( " ####powercount : "..powercount)
    print( " ####solarflag  : "..solarflag)
    print( " ####consume : "..consume)
 ttidx = otherdevices_idx['PowerConsumtion']
 commandArray['UpdateDevice'] = ttidx..'|0|'..consume
stuiow
Domoticz version: 3.6857
Post by stuiow »
I have a similar question now i am generating PV energy.
My aeon meter (that monitors off grid consumption) behaves not how i expected it too.
When i am generating more energy i am using, this shows up as postive on the aeon meter (so it looks like i am pulling pwoer off the grid).
Does the aeonlabs HEM not go into negative figures?
Without fixing that meter, i can't do what ip plain which is , take my solar edge generating figure then take my consumption figures and then have another meter giving my a net import/export figure.
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
gajotnt
Post by gajotnt »
If it shows positive, must be because it doesnt defirentiate the direction of the current :(
stuiow
Post by stuiow »
After snooping around the settings for that meter, I have found a setting that allows the device to log both consumed and exported, so all is well now.
Sent from my SM-G955F using Tapatalk
rednas
Post by rednas »
freijn wrote: Saturday 07 July 2018 21:34 Not sure which code you are looking for.
I finally have my solar panels reporting to Domoticz. This happens every 5 minutes. I also have my P1 meter report every 5 seconds.
If I would use your code, then it would run every 5 seconds with the solar data which updates every 5 minutes, right?
Would this give realistic data?
freijn
Post by freijn »
rednas wrote: Monday 30 July 2018 16:23
Hi Rednas
unfortunately not :-( I have had that the solar reported a huge number then a dark cloud arrived and my P1 produced a huge number getting power from the grid.
Either you decrease the 5 min snap shot to lower or you trigger the calculation only when you receive the new solar values.
Only this way you get 5 min snap shots of your house consumption which is as you can imagine not very realistic view.
margan
Post by margan »
Hopening this thread it's in life.... I'm trying to use this P1 function to read electrical info from an esp8266 device connected to an appliance .
I actually read the values I need on a domoticz window but only as a subset of number in a single window/device.
How can I split these infos to see 3 or for different "windows"/devices, for each read data: voltage, amp, instant power in watt ?
