Dashticz - Module - Garbage collector Topic is solved
Aussi
Re: Dashticz - Module - Garbage collector
Post by Aussi »
EdwinK wrote: Wednesday 14 March 2018 22:48 You change those in CONFIG.js
Really ? Cause I don't see any of those codes in my CONFIG.js ? :( :roll:
Not even from other blocks which are visible on the dashticz interface
Alphons
Post by Alphons »
Is it possible to use the Wastebin Module from the MagicMirror project? Looks very simple en customizable.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Aussi wrote: Thursday 15 March 2018 19:58
Could you reply with the contents of your CONFIG.js?
Or take a look at CONFIG_DEFAULT.js
Venzent
Domoticz version: 3.8153
Post by Venzent »
Is er een werkende voor Almere, krijg ze met de bekende geen info terug.
Venzent
Post by Venzent »
Venzent wrote: Thursday 03 May 2018 19:09 Is er een werkende voor Almere, krijg ze met de bekende geen info terug.
Heb hem al, de "almere" werkt gewoon, bleek alleen niet snel genoeg te reageren.
Vomera
Post by Vomera »
Hi!
I was wondering if Maastricht also will be supported.
I searched for the website they are using.
They use:
https://www.rd4info.nl/NSI/Burger/Aspx/ ... neral.aspx
How can i or the developer implement this in the garbage collector ? :)
Edit: Not needed anymore, checked the garbage js file and i saw rd4 is supported
Vomera
Post by Vomera »
Does someone know why the garbage text is darker then the rest of the buttons ?
It looks like the "button" is disabled
aiolos
Domoticz version: stable
Post by aiolos »
Vomera wrote: Sunday 13 May 2018 10:08 Does someone know why the garbage text is darker then the rest of the buttons ?
The text for the bins is given in the color of the bins, so for the grey bin, it's grey. You can change this with the following part in config.js:
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
You can change the #xxyyzz codes above to whatever you like, and you can lookup a color with for example a hex color picker (https://www.google.com/search?q=hex+color+picker)
Contributor to Dashticz
More on my Github profile
Vomera
Post by Vomera »
:oops: :roll: what it that simple :lol: i didnt look at the hex of the colors. i changed it and now i have the right colors haha thank you very much!!!
wmmudde
Post by wmmudde »
Hello guys,
The garbage calendar and the other calendars are not working anymore since today.
Any suggestions?
Wesley
robgeerts
Post by robgeerts »
Working over here...
Do you get any errors in console-window (F12 on Windows) ?
jdemas
Post by jdemas »
Hi Rob,
RD4 has renamed the BEST to BEST-tas , and isn't showing anymore :o ,
it will probbely because of the - in between. maybe the the best way is to trim of afther 4characters.
regards Jeffrey
jdemas
Post by jdemas »
or the problem is that 2 things will be collected on 1 day
regards Jeffrey
mvveelen
Post by mvveelen »
I got lost in the thread. I had the HVC working in the old version of Dashticz and can't see how to get it working in the latest version. The settings won't save, so I have to add it manually to the CONFIG.js, but how ? Anyone who can help me out?
Edit: nevermind, I figured it out, using the wiki.
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Derik
Post by Derik »
Dear All.
Perhaps someone that have just a simple ical format for garbage in "betuwe"?
Like the dash only for my WAF perhaps better a calendar message....
peet3kabo
Post by peet3kabo »
Rob, is it possible to implement the Omrin afvalkalender?
There is an app available from them, maybe to get the info you need? App called "Omrin Afval"
Otherwise it's only a PDF that you get and then I will try to implement it as an Ical into Dashicz but have to figure out how that goes,
amauryverschooren
Post by amauryverschooren »
Hello Rob, i can't get my garbage list to work. I did eveything that was said in the forum but i won't work. can you have a look at my Config?
regards Amaury
CONFIG.js
(6.58 KiB) Downloaded 102 times
HansieNL
Post by HansieNL »
amauryverschooren wrote: Thursday 06 September 2018 21:22 Hello Rob, i can't get my garbage list to work. I did eveything that was said in the forum but i won't work. can you have a look at my Config?
regards Amaury
Dear Amaury,
Maybe you can post your config.js as code. You can do that by selecting </>
Blah blah blah
amauryverschooren
HansieNL wrote: Thursday 06 September 2018 21:55
regards Amaury
Dear Amaury,
Here you go.
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://192.168.0.185:8080';
config['app_title'] = 'Dashboard';
config['domoticz_refresh'] = '0.1';
config['default_news_url'] = '';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'XXX';
config['gm_zoomlevel'] = '8';
config['gm_latitude'] = 'XXX';
config['gm_longitude'] = 'XXX';
config['wu_api'] = '40e147012dd3f272';
config['wu_city'] = 'Rapenberg';
config['wu_name'] = 'in Bazel';
config['wu_country'] = 'BE';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'd065b50c667940208f2bb2931f77e315';
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['hide_seconds'] = 1;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashcan = {}
trashcan.ophaalkalender = { trashapp: 'ophaalkalender', width:6,street:'kerkstraat',zipcode:'9150', country:'BE' }
var trashnames = {}
trashnames['Rest'] = 'Restafval';
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
var trashcolors = {}
trashcolors['Gft'] = 'Lime';
trashcolors['Pmd'] = 'Orange';
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxxxxx';
var _WEATHER_CITY = 'Kruibeke';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'BE';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = false; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer'
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
{"track":2,"name":"Radio 538","file":"http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3"},
{"track":3,"name":"Arrow Classic Rock","file":"http://www.garnierstreamingmedia.com/as ... stream=205"},
{"track":4,"name":"Radio Veronica","file":"http://live.icecast.kpnstreaming.nl/sky ... GSTR09.mp3"},
{"track":5,"name":"Q-music","file":"http://live.icecast.kpnstreaming.nl/omr ... bantHq.m3u"},
var buttons = {}
buttons.webcam1 = { width:6, isimage:true, refresh:5000, image: 'http://sensored/image.jpg', url: 'http://sensored/image.jpg' }
buttons.webcam2 = { width:6, isimage:true, refresh:5000, image: 'sensored' }
buttons.buienradar = {width:4, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=sensored', url: 'http://www.weeronline.nl/Europa/Nederland/Dordrecht/sensored'}
buttons.nzbget = {width:12, icon: 'fa-download', title: 'NZBget', url: 'http://sensored:6789'}
buttons.log = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
//Groepen & Scenes
//Schakelaars
//Overige
blocks[6] = {}
blocks[6]['width'] = 6;
blocks[6]['title'] = 'Temp. Kamer Amaury:'
blocks[6]['switch'] = true;
blocks[7] = {}
blocks[7]['width'] = 6;
blocks[7]['title'] = 'Temp. Kamer Valerie:'
blocks[7]['switch'] = true;
blocks[8] = {}
blocks[8]['width'] = 6;
blocks[8]['title'] = 'Temp. Woonkamer:'
blocks[8]['switch'] = true;
//Titels
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Temperatuur sensors';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Scenes';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Schakelaars';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Weer';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Radio';
// Kolommen
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['clock','sunrise', 'currentweather_big']
columns[1]['width'] = 2;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1','6','7','8','blocktitle_2']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_3','1','2','5','blocktitle_4','weather']
columns[3]['width'] = 5;
columns[4] = {}
columns[4]['blocks'] = ['currentweather_big']
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = [buttons.buienradar, buttons.radio, buttons.nunl]
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = [trashcan.ophaalkalender]
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
screens[1]['background_night'] = 'bg12.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['background_night'] = 'bg12.jpg';
screens[2]['columns'] = [4,5,6]
HansieNL
Post by HansieNL »
amauryverschooren wrote: Thursday 06 September 2018 21:59
regards Amaury
Dear Amaury,
Here you go.
var config = {}
config['wu_api'] = 'xzxzzxz';
config['spot_clientid'] = 'xzxzx';
var trashcan = {}
trashcan.ophaalkalender = { trashapp: 'zxx', width:6,street:'zxzx',zxzx:'zxzx', country:'BE' }
var trashnames = {}
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.zx/domoticz/switch_horizon.php';
var buttons = {}
var blocks = {}
//Groepen & Scenes
//Schakelaars
//Overige
blocks[6] = {}
blocks[7] = {}
blocks[8] = {}
//Titels
// Kolommen
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[4] = {}
columns[5] = {}
columns[6] = {}
var screens = {}
screens[1] = {}
screens[2] = {}
These variables are empty
You can take a look at the wiki https://www.domoticz.com/wiki/Dashticz_ ... _Collector how to do that.
I don't know what version of Dashticz you are using, because variables all have changed. Now it's a mix of very old and new in your config.js.
TIP: Remove personal info from your config.js if you post on a forum.
Blah blah blah
