ESPEasy/RFM69 and WH24 Weather Station
Everything about esp8266 and more.
Zodiac69
Domoticz version: 3.9319
Post by Zodiac69 »
Hi All
I have managed to get the ESPEasy to read the raw RF string from a WH24 Outdoor Weather Station.
I used Plugin 124 as a template and changed the RFM69 settings to adapt to the WH24.
I can get all the info on my ESPEasy, but i see that Domoticz is not happy with the data format, the only sensor that is working correct is Temp + Humidity.
See Screen shot - it seems that hey want more values that what i am posting??
If you can point me in the right direction it would be appreciated.
cyberclwn
Domoticz version: 2024.4
Re: ESPEasy/RFM69 and WH24 Weather Station
Post by cyberclwn »
I normally take the specifications from the API/JSON page, to get the details that Domoticz expects.
There are the parameters explained which are expected/ needed.
You can use a dummy device in ESPEasy to create/combine the values you need, or use the rules bit to create the required JSON-call to Domoticz.
Hope you succeed.
It's a bit tricky sometimes, but i like that :)
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
