Controlling Lucci Air in Blockly
Goldwing1973
Domoticz version: Stable
Post by Goldwing1973 »
I have a couple of Westinghouse RF Ceiling fan controllers build into the fans.
Now i would like to be able to control the fans and especially the lights in the fans using a blockly script, but i'm unable to find the correct value to put in the "Set =" in Blockly.
I can find the device, "Plafondventilator Woonkamer" but cant find the "light" command to put after the =.
I've tried "On" but no responce.
This is the device
704 RFXCOM 433 Reciever 000005 0 Plafondventilator Woonkamer Fan Lucci Air light
See the last word "light", that appears when i manually turn on the light from the Domoticz Dashboard.
And this is the line that appears in the log when i turn on or off the light
2018-06-28 22:20:57.744 User: mark initiated a switch command (704/Plafondventilator Woonkamer/light)
Any suggestions? i want to be able to control the light from a z-wave wallswitch.
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
ervine
Re: Controlling Lucci Air in Blockly
Post by ervine »
Try using “Light” instead of “light”, so with a capital L. This made the difference for me when using a json call.
Verzonden vanaf mijn iPad met Tapatalk Pro
Goldwing1973
Tried that, without success.
peliilep
Domoticz version: 4.7
Post by peliilep »
Maybe following might explain something:
Re: Lucci fan support with RFXCOM in Domoticz?
Report this post Quote
Post by gizmocuz » Wednesday 20 June 2018 6:22
@Ralfie, try the latest domoticz beta version, it should now support this type of fan
I am not keen on supporting this fan, as it does not have an On/Off option like the AC fan, it has a toggle function
So you can not use this in timers for example
Hope all works
Evo-Home API, HEOS, KaKu, Landys Smartmeters, Logitech Hub, RFXCOM 433, RFXCOM 868 (Visonic), Xiaomi GW, Youless, Zwave+. MySensors: USB-GW + Cat-feeder, Lux sensor, Watermeter
