Hi there - can you try now?
Apologies to all - i've been working hard on implementing something for Google (at their request), and you've probably experienced some minor outages, and some functionality stopping working.
Sorry, but no improvement.
ok, can you mail me from your Controlicz profile and i'll take a look?
Hi all - the 'Test' button is now fully operational - should give you specific errors for each issue.
Hello there,
I just created a new fresh account on controlicz.com
When I try to update my server information, I got an .htaccess error:
Can you help me?
Thank you!
Can you help me?
Thank you!
Hi there -
can you try again? thx
I just tried, still the same problem.
Thank you!
Thank you!
Can you reset your password and try again?
https://www.controlicz.com/forgot
I did it.Madgeni wrote: ↑Tuesday 26 June 2018 16:54 Can you reset your password and try again?
The problem persists.
hi magdeni,
i was able to connect controlicz with alexa, but impossible to link with google home, error message : Couldn't update the settings. Check your connection
the test on your site is ok.
i'm lost
i'm lost
Can you mail me from your controlicz profile? Also, what language is your GH?
done !
i'm french
thank's
i'm french
thank's
Hello, I'm from Spain and when I try to find controlicz in my Google assistant (android app) I can't. Do I have to do anything special?
Enviado desde mi Redmi 4X mediante Tapatalk
It's not available there yet, you need to change the language to English
Ok, if you need help with spanish I can helpMadgeni wrote:It's not available there yet, you need to change the language to English
im spanish too. We have a telegram group about domoticz, if you want i can tell you.
Now im not configured controlicz yet, i dont know how to change the alias to tell google assistant what to do
hi Magdeni,
i've made a fresh install of Domoticz and now everything is ok.
thank's
thank's
To change the alias, go to your device and edit it, in Description you can type Controlicz: and then the name of the alias.
When I ask assistant to do something it says that "it looks like Controlicz is unavailable right now"
thats not good - had a quick check, can you access your Domoticz host over the internet? it's timing out.
