can I do forEach on a table in global_data? [closed]
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
I have a table in global_data that looks like this:
harmony = {
            poweroff = {
                ['name']='PowerOff',
                ['índex']=10,
                ['lightscene']='video'
            television = {
                ['name']='Televisie',
                ['índex']=20,
it is part of the helpers
I can call it with:
domoticz.log (domoticz.helpers.harmony.television.lightscene)
But can I also do this:
       domoticz.helpers.harmony().forEach(function(test)
            domoticz.log (test.name)
        end)
It throws an error:
2018-06-25 16:01:54.123 Status: dzVents: Error (2.4.6): Harmony set Domoticz: ...moticz/scripts/dzVents/scripts/harmony_V-0-0-2-alpha.lua:101: attempt to call field 'harmony' (a table value)
Thank you all!
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
dannybloe
Re: can I do forEach on a table in global_data?
Post by dannybloe »
That's correct. forEach is a dzVents construct that is implemented for the various collections. So for other stuff you will have to do a standard Lua for loop.
rbisschops
Re: can I do forEach on a table in global_data? [closed]
Thx @dannybloe, was expecting that.
