For a few months i work whit domoticz.
The first days it needed a lot of time to get used whit it. But i like it more every day.
Not all wishes are made, but need to do it in steps, otherwise the money flies out the door.
Speaking about a door. One of my wishes is to have a doorbell with camera, to send notification.
Looking at the RING doorbell. Not cheap and untill now not connectable whit domoticz.
I ordered an CTVMAN CM50B01PE WIFI, but it was disappointed.
The CTVMAN is not waterproof. Camera is not protected, therefor the rain will fall on the lens.
Also the motion sensor is not waterproof. Rain will come in the doorbell and it needs just time, to stop working correctly.
An other thing i discovered, the camera stops streaming an image when the doorbell button is pushed. When the doorbell button is pushed the image starts to stream and after a few seconds the stream stops. Couldn't find it, but the RING doorbell connects to an external server. I think that the CTVMAN also connects to an external server. And at last, the doorbell is BIG. Of course it can take 2 batteries.
The CTVMAN Doorbell i am speaking about
After looking around, searching for a doorbell whit the functions a wass looking for.
I stopped searching. I couldn't find it.
Therefor i wan't to design my own doorbell. But looking at this forum, it looks like more people are looking for a video doorbell which is not that expensive, but also can be made to your own wish.
But starting about that. I am not a person which can write big scripts. It will be build whit standard electronics. Lets look where how it will look like and where it will end (or maybe not will end).
What are my wishes, just to start with:
- Push button send to domoticz, for notification or ring chime
- Camera which is attachable whit domoticz
- A led coloured push button
- Optional, MP3-player to play doorbell sound or a recorded speech message when button is pushed
- Trying to get a smaller doorbell than most video doorbells which are on the marked.
How are my thougheds to achieve this:
I ordered a pi zero W. This will be used for a pi cam. This can be connected to domoticz.
I choose for the pi zero wifi version. I don't like to have a network cable to the front door, this because of safety reasons, that your home network isn't outside the door.
For the pi zero there a multiple camera's available. So everybody can choose a cam which fits to his wish.
The pi also can be used for inputs and outputs. The thoughed is that the push button is connected to an input and that triggers 2 outputs. One for a led signal that the button is pushed. The other for playing a MP3 file.
For connection the doorbell function to domoticz i want to use a fibary universal z-wave module.
Also these things i first want to mount in a 3d printed unit.
When the design is ready and usefull, i want to looked to make a metal version.
But also need to think about a waterproof version.
A lot to think about.
I hope a few people like to think about it. Not that those people need to build it. But just the thoughts i am happy whit.
I need to start easy. When everything works propperly then it can be extended.
What are you thinking about this?
Do i miss something? Or are there people that say, look at this or that?
