dzVent version info and .isDevice not working  [Solved]
rogzon
Post by rogzon »
Hi!
I have searched thru the whole Internet for an answer on how to get the version number of my installed dzVents.....
Is there somewhere version information for dzVents?
Also I have this:
	active = true, -- set to false to disable this script
		devices = {
			224, -- id
		httpResponses = {
		    'scheduleinfo',
	    if (device.isDevice) then
	         print('Device!')
I have taken away the http stuff for now but, what I can understand is that if I push the switch(224) the device.isDevice should return true?
It doesn't, when trying "print(device.isDevice)" i get " ... isDevice is a nil value" in my log.
Is this because a dzVent version problem?
Reason: Use code tags please
snellejellep
Re: dzVent version info and .isDevice not working  [Solved]
Post by snellejellep »
to get your version number for dzvents you can go to <your domoticz url>/#/About
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
rogzon
Post by rogzon »
For anybody else reading this..
The version info is available in the About dialog but for some reason I needed to update to 4.9700 to even have an entry stating the dzVents version...
Also device.isDevice is working now.
The only thing completely missing now is device.isSchedule which should return true if the switch would be toggled by a schedule.
It would be quite handy...
rogzon wrote: Monday 25 June 2018 22:09 The only thing completely missing now is device.isSchedule which should return true if the switch would be toggled by a schedule.
If you want to have information if a device state is triggered by a schedule you could use the information in the domoticz log to identify this.
-- isScheduled.lua
triggerDevice = 985  -- define the switch you want to monitor
    on      =   {   httpResponses   =   { "get_DomoticzLogLines" },
                    devices         =   { triggerDevice}},
    logging =   {   level     =   domoticz.LOG_INFO,
                    marker    =   "get triggered by info from log"    },
    execute = function(dz, trigger)
        local function askDomoticzForLogLines()
            local lastLogTime = os.time(os.date('*t')) - 10    -- current Time as seconds from epoch  - 10 should get enough logging
            local logLevel    = 2                              -- loglevel (1=normal,2=Status,4=error,268435455=all
            local jsonString  = "/json.htm?type=command&param=getlog&" ..
                                "lastlogtime=" .. tostring(lastLogTime) ..
                                "&loglevel=" .. logLevel
            dz.openURL  ({ url      = dz.settings["Domoticz url"] .. jsonString,   -- loglevel 2 ==>> Status:logURL,
                           method   = "GET", callback = "get_DomoticzLogLines" })
        -- Get information recent log entries for switch action
        function isScheduled(device)
           local resultTable = trigger.json.result
           for i = #resultTable,1,-1 do                  -- Read backwards to get latest switchoperation first
                if      string.find(resultTable[i].message,device.name) and                             -- Look for Device name , update Time
                        string.find(resultTable[i].message,device.lastUpdate.rawTime) and               -- and string Schedule...
                        string.find(resultTable[i].message,"Schedule") and               -- and strings User: and initiated...
                        not(string.find(resultTable[i].message,"dzVents")) then
                        return true
            return false
        if trigger.isDevice then
            if isScheduled(dz.devices(triggerDevice)) then
                dz.log(dz.devices(triggerDevice).name .. " IS triggered by schedule",dz.LOG_INFO)
                dz.log(dz.devices(triggerDevice).name .. " NOT triggered by schedule",dz.LOG_INFO)
rogzon
Post by rogzon »
Yes, that's a good idea. For now I am storing on and off time as string in a variable like this:
		devices = {
			224, -- id
		httpResponses = {
		    'scheduleinfo',
            print('Device!')
	        if(device.state == 'On') then
                domoticz.openURL({
                    url = 'http://192.001.01.02:8080/json.htm?type=schedules',
                    method = 'GET',
                    callback = 'scheduleinfo'})
		if (device.isHTTPResponse and device.ok) then
		    print('HTTPResponse!')
		    local results = device.json.result
		    for i, node in pairs(results) do
		        if(node.DeviceRowID == 3) then
		            print(node.DevName .. ' ' .. node.Active .. ' ' .. node.Time .. ' ' .. node.TimerCmd)
		            if (node.TimerCmd==1) then
		                domoticz.variables('mvhScheduleOffTime').set(node.Time)
		                domoticz.variables('mvhScheduleOnTime').set(node.Time)
I did however succeed in my original quest which was distinguishing between a physical button push and "on by schedule" in a device event.
I simply moved the timer to a group and put my switch into that group. By setting a uservariable in the "schedule on" event I now know that it wasn't a physical button push.
This comes in handy when controlling engine heaters during winter, push the button means on for 3 hours but don't turn off if schedule has kicked in..
Users browsing this forum: Google [Bot], Wiers and 1 guest
