Domoticz App
felix63
Domoticz version: 2020.1
Re: Domoticz App
Post by felix63 »
I had location services working on my configuration. But when I switched from a Let's Encrypt certificate to a Comodo certificate the location based switching stopped working with the app showing a notification "Error when sending your location to the server". However the app connects to the server just fine. Checked the certificate that seems also to be fine... so I am more than a little puzzled. How could I check/debug/fix this? Trying to switch by calling https://server.xx/json.htm?type=command ... itchcmd=On works fine.
terrorsource
Re: Domoticz App
Post by terrorsource »
Where can I find a full list of free functions and premium functions?
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
terrorsource wrote: Thursday 12 July 2018 21:15 Where can I find a full list of free functions and premium functions?
There is a dialog in the app with all the premium functions explained when you hit that 'buy' button.
galadril
Re: Domoticz App
Post by galadril »
The next coming update finally has a Color Picker implemented for RGB devices!
madpatrick
Domoticz version: 2024.7
Re: Domoticz App
Post by madpatrick »
I'm using the IOS version of the Domoticz app.
When i want to change the thermostat temperature it does not change the setting.
It look like the command of old setting is repeated.
First it goes to 15.5 and then back to 15 (2x)
This is in my log
2018-10-21 17:38:04.734 EventSystem: Sending SetPoint to device....
2018-10-21 17:38:04.735 (Toon schakelaars) Thermostat (Toon Thermostaat)
2018-10-21 17:38:04.624 Status: LUA: Setting Toon setpoint to 15.5
2018-10-21 17:38:04.624 Status: EventSystem: Fetching url http://xxx.xxx.xxx.xxx/happ_thermstat?action=setSetpoint&Setpoint=1550...
2018-10-21 17:38:04.678 Status: LUA: Updating thermostat sensor to new set point: 15
2018-10-21 17:38:04.733 Status: LUA: Updating thermostat sensor to new set point: 15
2018-10-21 17:38:04.789 Status: LUA: Setting Toon setpoint to 15.00
2018-10-21 17:38:04.789 Status: EventSystem: Fetching url http://xxx.xxx.xxx.xxx/happ_thermstat?action=setSetpoint&Setpoint=1500...
I'm using a rooted Toon which operated via Domoticz.
When i change the tempeature in the Domoticz page i've no problem
-= HP server GEN8 Xeon(R) E3-1220L_V2 -=- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.12b on Tab8" =-
Stanleyk
Re: Domoticz App
Post by Stanleyk »
I use 2 iphones in my house and yesterday app stop work. It work from outside to my public ip and nat https port, but from local network stop work. It write not connect to any network... what happend ?
I try :
change http port in domoticz - no change
access from pc web browser - work
acces from phone web browser - work
disable wifi and use 4g network - work
android phone app - work
I enabled debug in iphone app and in log is connect always to external address, not internal. This is problem because my external IP is not reachable from local network and nat is for https where is certificate for domain name. In android app is option for choose local wifi SSID but not in ios app.
What I am doing wrong ?
santricity
Domoticz version: 4.9700
Re: Domoticz App
Post by santricity »
galadril wrote: Tuesday 11 September 2018 9:37 The next coming update finally has a Color Picker implemented for RGB devices!
Hi, any news on Color Picker implementation?
santricity
Re: Domoticz App
santricity wrote: Sunday 09 December 2018 15:21
It's finally there! Thank you! Works great with my Zigate controlled Hue color bulbs!
psmajek
Re: Domoticz App
Post by psmajek »
Is it any way to use iOS app with data from my.domoticz.com ? With Instance id and api key ?
iMoi
Re: Domoticz App
Post by iMoi »
Hi there,
I tried the App on iOS (last version) I and could perfectly connect through LAN but never through internet, far from home. I thought my router or Domoticz settings were incorrect, but the Pilot iOS app connected perfectly with the same settings. Does anyone have an idea ?
(When in servers connection parameters, I click on the connection parameters button, I get a « Error : no connection » message. No problem outside of the LAN)
Best regards
i-Moi
Domoticz (domoticz_apollolake-6.2_4.0.9700-7.spk)
installed on a Synology NAS DS 218+ (INTEL Celeron J3355)
under DSM 6.2.1-23824 Update 4
Raspberry Pi B+ with official cam
+ Android smartphone with IP Webcam
Rinkel
Re: Domoticz App
Post by Rinkel »
I am a bit confused with the app. But I just recently tried Domoticz and just playing with it to see if I can move from my current hub.
I have a (Xiaomi) button on the dashboard, but I cannot push it. I get a list (click/double click/etc)
I really don’t care about that list, I just want to click.
Same thing with clicking on the left part; i get “Favorite”. I really don’t care, I just want to click on a button or turn something on/off.
So I have a push button on the dashboard which I cannot push. Please give me a name and a button to push, nothing else.
Another thing:
I have a switch. I turn the switch (light is turned on, so it works) but the switch on the screen stays off, until I do a refresh, then it’s on.
galadril
Re: Domoticz App
Post by galadril »
Rinkel wrote: Wednesday 13 March 2019 23:41 I have a (Xiaomi) button on the dashboard, but I cannot push it. I get a list (click/double click/etc)
This has nothing to do with the app. the Xiaomi implementation for the button is a selector. You can always make a dummy push button and then via scripts call the Xiaomi button. But it's not due to the app!
galadril
Re: Domoticz App
Post by galadril »
psmajek wrote: Tuesday 25 December 2018 14:57 Is it any way to use iOS app with data from my.domoticz.com ? With Instance id and api key ?
Sorry not yet.. I hope that the my.domoticz.com developer would assist me on connecting his system!
galadril
Re: Domoticz App
Post by galadril »
New update is loaded in the beta channel..
- Added sunset/sunrise information in the action bar
- Moved the filter from the list to the action bar (save space)
- Change the fontsizes
- Improved the design of the list views/screens
- Added support for the door lock + inverted
- Fixed some issues on the blinds
- Updated from old Xamarin framework to 3.6 (nothing new for you :( )
Hope you all like it :D
DewGew
Domoticz version: V4.10618
Re: Domoticz App
Post by DewGew »
Great update. I don't get any notification sound. is that correct?
FearNaBoinne
Domoticz version: 2021.1
Re: Domoticz App
Post by FearNaBoinne »
Stanleyk wrote: Thursday 08 November 2018 21:12 Hello,
I try :
I am was having the above problem as well... Either "not connected to any network" or just "not found", even though I *can* access the LAN interface from the phone browser when on WiFi *or* the WAN from 4G (My firewall is not set up for reflective NATIt is now!)
Last edited by FearNaBoinne on Saturday 24 August 2019 16:39, edited 1 time in total.
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
numanx
Domoticz version: 3.8153
Re: Domoticz App
Post by numanx »
Would it be possible for you to implement iOS criticalAlertSetting (https://developer.apple.com/documentati ... ertsetting) within the Domoticz iOS app?
It would be great for me to receive Domoticz alerts while my iPhone is on DND.
For example I use it for my security system and I would like to know when one of my sensors are tripped even if the iPhone is on DND. Also I am using domoticz for my heating system if the temperature or pressure rises to much I receive an alert which should work even if my iPhone is on DND.
Thank you!
julienjan
Re: Domoticz App
Post by julienjan »
Hi, i recently started to use a RFLink gateway with an Arduino Mega 2560 on my Nas Synology in order to control my blinds using Domoticz. It works but not for all of my switches. Anyway, im writing this to ask yall how do you use the application ??
I have an iPhone SE and Domoticz is installed on my phone. I put the informations of connection: adress, port, etc. and for local connection too.
Then i check my settings and it says "OK" but it doesn't do anything else like showing me my switches (which is a little bit problematic...).
Here are two screenshot:
The informations:
And the last step of Domoticz's setup:
As you can see im french so sorry if my english is bad ^^
Therefore, after i have got the "OK" message, i can't do anything else.
I hope someone has a solution for me :)
Best regards
Julien
Domoticz v4.9700 on NAS Synology DS115j, RFLink on Arduino Mega 2560 (nodo-shop.nl) controlling Somfy RTS blinds, Shelly 1
lmet
Domoticz version: v4.9700
Re: Domoticz App
Post by lmet »
Hi, For me it does not work I have the message: "Error no connection"
iPad iOS 12.3.1 Domoticz 4.10717
it seems that I'm not the only one if I look at the comments in the app store
Thank you for your help
FearNaBoinne
Re: Domoticz App
@Galadril: Any news on implementation of location services for us iOS users?
