Hey folks,
I'm trying to figure out how to control a device using an if condition only if it's between sunset and sunrise.
I have a light by the window which should only be activated when it is dark, I could use set times but I think between sunset and sunrise is the best way to do it.
It has to be in Lua since I've got a fairly complex "Device Control" script already running pretty much all the lights in my apartment.
Has anyone got a script to do this?
Cheers
If motion triggered between sunset and sunrise, control device
Re: If motion triggered between sunset and sunrise, control device
Use dzVents. it's all in there with just a few lines of code (and plain Lua).
Thanks, I figured it out in Lua, here is an example script for anyone else looking to do the same. Domoticz has a built in feature called timeofday which makes it easy.
Nighttime can be changed to Daytime in the script if you need the opposite.
Cheers
if (devicechanged["Living Room"] == 'On' and timeofday['Nighttime']) then
commandArray['Main Bedroom Hallway'] = 'On'
Cheers
- waaren
If I understand your requirement correctly it can be implemented as a device triggered Lua script like
[EDIT] My posting just crossed yours
(btw: you don't need to switch the light off again ?)
if devicechanged['Your motion detector'] == 'On' then
if timeofday['Nighttime'] then
commandArray['light by the window'] = 'On'
print ("light by the window ==>> On");
elseif devicechanged['Your motion detector'] == 'Off' then
commandArray['light by the window'] = 'Off'
print ("light by the window ==>> Off");
waaren the script is just a quick example if anyone is looking how to use the function.
My use case is quite a bit more complex, it's a sub if statement that chooses which devices in the living room to control based on time of day.
Also uses this to accelerate the device control (in some instances):
viewtopic.php?f=61&t=21336
-- Device Last Updates
t1 = os.time()
devices = {
"Main Entrance Motion Sensor",
"Living Room Motion"
numdevices = 0 -- Count number of devices in the array
for index in pairs(devices) do
numdevices = numdevices + 1
for i = 1, numdevices do
s = otherdevices_lastupdate[devices[i]]
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
str = (devices[i] .. "LastUpdate")
str = str:gsub("%s+", "")
str = string.gsub(str, "%s+", "")
_G[str] = (os.difftime (t1, t2))
--- Living Room and Kitchen + Main Entrance Hallway
if (devicechanged["Main Entrance Motion Sensor"] == 'On' and LivingRoomMotionLastUpdate > 32 and otherdevices["Motion Detection"] == 'On' or
devicechanged["Living Room Motion"] == 'On' and MainEntranceMotionSensorLastUpdate > 32 and otherdevices["Motion Detection"] == 'On' or
devicechanged["Main Entrance Door Sensor"] == 'Open') then
if (timeofday['Nighttime']) then
devices = {"Main Entrance Hallway","Living Room Middle","Living Room Window","Kitchen","Fish Tank"}
devices = {"Main Entrance Hallway","Living Room Middle","Kitchen","Fish Tank"}
numdevices = 0
if (otherdevices[devices[i]] == 'Off') then -- Priority control
commandArray[devices[i]] = 'On'
print("Priority On:" .. devices[i])
if (otherdevices[devices[i]] == 'On') then -- Remaining control
print("Remaining On:" .. devices[i])
- waaren
Understand. Nice use of priority based switching !ben53252642 wrote: ↑Monday 11 June 2018 7:00 waaren the script is just a quick example if anyone is looking how to use the function.
Just a hint: you make use of this snippet in your code to count the number of devices in your array
numdevices = 0
for i = 1, #numdevices do
waaren, thank you for making the code even better!
This works without the extra loop (had to use #devices):
Cheers
t1 = os.time()
devices = {
"Main Bathroom Motion",
"Main Bedroom Hallway Motion",
"Main Entrance Door Sensor",
for i = 1, #devices do
