water meter
water meter
I would like to connect an instant water flow meter to the hall effect, someone can help me do it. I saw that a water flow meter already exists in the menu but I do not know how to connect it. Thank you
Re: water meter
before we start giving suggestions, it would help that we know what type of water meter you have and with which device you want to measure this.
That helps in giving correct suggestions and others might even give better solutions to your problem.
Re: water meter
You're right, my domoticz is installed on Raspberry PI3 and as a sensor I would like to use a hall effect that produces pulses that increase in frequency as the flow increases like this: https://www.amazon.it/filettatura-effet ... flow+meter
Thank you
Thank you
Re: water meter
A help at least starting then I try to understand by myself, thanks
water meter
I would install ESPEasy on a NodeMCU, connect the sensor to one of its GPIOs, and set up ESPEasy in such a way that it sends the data to Domoticz. You can use the device type "Pulse Counter" for this. You can even assign a formula to calculate how many litres a single pulse is. There are guides to explain the steps in detail, I think the ESPEasy website also has some info.
I did this with an optical contrast sensor (TCRT-5000) on my "classic" water meter, works perfectly.
Re: water meter
as soon as I can try, thank you
Re: water meter
Resolved, this site has been very helpful: https://www.letscontrolit.com/wiki/index.php/ESPEasy explains how to use ESP8266. Recommended for everyone
