Nefit Easy XMPP authentication failure
Since today there seems to be some issues with the nefit-easy-http-server resulting in XMPP authentication failures.
I already informed Robert Klep (author of the nefit-easy SW) about this and he acknowledged this. https://github.com/robertklep/nefit-eas ... /issues/12
There seems to be something changed at the server side as my Android client still works.
Edit: Last news is that Robert found a solution, but it will take some time to implement. Watch the repo for updates
Update: Update nefit-easy-http-server to v4.0.0 and associated utilities to latest version and problem is solved. Thanks to Robert Klep
- Bartb
Re: Nefit Easy XMPP authentication failure
Brilliant! Works perfectly again.
- Domoticz version: 3.4834
Unfortunately afther the nefit easy upgrade I still get an "XMPP authentication error"
What can be wrong?
I already did:
sudo apt-get update
sudo apt-get upgrade
Here are the versions of my packages
npm -v: 6.1.0
node -v: v9.9.0
easy-server -v: 4.0.1
What can be wrong?
I already did:
sudo apt-get update
npm -v: 6.1.0
node -v: v9.9.0
Works fine with:
node -v 6.14.2
npm -v 3.10.10
easy-server -v 4.0.1
node -v 6.14.2
npm -v 3.10.10
- Domoticz version: 2024.4
Thanks for the fix.
Really appreciate it!
I updated as suggested, unfortunately I now get a:
module.js:549
throw err;
Error: Cannot find module '@xmpp/connection'
When running easy-server.
I tried cleaning, reinstalling, reinstalling NodeJS (8.11.2), but until now no success.
Any help appreciated.
NodeJS 8.11.2
NPM 2.15.11
easy-server > ERROR
module.js:549
throw err;
NodeJS 8.11.2
NPM 2.15.11
easy-server > ERROR
Did you get any errors installing Node.js? When I did it told me my npm version was too low. (sudo npm install npm -g) What tells easy-server -v?
You are right! I removed every instance of NPM and Node(js), literely every file. Thereafter reinstalled with then did a dist-upgrade and voila: latest NPM and latest Node(Js) AND after re-installing with the new NPM: a working Easy-Server!
sudo aptitude install npm
easy-server keeps reporting v3.0.0 after running the following command:
node -v v6.14.2
npm -v 3.10.10
What can I do?
sudo npm update nefit-easy-http-server -g
npm -v 3.10.10
What can I do?
Try:
sudo npm uninstall neffit-easy-http-server -g (this should remove the old one and dependencies)
sudo npm install nefit-easy-http-server -g (should install 4.0.1)
and probably
sudo npm install nefit-easy-commands -g
and probably
I tried this but still ending up with version 3.1.1
Before I had version 4.0.1 but received the Error: NefitEasy: Error getting http data!
Did you see any errors during install?
Don't know about this one, could be a temporary issue. I noticed the Bosch backend servers are not always very reliable
This is what I get as return:
pi@Domoticz:~ $ sudo npm install nefit-easy-http-server -g
/usr/bin/easy-server -> /usr/lib/node_modules/nefit-easy-http-server/bin/easy-server
/usr/lib
└─┬ [email protected]
├── [email protected]
├─┬ [email protected]
│ ├── [email protected]
│ ├─┬ [email protected]
│ │ └── [email protected]
│ │ ├── [email protected]
│ └─┬ [email protected]
│ │ └─┬ [email protected]
│ │ ├─┬ [email protected]
│ │ │ └── [email protected]
│ │ │ ├── @xmpp/[email protected]
│ │ │ ├─┬ @xmpp/[email protected]
│ │ │ │ └── [email protected]
│ │ │ ├── [email protected]
│ │ │ └─┬ [email protected]
│ │ │ ├─┬ [email protected]
│ │ │ │ ├─┬ [email protected]
│ │ │ │ │ ├── [email protected]
│ │ │ │ │ └── [email protected]
│ │ │ │ │ └─┬ [email protected]
pi@Domoticz:~ $
/usr/lib
pi@Domoticz:~ $
Ok, remove this one first and re-install.Biarritz wrote: ↑Saturday 09 June 2018 10:12 This is what I get as return:
/usr/lib
pi@Domoticz:~ $
sudo npm uninstall nefit-easy-http-server -g
This should give you 4.0.1
Did this serveral times already, but 3.1.1 is what I get
I have completely removed /usr/lib/node_modules/nefit-easy-http-server directory
started installation of Nefit easy from scratch
Have now version 4.0.1 running but still receive the Error: NefitEasy: Error getting http data!
What do you see when starting the easy-server manually with -V (verbose) and domoticz tries to access it?
Hmm, this is what I get:
pi@Domoticz:~ $ easy-server --serial=your-xxxx --access-key=xxxx --password=xxxx --host=127.0.0.1
{ SASLError: not-authorized
at XMPPError (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/connection/index.js:10:5)
at SASLError (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/plugins/sasl/index.js:14:5)
at EventEmitter.handler (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/plugins/sasl/index.js:144:15)
at emitOne (events.js:101:20)
at EventEmitter.emit (events.js:188:7)
at Client.EventEmitter.(anonymous function) [as emit] (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/events/lib/EventEmitter.js:46:24)
at Parser.listeners.element.element (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/connection/index.js:118:12)
at emitOne (events.js:96:13)
at Parser.emit (events.js:188:7)
at Parser.onEndElement (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/connection-tcp/node_modules/@xmpp/xml/lib/Parser.js:54:12)
at SaxLtx.Parser.parser.on.name (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/connection-tcp/node_modules/@xmpp/xml/lib/Parser.js:33:14)
at SaxLtx.emit (events.js:188:7)
at SaxLtx._handleTagOpening (/usr/lib/node_modules/nefit-easy-http-server/node_modules/ltx/lib/parsers/ltx.js:38:12)
at SaxLtx.write (/usr/lib/node_modules/nefit-easy-http-server/node_modules/ltx/lib/parsers/ltx.js:127:18)
at Parser.write (/usr/lib/node_modules/nefit-easy-http-server/node_modules/@xmpp/connection-tcp/node_modules/@xmpp/xml/lib/Parser.js:67:17)
condition: 'not-authorized',
text: '',
element:
Element {
parent:
Element {
parent: null,
children: [Object],
attrs: [Object] },
children: [ [Object] ],
attrs: { xmlns: 'urn:ietf:params:xml:ns:xmpp-sasl' } } }
pi@Domoticz:~ $
text: '',
element:
Element {
parent:
Element {
parent: null,
children: [Object],
attrs: [Object] },
pi@Domoticz:~ $
