hi i stumbled across a problem here
i just installed zigate and also python3.what can be the problem here 4
python dev
did took me a wile to get it working or at least ad the zigate hardware
but now i saw that my lights and he blinds did not opeate
seems that all rfx com devices do not work , i have not changed anything to those devices also not to rfxcom hardware
when i use a switch in domoticz it apears normal in log
restart raspberry and the same happened everything apeared to be normal but rfxcom still dous not send anything.
after shutting down raspberry unplugging it and start it up again still nothing happened
but now i did get an error message in log
Error: RFX hardware (2) thread seems to have ended unexpectedly
what could be the problem here or what can i check to hopfully get it working again
kind of a noob in these things
RFXCOM Stopped working
jessy1984
Re: RFXCOM Stopped working
just looked a bit further
seems the usb ports were changed
now rfxcom is on usb1 were it was before usb0
strange as the cable still was in the same port and i did not make any changes to this
zigate i have now changed to usb0
just cous rfxcom seems to be working on usb1 now
but is this correct , now in log i dont see iff zigate is sending a mssg when i set it to alow devices in the settings tab
how can i see witch usb is connected to witch port ?
